Similar problem to this post from 2022:
Answering either yes or no fails so my system won’t update. I’ve waited about a week hoping this would get fixed on the back end but it is still failing - any advice or actions I should take?
Thanks!!
:: Replace networkmanager-qt with extra/networkmanager-qt5? [Y/n] y
:: Replace prison with extra/prison5? [Y/n] y
:: Replace purpose with extra/purpose5? [Y/n] y
warning: qemu-base: ignoring package upgrade (8.1.0-2 => 8.1.1-1)
:: Replace qqc2-desktop-style with extra/qqc2-desktop-style5? [Y/n] y
warning: reshade-shaders-git: local (r879.a2314cb-1) is newer than chaotic-aur (r31.99b9732-1)
:: Replace solid with extra/solid5? [Y/n] y
:: Replace sonnet with extra/sonnet5? [Y/n] y
:: Replace syndication with extra/syndication5? [Y/n] y
:: Replace syntax-highlighting with extra/syntax-highlighting5? [Y/n] y
:: Replace threadweaver with extra/threadweaver5? [Y/n] y
resolving dependencies...
warning: ignoring package qemu-base-8.1.1-1
warning: cannot resolve "qemu-base=8.1.1-1", a dependency of "qemu-desktop"
:: The following package cannot be upgraded due to unresolvable dependencies:
qemu-desktop
:: Do you want to skip the above package for this upgrade? [y/N]
╰─λ garuda-inxi
Kernel: 6.4.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=96a32e1f-c291-4c2d-b366-9065d5f95e53 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.7 tk: Qt v: 5.15.10 info: latte-dock
wm: kwin_x11 vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Micro-Star model: B550-A PRO (MS-7C56) v: 2.0
serial: UEFI: American Megatrends LLC. v: A.70
date: 06/23/2021
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
model-id: 0x21 (33) stepping: 2 microcode: 0xA201204
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3881 high: 4650 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3647 2: 3700
3: 3707 4: 3599 5: 3700 6: 4395 7: 4650 8: 3599 9: 3618 10: 3598 11: 4650
12: 3710 bogomips: 88796
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 2d:00.0 chip-ID: 1002:73ff
s-diag: 1245mm (49.01")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: right model: Dell U2711
serial: built: 2010 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: Dell 2709W
serial: built: 2009 res: 1920x1200 hz: 60 dpi: 84 gamma: 1.2
size: 582x364mm (22.91x14.33") diag: 686mm (27") ratio: 16:10 modes:
max: 1920x1200 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: AMD Radeon RX 6600 XT
(navi23 LLVM 16.0.6 DRM 3.52 6.4.12-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2d:00.1 chip-ID: 1002:ab28
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.4.12-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.79 status: active with: 1: pipewire-pulse
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac:
IF-ID-1: anbox0 state: down mac:
IF-ID-2: virbr0 state: down mac:
Local Storage: total: 9.1 TiB used: 1.9 TiB (20.9%)
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 731030WD temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWR480 size: 7.28 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 7200 serial: fw-rev: 0601 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 772.78 GiB (41.5%)
used: 772.78 GiB (41.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 1.52 GiB (4.9%)
System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 42.0 C
mem: 42.0 C
Processes: 374 Uptime: 7d 15h 55m wakeups: 0 Memory: total: 32 GiB
available: 31.27 GiB used: 8.24 GiB (26.4%) Init: systemd v: 254
Packages: 2347 pm: pacman pkgs: 2342 libs: 598 tools: octopi,pamac,paru
pm: flatpak pkgs: 5 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date: 2022-07-12
Last full system update: 2023-09-08
Failed units: anbox-container-manager.service bluetooth-autoconnect.service systemd-networkd-wait-online.service
