Hi all,
I have a Lenovo Legion 5 laptop with intel / nvidia graphics. I am running the Dragonized flavor, so KDE is my desktop. After a recent Garuda upgrade, it looks like the NVidia GPU isn't utilized. I noticed this because my external HDMI monitor no longer works. I believe I did the upgrade correctly according to the information on this forum.
After upgrading, I noticed that Optimus Manager Qt was showing "integrated" instead of "hybrid" as it did before the upgrade. If I try to switch to hybrid, the system hangs on reboot at the screen with the text:
Loading Linux linudx-zen ...
Loading initial ramdisk ...
What I've tried
Upgrade Garuda properly. I did this several times thanks to Timeshift.
Here is how I upgraded because of the Python issue posted:
garuda-upadate
sudo pacman -Syu optimus-manager optimus-manager-qt
Downgrade the NVidia driver.
I don't believe the issue is related to the driver update from 495.44 to 495.46 because after I updated Garuda, I downgraded the NVidia driver back to 495.44. First I used add/remove software to remove the four packages that I reinstalled shown below:
2021-12-24 11:53:19 sudo pacman -U https://archive.archlinux.org/packages/n/nvidia-utils/nvidia-utils-495.44-6-x86_64.pkg.tar.zst
2021-12-24 11:59:53 sudo pacman -U https://archive.archlinux.org/packages/n/nvidia-dkms/nvidia-dkms-495.44-6-x86_64.pkg.tar.zst
2021-12-24 12:02:23 sudo pacman -U https://archive.archlinux.org/packages/n/nvidia-prime/nvidia-prime-1.0-4-any.pkg.tar.zst
2021-12-24 12:03:35 sudo pacman -U https://archive.archlinux.org/packages/n/nvidia-settings/nvidia-settings-495.44-1-x86_64.pkg.tar.zst
Made sure I was not somehow in a Wayland session:
╭─[email protected] in ~ took 3ms
╰─λ echo $XDG_SESSION_TYPE
x11
I tried swithcing to discrete graphics in the BIOS.
I have verified all the necessary packages are in place using the list mmsaeed509 provided in a post below.
Here is what I see in dmesg for both working system and upgraded system:
Working
╭─[email protected] in ~ took 2m
╰─λ sudo dmesg | egrep -i '(nvrm|nvidia)'
[sudo] password for john:
[ 10.588880] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input27
[ 10.588908] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input28
[ 10.588929] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input29
[ 10.588947] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input30
[ 10.588965] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input31
[ 10.588984] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input32
[ 16.125090] nvidia: module license 'NVIDIA' taints kernel.
[ 16.139336] nvidia-nvlink: Nvlink Core is being initialized, major device number 507
[ 16.139782] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[ 16.139930] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 16.181165] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.44 Fri Oct 22 06:13:12 UTC 2021
[ 16.189977] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 495.44 Fri Oct 22 06:05:22 UTC 2021
[ 16.190772] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 17.027929] NVRM: nv_acpi_dsm_method: DSM data invalid!
[ 17.605777] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-4
[ 17.614894] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-4
[ 17.734973] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
Upgraded:
[ 9.305469] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input26
[ 9.305501] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input27
[ 9.305537] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input28
[ 9.305569] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input29
[ 9.305607] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input30
[ 9.305637] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input31
[ 15.556964] nvidia: module license 'NVIDIA' taints kernel.
[ 15.570968] nvidia-nvlink: Nvlink Core is being initialized, major device number 507
[ 15.571418] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[ 15.571573] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 15.613120] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 495.46 Wed Oct 27 16:31:33 UTC 2021
[ 16.483010] NVRM: nv_acpi_dsm_method: DSM data invalid!
inxi -Faz for both working and upgraded systems
Working System:
╭─[email protected] in ~ took 3s
╰─λ inxi -Faz
System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=7b6e96df-621e-4aaf-a245-80007eef5efa rw
[email protected] quiet
cryptdevice=UUID=15025ade-dda6-4f32-a486-4a0b51903fa0:luks-15025ade-dda6-4f32-a486-4a0b51903fa0
root=/dev/mapper/luks-15025ade-dda6-4f32-a486-4a0b51903fa0 splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: LENOVO product: 82JF v: Legion 5 Pro 16ITH6 serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <superuser required> UEFI: LENOVO v: H1CN26WW
date: 05/22/2021
Battery: ID-1: BAT0 charge: 82.2 Wh (100.0%) condition: 82.2/80.0 Wh (102.8%) volts: 16.9 min: 15.4 model: Celxpert L20C4PC1
type: Li-poly serial: <filter> status: Full cycles: 23
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 50% rechargeable: yes status: Discharging
CPU: Info: 8-Core model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP arch: Tiger Lake family: 6
model-id: 8D (141) stepping: 1 microcode: 32 cache: L1: 640 KiB L2: 10 MiB L3: 24 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 73728
Speed: 1002 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 1002 2: 4527 3: 1816 4: 2963 5: 4228 6: 800 7: 3179
8: 801 9: 3237 10: 1151 11: 4372 12: 1730 13: 2858 14: 1983 15: 1060 16: 4450
Graphics: Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:9a60 class-ID: 0300
Device-2: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Lenovo driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:25e2 class-ID: 0300
Device-3: IMC Networks Integrated Camera type: USB driver: uvcvideo bus-ID: 3-6:3 chip-ID: 13d3:56bb class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0
Screen-1: 0 s-res: 4480x1600 s-dpi: 96 s-size: 1184x423mm (46.6x16.7") s-diag: 1257mm (49.5")
Monitor-1: eDP-1 res: 2560x1600 hz: 165 dpi: 188 size: 345x215mm (13.6x8.5") diag: 407mm (16")
Monitor-2: HDMI-1-0 res: 1920x1080 hz: 60 dpi: 88 size: 553x311mm (21.8x12.2") diag: 634mm (25")
Audio: Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:2291 class-ID: 0403
Device-3: Logitech Blue Microphones type: USB driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-10:6
chip-ID: 046d:0ab7 class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.40 running: yes
Network: Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:43f0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 3000
bus-ID: 58:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp88s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-14:8 chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 2.29 TiB used: 243.84 GiB (10.4%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: SK Hynix model: HFS512GDE9X084N size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 41010C22 temp: 41.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT2000P5SSD8 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 31.9 C scheme: GPT
Partition: ID-1: / raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 100.09 GiB (21.0%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0 mapped: luks-15025ade-dda6-4f32-a486-4a0b51903fa0
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 16.7 MiB (6.5%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:3
ID-3: /home raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 143.73 GiB (7.7%) fs: btrfs dev: /dev/dm-1
maj-min: 254:1 mapped: luks-a4ed31b6-55c7-4c61-86fd-10848d8a80d9
ID-4: /var/log raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 100.09 GiB (21.0%) fs: btrfs dev: /dev/dm-0
ID-5: /var/tmp raw-size: 476.68 GiB size: 476.68 GiB (100.00%) used: 100.09 GiB (21.0%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: zram size: 15.41 GiB used: 232.8 MiB (1.5%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 37.0 C mobo: N/A
Info: Processes: 392 Uptime: 54m wakeups: 4 Memory: 15.41 GiB used: 4.63 GiB (30.0%) Init: systemd v: 249 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1939 lib: 443 Shell: fish v: 3.3.1 default: Bash v: 5.1.12
running-in: konsole inxi: 3.3.09
Upgraded System:
╰─λ inxi -Faz
Kernel: 5.15.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=7b6e96df-621e-4aaf-a245-80007eef5efa rw [email protected]
quiet
serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16ITH6
serial: <superuser required> UEFI: LENOVO v: H1CN26WW date: 05/22/2021
volts: 16.9 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x32
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1546 high: 3414 min/max: 800/4600 scaling:
driver: intel_pstate governor: performance cores: 1: 1469 2: 801 3: 3414
4: 801 5: 800 6: 801 7: 801 8: 1522 9: 2112 10: 1557 11: 3255 12: 801
13: 2271 14: 2742 15: 801 16: 801 bogomips: 73728
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9a60 class-ID: 0300
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
bus-ID: 3-6:4 chip-ID: 13d3:56bb class-ID: 0e02
loaded: modesetting display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.7x16.7")
s-diag: 798mm (31.4")
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 21.3.2
direct render: Yes
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-10:7 chip-ID: 046d:0ab7
Sound Server-1: ALSA v: k5.15.11-zen1-1-zen running: yes
Sound Server-5: PipeWire v: 0.3.42 running: yes
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 58:00.0
bus-ID: 3-14:9 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 4 state: up address: <filter>
Local Storage: total: 9.56 TiB used: 255.98 GiB (2.6%)
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: P4CR311 temp: 37.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 type: USB vendor: Seagate
model: Backup+ Hub BK size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: D781 scheme: GPT
used: 108.5 GiB (22.8%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
used: 16.7 MiB (6.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
used: 147.46 GiB (7.9%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
ID-1: swap-1 type: zram size: 15.41 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 33.0 C mobo: N/A
Processes: 501 Uptime: 9h 0m wakeups: 9 Memory: 15.41 GiB
used: 4.38 GiB (28.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1934 lib: 442 Shell: fish
v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
nvidia-smi for both working and upgraded system
Working
╭─[email protected] in ~ took 15s
╰─λ nvidia-smi
Thu Dec 23 19:59:36 2021
| NVIDIA-SMI 495.44 Driver Version: 495.44 CUDA Version: 11.5 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 On | N/A |
| N/A 36C P8 6W / N/A | 62MiB / 3910MiB | 20% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 3831 G /usr/lib/Xorg 61MiB |
Upgraded
╭─[email protected] in ~ took 3m19s
╰─λ nvidia-smi
Thu Dec 23 20:45:32 2021
| NVIDIA-SMI 495.46 Driver Version: 495.46 CUDA Version: 11.5 |
| | | MIG M. |
| 0 NVIDIA GeForce ... Off | 00000000:01:00.0 Off | N/A |
| N/A 33C P0 N/A / N/A | 0MiB / 3910MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
