I'm a new user to Garuda and am getting the following message on a fresh install of the gaming version of the Dragonized KDE after running the GUI updater.
This is probably as simple of a fix as "remove one of the conflicting packages and try to update again" however I'm not used to configuring such highly customized distros.
I'm a little worried that I might break things... ![]()
garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
--> Refreshing mirrorlists using rate-mirrors, please be patient..
garuda 95.7 KiB 162 KiB/s 00:01 [------------------------------------] 100%
core 157.7 KiB 1095 KiB/s 00:00 [------------------------------------] 100%
extra 1760.1 KiB 4.24 MiB/s 00:00 [------------------------------------] 100%
community 7.1 MiB 6.76 MiB/s 00:01 [------------------------------------] 100%
multilib 167.5 KiB 846 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur 2026.6 KiB 2.45 MiB/s 00:01 [------------------------------------] 100%
spawn pacman -Su
:: Replace ananicy-rules-git with chaotic-aur/ananicy-rules? [Y/n] y
:: Replace nerd-fonts-fira-code with community/ttf-firacode-nerd? [Y/n] y
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: qemu-base and qemu-desktop are in conflict
**GARUDA-INXI OUTPUT**
root=UUID=d3d2c1f4-dea3-4c51-8742-daa8a36ffb02 rw rootflags=subvol=@
resume=UUID=041d78a5-5372-4e8f-9018-921356951f21 loglevel=3
Desktop: KDE Plasma v: 5.26.1 tk: Qt v: 5.15.6 info: latte-dock
Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming
serial: <superuser required> Chassis: type: 10 v: IdeaPad L340-15IRH Gaming
Mobo: LENOVO model: LNVNB161216 v: SDK0J40700 WIN
serial: <superuser required> UEFI: LENOVO v: BGCN34WW date: 05/21/2021
ID-1: BAT0 charge: 38.6 Wh (94.8%) condition: 40.7/45.0 Wh (90.5%)
volts: 12.4 min: 11.4 model: SMP L18M3PF1 type: Li-poly serial: <filter>
status: not charging cycles: 54
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2400 high: 2401 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 2401 2: 2400 3: 2400
4: 2400 5: 2400 6: 2400 7: 2400 8: 2400 bogomips: 38400
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Lite-On Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:3 chip-ID: 04ca:7070 class-ID: 0e02
Monitor-1: eDP-1 model: BOE Display 0x0700 built: 2016 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa
22.2.1 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
bus-ID: 1-1.2:4 v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
chip-ID: 041e:324d bus-ID: 00:1f.3 class-ID: 0300 serial: <filter>
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-3: Creative Sound Blaster Play! 3 type: USB
IF: wlp0s20f3 state: down mac: <filter>
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 591.54 GiB used: 14.84 GiB (2.5%)
model: MZVLB512HBJQ-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: 3L1QEXF7 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 114.6 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: / raw-size: 459.59 GiB size: 459.59 GiB (100.00%) used: 14.83 GiB
(3.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.59 GiB size: 459.59 GiB (100.00%) used: 14.83
GiB (3.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 459.59 GiB size: 459.59 GiB (100.00%) used: 14.83
ID-5: /var/tmp raw-size: 459.59 GiB size: 459.59 GiB (100.00%) used: 14.83
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 47.0 C pch: 56.0 C mobo: N/A
Processes: 296 Uptime: 1h 28m wakeups: 1 Memory: 15.5 GiB used: 6.87 GiB
(44.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1831 libs: 514
Garuda (2.6.8-1):
System install date: 2022-11-14
Last full system update: 2022-11-14
Is partially upgraded: Yes
