garuda-inxi:
Kernel: 6.5.7-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=4fdf9e35-eb8e-4181-93e8-eae07da02c42 rw rootflags=subvol=@
amd_iommu=on ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: LENOVO product: 82KC v: Lenovo V14 G2 ALC
serial: <superuser required> Chassis: type: 10 v: Lenovo V14 G2 ALC
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GLCN46WW date: 04/29/2022
ID-1: BAT0 charge: 37.8 Wh (97.7%) condition: 38.7/38.0 Wh (101.9%)
volts: 8.1 min: 7.7 model: LGC L20L2PF0 type: Li-poly serial: <filter>
status: not charging cycles: 65
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 3150 high: 4045 min/max: 400/4056 scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4043 2: 4043 3: 3347
4: 2859 5: 2980 6: 3335 7: 2434 8: 2268 9: 4045 10: 4042 11: 2257 12: 2148
bogomips: 50307
Device-1: AMD Lucienne vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: HDMI-A-1,eDP-1
empty: none bus-ID: 04:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 45.0 C
Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:2137
class-ID: 0e02
Screen-1: 0 s-res: 1920x2160 s-dpi: 96 s-size: 506x570mm (19.92x22.44")
s-diag: 762mm (30.01")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 pos: top model: Dell P2417H
serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
Monitor-2: eDP-1 mapped: eDP pos: primary,bottom
model: AU Optronics 0x208d built: 2019 res: 1920x1080 hz: 60 dpi: 158
gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14") ratio: 16:9
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (renoir LLVM
16.0.6 DRM 3.54 6.5.7-zen2-1-zen) device-ID: 1002:164c memory: 1.95 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:164c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.5.7-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.82 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:c123
Local Storage: total: 476.94 GiB used: 326.77 GiB (68.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lenovo
model: UMIS RPJTJ512MEE1OWX size: 476.94 GiB block-size: physical: 512 B
fw-rev: 2.1C0628 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
used: 174.07 GiB (67.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-4: /var/log raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-5: /var/tmp raw-size: 256.64 GiB size: 256.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 21.37 GiB used: 690.5 MiB (3.2%)
System Temperatures: cpu: 50.5 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 390 Uptime: 23m wakeups: 1 Memory: total: 24 GiB note: est.
available: 21.37 GiB used: 5.72 GiB (26.8%) Init: systemd v: 254
Packages: pm: dpkg pkgs: 0 pm: pacman pkgs: 1532 libs: 417
tools: octopi,paru,yay pm: rpm pkgs: 0 Shell: fish v: 3.6.1
running-in: yakuake inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-06-28
Last full system update: 2023-10-18 ↻
Hi,
For a few months now, once every few updates I get the issue described in many different posts on the forum, see e.g., [1], [2], [3], and [4].
The issue is that garuda-update fails due to a missing qemu-base dependency. Here is the console output of running garuda-update, just to have the full context:
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
:: Replace libinput_gestures_qt with chaotic-aur/libinput-gestures-qt? [Y/n] y
warning: qemu-base: ignoring package upgrade (8.1.1-2 => 8.1.2-1)
warning: virt-manager-meta: local (5-4.3) is newer than garuda (5-4)
resolving dependencies...
warning: ignoring package qemu-base-8.1.2-1
warning: cannot resolve "qemu-base=8.1.2-1", a dependency of "qemu-desktop"
:: The following package cannot be upgraded due to unresolvable dependencies:
qemu-desktop
:: Do you want to skip the above package for this upgrade? [y/N] n
:: unable to satisfy dependency 'qemu-base=8.1.2-1' required by qemu-desktop
The recommended solution has always been to remove virt-manager and virt-manager-meta and then to reinstall them. I have been doing that each time. However, it’s getting tedious. I need virt-manager for my VMs, so I can’t permanently uninstall it.
I’d like not to have to uninstall it every time there’s a qemu update available. Is there a more permanent solution to the problem?
