inxi
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "pt_BR.UTF-8",
LC_NAME = "pt_BR.UTF-8",
LC_MONETARY = "pt_BR.UTF-8",
LC_PAPER = "pt_BR.UTF-8",
LC_IDENTIFICATION = "pt_BR.UTF-8",
LC_TELEPHONE = "pt_BR.UTF-8",
LC_MEASUREMENT = "pt_BR.UTF-8",
LC_TIME = "pt_BR.UTF-8",
LC_NUMERIC = "pt_BR.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.15.65-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=33da784c-6400-4145-99e3-93bc3c7463b2 rw rootflags=subvol=@
quiet
cryptdevice=UUID=5b16040e-5d39-4cd0-80b7-423ffe50eaff:luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
root=/dev/mapper/luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff splash
Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.5 info: cairo-dock, lxqt-panel
Type: Desktop Mobo: INTEL model: HM65DESK serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 02/23/2019
Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 built: 2010-12 process: Intel 32nm family: 6
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2187 high: 2660 min/max: 800/3400 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2289 2: 2660 3: 2107
4: 1694 bogomips: 21552
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
prctl and seccomp
Device-1: NVIDIA GM107 [GeForce GTX 750] driver: nvidia v: 515.65.01
alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-07) arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19
pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1381 class-ID: 0300
Screen-1: 0 s-res: 1360x768 s-dpi: 90 s-size: 384x300mm (15.12x11.81")
s-diag: 487mm (19.18")
Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 49
size: 708x398mm (27.87x15.67") diag: 812mm (31.98") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 750/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Sound Server-1: ALSA v: k5.15.65-1-lts running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Local Storage: total: 2.78 TiB used: 690.02 GiB (24.2%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter>
rev: Sb10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: G00A scheme: GPT
ID-1: / raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 143.05 GiB
(25.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%) used: 240.8
MiB (4.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 143.05
GiB (25.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 143.05
ID-5: /var/tmp raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 143.05
ID-1: swap-1 type: zram size: 3.79 GiB used: 286.5 MiB (7.4%)
System Temperatures: cpu: 43.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 234 Uptime: 36m wakeups: 0 Memory: 3.79 GiB used: 1.66 GiB
(43.7%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1793 pacman: 1762 lib: 545
flatpak: 31 Shell: Bash v: 5.1.16 running-in: qterminal inxi: 3.3.20
Garuda (2.6.6-2):
head: cannot open '/var/log/pacman.log' for reading: No such file or directory
System install date:
Last full system update: 2022-09-09
Failed units: shadow.service
Hi everyone o/ I'm having a little issue with Flatpak, it says it's out of space ¿ocasionally?
Apparently I can open 1 flatpak app per login session. If I try to run bottles, fine, it runs, but then if I try to run Dust3D:
flatpak run org.dust3d.dust3d
error: Failed to write file ?/run/user/1001/.flatpak/3157103008/info.YS9VR1?: write() failed: No space left on device
And so it's the opposite, it's not an app issue, it's a flatpak one. Doesn't seem to matter if the 1st app is open or not, I opened one app, the second won't run, regardless.
I tried searching online, I found a thread on fedora about this, but it was a BIOS issue IG, I didn't fully understand xD
I also found this on reddit
But then again, I have no clue about what
tmpfs 1048576 1048504 72 100% /home/mthw/.cache
even means, let alone do something about it.
So I'm here for any insights on the stuff, if anyone faced it before or anything, I'll be amazed to hear your thoughts.
Thanks in advance : 3
