Performance optimized repositories - cachyos-aur
I use kate in Gnome. The Qt-Design doesn't really fit in, but using Plasma I got used to it and won't miss it.
Wasn't the most serious of comments though :wink:
As much as I use micro, I really do love Kate for some things because I can’t be bothered to learn keybindings for vim lol
Kate on i3wm :slight_smile:
Hmm. Doesn't quite fit in with Gnome, since it doesn't take the dark theme from Gnome and under Settings I only have "Standard"-theme for the window.
Dont ask me about, but is the kvantum thing. IIRC.
btw,
Offtopic :slight_smile:
Forgive my last OT-post here, but mentioning "kvantum" was quite enough to fix the problem. :slight_smile:
Thanks and good night :smiley:
Geekbench detected no performance improvement. Duh. I get a boost by having more optimized applications, not by having the CPU actually work faster.
My pre-upgrade snapshots expired so I can't boot on old snapshot to benchmark anymore.
If someone else wants to apply the upgrades, could you run Javascript benchmarks? Firedragon is among the things that get recompiled and thus Javascript should see a good difference.
  1. Run the JetStream benchmark before
  2. Apply the Intel upgrade
  3. Add the AHLP repos
  4. Benchmark again
  5. Post results.
I'm curious.
OK, so did a few performance benchmarks on this: context, benchmarking garuda-cachyos-x86-v3 vs gentoo-znver2.
As normal and previous using ahlp, gentoo (all compiled to znver2) is around 15/20% faster than garuda on some tests. but it's "not felt" ... its only through various hyperfine benchmarks.
the kernel though, cachyos-bore-lto was the one I tested.... focked all the results. both in gentoo and garuda (I copied the kernel installed on garuda to gentoo, kernel, initramfs and modules), in some benchmarks, halfed the times of the tests.
on jetstream bench, it increased 14% the final result.
Probably, what is doing this, is I noticed cachyos is using the new amd-pstate-epp, and it seemed to work wonders. (using zen or xanmod kernels, with performance governor was able to keep up, but amd-pstate-epp does switch frequencies, unlike performance on "normal" amd-pstate).
All in all... bottom line, for amd ryzen users, i would advise using cachyos repo or ahlp (or both) and definitly using cachyos kernel and check if amd-pstate-epp is enabled on cpupower.
PS: remembered why i stopped using cachyos repos: some packages were/are missing.
Hmm, after installing a cachyos kernel and upgrading with garuda-update, I have the next error
( 1/19) Restoring Linux kernel modules...
++ uname -r
+ KVER=6.0.0-1-cachyos
+ test -e /usr/lib/modules/backup/6.0.0-1-cachyos
+ rsync -AHXal --ignore-existing /usr/lib/modules/backup/6.0.0-1-cachyos /usr/lib/modules/
+ rm -rf /usr/lib/modules/backup
( 2/19) Creating system user accounts...
( 3/19) Reloading system manager configuration...
( 4/19) Creating temporary files...
( 5/19) Arming ConditionNeedsUpdate...
( 6/19) Updating module dependencies...
( 7/19) Install DKMS modules
==> dkms install --no-depmod v4l2loopback-dc/1.8.2 -k 6.0.1-1-cachyos
==> dkms install --no-depmod hid-xpadneo/0.9.5 -k 6.0.1-1-cachyos
==> depmod 6.0.1-1-cachyos
( 8/19) Updating linux initcpios...
call to execv failed (No such file or directory)
After that, when I reboot and in grub menu, when I select "Garuda Linux". I will have stuff related to "zen-kernel" something and and error "you should load the kernel first"
kek
 ╰─λ mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux-cachyos.preset: 'default'
  -> -k /boot/vmlinuz-linux-cachyos -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-cachyos.img
==> ERROR: specified kernel image does not exist: `/boot/vmlinuz-linux-cachyos'
==> Building image from preset: /etc/mkinitcpio.d/linux-cachyos.preset: 'fallback'
  -> -k /boot/vmlinuz-linux-cachyos -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-cachyos-fallback.img -S autodetect
After updating or installing any kernel system is crushed. Not sure how to resolve this
Make an issue and stop posting it under the community section in an open thread would be my first tip
well ... in my case:
I had to copy the kernel into boot and manually run mkinitcpio
the kernel is in /lib/modules/$VERSION/vmlinuz
dunny why but didn't work like "other arch kernels".
Try to remove the kernel, you still should have a performance uplift, because of packages x86-64-v3.
Actually the amd-pstate-epp does not bring a benefit in most cpu benchmarks, I have benchmarked all amd-pstate-epp preferences (can be set when using the powersave gov), against acpi and amd-pstate (schedutil, ondemand, performance - powersave is at them not useable), and acpi perf did showed the best result.
The EPP driver improves the frequencies switching a lot --> better power per watt ratio.
To your PS:
Which packages you are missing ?
Edit:
pstate-epp will need with 6.0.2 then a cmdline parameter to be enabled:
amd_pstate.epp=1
well
 actually it does! but in my case i have to use amd_pstate.shared_mem=1 so, other cpus might have different results.
the result on amd-pstate-epp is only comparable to amd-pstate with performance gov, but then, it gets much hotter and uses more watts. i guess amd-pstate-epp on performance gov is kinda like amd-pstate performance gov, but turning freq to min when not in use. FINE by me.
in here, zen2 cpu, it doesn’t switch much frequencies
 its either min freq or max freq.
I don’t remember all of them, but for example notice on this recent testing that chromium is missing. its cool that ungoogled-chromium exists, but is not a 1:1 map with arch repos.
But I found amd_pstate_epp performance to be similar as amd-pstate ondemand.
According to my tests here(https://forum.garudalinux.org/t/discussing-linux-kernels-for-garuda-linux/):
The xanmod kernel using amd-pstate gives more battery, and the overall temperature seems lower than the linux-bore kernel with amd_pstate_epp.
well
 dunno!
I am not invalidating any results, just stating what is happening here on my znver2!
We don’t actually provide optimized “community” repo(in which chromium is), maybe in future.
I think you have not used the the powersave gov, then you are able to set different preferences.
The performance gov is not really good at the epp driver, you should do following:
sudo cpupower frequency-set -g powersave
echo power | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/energy_performance_preference
Following can be set as prefererence:
default performance balance_performance balance_power power
Here you can read more about the ppw.
https://lore.kernel.org/lkml/20221010162248.348141-1-Perry.Yuan@amd.com/
That looks more like a Kernel parm than a Command line parm. Is it?
