Garuda-inxi
Kernel: 5.19.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=ec56f045-0b46-48cb-ad41-c68705366f20 rw rootflags=subvol=@
quiet
cryptdevice=UUID=a67a8316-52c4-4a8e-b15d-27bb91d58197:luks-a67a8316-52c4-4a8e-b15d-27bb91d58197
root=/dev/mapper/luks-a67a8316-52c4-4a8e-b15d-27bb91d58197 quiet splash
Type: Laptop System: Micro-Star product: GL62M 7RD v: REV:1.0
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16J9IMS.324 date: 03/23/2018
ID-1: BAT1 charge: 25.7 Wh (97.0%) condition: 26.5/43.2 Wh (61.3%)
volts: 12.1 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 level: v3 built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1469 high: 2800 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1000 2: 1087 3: 2800
4: 1000 5: 1066 6: 1000 7: 1000 8: 2800 bogomips: 44798
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d
class-ID: 0302
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-11:4
chip-ID: 5986:0683 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: gpu: i915 note: X driver n/a display-ID: :0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15d2 built: 2015 res: 1920x1080
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.19.10-zen1-1-zen running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:3 chip-ID: 8087:0aa7 class-ID: e001
Local Storage: total: 931.51 GiB used: 86.23 GiB (9.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A3U0
ID-1: / raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 11.98 GiB
(18.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a67a8316-52c4-4a8e-b15d-27bb91d58197
ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%) used: 984 KiB
(0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 11.98 GiB
ID-4: /var/log raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 11.98
GiB (18.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-5: /var/tmp raw-size: 65.19 GiB size: 65.19 GiB (100.00%) used: 11.98
ID-1: swap-1 type: zram size: 7.68 GiB used: 1.42 GiB (18.5%)
ID-2: swap-2 type: partition size: 14.9 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda5 maj-min: 8:5
System Temperatures: cpu: 48.0 C pch: 44.5 C mobo: N/A
Processes: 309 Uptime: 1h 22m wakeups: 1 Memory: 7.68 GiB used: 3.17 GiB
(41.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: 1236 pm: pacman pkgs: 1227 libs: 311
tools: octopi,paru pm: snap pkgs: 9 Shell: Bash v: 5.1.16 running-in: tilix
inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-09-26
Last full system update: 2022-09-26 ↻
When I am trying to run vivaldi or any of the snap based apps I am getting this error -
$ vivaldi-stable
[0926/125325.723142:ERROR:file_writer.cc(98)] writev: No space left on device (28)
[0926/125325.723157:ERROR:crash_report_exception_handler.cc(226)] WriteEverything failed
Trace/breakpoint trap (core dumped)
Here is my df -h
$ df -h
Filesystem Size Used Avail Use% Mounted on
dev 3.9G 0 3.9G 0% /dev
run 3.9G 18M 3.9G 1% /run
/dev/dm-0 66G 12G 53G 19% /
tmpfs 3.9G 52M 3.8G 2% /dev/shm
/dev/loop1 128K 128K 0 100% /var/lib/snapd/snap/bare/5
/dev/loop2 46M 46M 0 100% /var/lib/snapd/snap/snap-store/599
/dev/loop4 165M 165M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
/dev/loop7 48M 48M 0 100% /var/lib/snapd/snap/snapd/16778
/dev/loop8 64M 64M 0 100% /var/lib/snapd/snap/core20/1623
/dev/loop5 56M 56M 0 100% /var/lib/snapd/snap/core18/2566
/dev/loop6 347M 347M 0 100% /var/lib/snapd/snap/gnome-3-38-2004/115
/dev/loop0 92M 92M 0 100% /var/lib/snapd/snap/gtk-common-themes/1535
tmpfs 3.9G 3.7M 3.9G 1% /tmp
/dev/dm-0 66G 12G 53G 19% /var/log
/dev/dm-0 66G 12G 53G 19% /var/tmp
/dev/dm-0 66G 12G 53G 19% /srv
/dev/dm-0 66G 12G 53G 19% /var/cache
/dev/dm-0 66G 12G 53G 19% /home
/dev/dm-0 66G 12G 53G 19% /root
/dev/sda2 499M 984K 499M 1% /boot/efi
tmpfs 787M 787M 0 100% /run/user/1000
/dev/dm-1 9.1G 895M 7.7G 11% /run/media/cerulean/Docs
/dev/dm-2 313G 27G 270G 9% /run/media/cerulean/Var
/dev/dm-3 46G 2.0G 42G 5% /home/cerulean/Pictures
/dev/dm-4 274G 45G 216G 18% /home/cerulean/Videos
and my df -i
$ df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
dev 999039 742 998297 1% /dev
run 1006468 1419 1005049 1% /run
/dev/dm-0 0 0 0 - /
tmpfs 1006468 181 1006287 1% /dev/shm
/dev/loop1 29 29 0 100% /var/lib/snapd/snap/bare/5
/dev/loop2 17275 17275 0 100% /var/lib/snapd/snap/snap-store/599
/dev/loop4 27806 27806 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
/dev/loop7 486 486 0 100% /var/lib/snapd/snap/snapd/16778
/dev/loop8 11882 11882 0 100% /var/lib/snapd/snap/core20/1623
/dev/loop5 10858 10858 0 100% /var/lib/snapd/snap/core18/2566
/dev/loop6 18121 18121 0 100% /var/lib/snapd/snap/gnome-3-38-2004/115
/dev/loop0 76208 76208 0 100% /var/lib/snapd/snap/gtk-common-themes/1535
tmpfs 1048576 82 1048494 1% /tmp
/dev/dm-0 0 0 0 - /var/log
/dev/dm-0 0 0 0 - /var/tmp
/dev/dm-0 0 0 0 - /srv
/dev/dm-0 0 0 0 - /var/cache
/dev/dm-0 0 0 0 - /home
/dev/dm-0 0 0 0 - /root
/dev/sda2 0 0 0 - /boot/efi
tmpfs 201293 6082 195211 4% /run/user/1000
/dev/dm-1 609600 269 609331 1% /run/media/cerulean/Docs
/dev/dm-2 20881408 246979 20634429 2% /run/media/cerulean/Var
/dev/dm-3 3055616 1335 3054281 1% /home/cerulean/Pictures
/dev/dm-4 18317312 198 18317114 1% /home/cerulean/Videos
I did go through the forums earlier discussions and ran the following -
# btrfs scrub start /
scrub started on /, fsid ec56f045-0b46-48cb-ad41-c68705366f20 (pid=29644)
and also
# btrfs balance /
Done, had to relocate 15 out of 15 chunks
and yet when I run
$ vivaldi-stable
[0926/130222.524285:ERROR:file_writer.cc(98)] writev: No space left on device (28)
[0926/130222.524311:ERROR:crash_report_exception_handler.cc(226)] WriteEverything failed
Am I running the btrfs balance wrong?
