Kernel: 5.19.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6306a748-317d-4387-82ba-4d6f6324a375 rw rootflags=subvol=@
quiet
cryptdevice=UUID=a957fc4a-48d0-46e2-9c94-1c152dc5ab76:luks-a957fc4a-48d0-46e2-9c94-1c152dc5ab76
root=/dev/mapper/luks-a957fc4a-48d0-46e2-9c94-1c152dc5ab76 splash
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Type: Laptop System: Micro-Star product: GL62M 7RD v: REV:1.0
serial: Chassis: type: 10 serial:
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial:
UEFI: American Megatrends v: E16J9IMS.324 date: 03/23/2018
ID-1: BAT1 charge: 26.8 Wh (94.4%) condition: 28.4/43.2 Wh (65.6%)
volts: 12.1 min: 10.8 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake
gen: core 7 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 9 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2907 high: 3660 min/max: 800/3800 scaling:
driver: intel_pstate governor: performance cores: 1: 2800 2: 3660 3: 2800
4: 2800 5: 2800 6: 2800 7: 2800 8: 2800 bogomips: 44798
vulnerable
PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915
active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:591b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0302
Device-3: Acer BisonCam NB Pro type: USB driver: uvcvideo bus-ID: 1-11:4
chip-ID: 5986:0683 class-ID: 0e02 serial:
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: i915
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x288mm (20.20x11.34")
s-diag: 588mm (23.16")
Monitor-1: eDP-1 mapped: eDP-1-1 model: ChiMei InnoLux 0x15d2 built: 2015
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
OpenGL: renderer: NVIDIA GeForce GTX 1050/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
Sound Server-1: ALSA v: k5.19.4-zen1-1-zen running: yes
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
IF: wlp2s0 state: up mac:
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 1969:10a1 class-ID: 0200
IF: enp3s0 state: down mac:
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-10:3 chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address:
Local Storage: total: 931.51 GiB used: 185.5 GiB (19.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: rev: A3U0
ID-1: / raw-size: 590.05 GiB size: 590.05 GiB (100.00%) used: 185.5 GiB
(31.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-a957fc4a-48d0-46e2-9c94-1c152dc5ab76
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%) used: 736 KiB
(0.1%) fs: vfat dev: /dev/sda3 maj-min: 8:3
ID-3: /home raw-size: 590.05 GiB size: 590.05 GiB (100.00%) used: 185.5
GiB (31.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
ID-4: /var/log raw-size: 590.05 GiB size: 590.05 GiB (100.00%) used: 185.5
ID-5: /var/tmp raw-size: 590.05 GiB size: 590.05 GiB (100.00%) used: 185.5
ID-1: swap-1 type: zram size: 7.68 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 47.0 C pch: 41.0 C mobo: N/A gpu: nvidia
temp: 39 C
Processes: 267 Uptime: 7m wakeups: 2 Memory: 7.68 GiB used: 3.96 GiB
(51.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pacman: 1905 lib: 352
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-04-12
Last full system update: 2022-08-29
Snapshots: Timeshift (maybe)
Issue -
Facing issues with Ferdi and Vivaldi after a system upgrade -
╰─λ ferdi
internal error, please report: running "ferdi" failed: cannot create transient scope: DBus error "org.freedesk
top.systemd1.NoSuchUnit": [Unit snap.ferdi.ferdi.2343f5b9-764e-41db-a3ef-074420a859ec.scope not found.]
] × vivaldi-stable
[0829/233841.123882:ERROR:file_writer.cc(98)] writev: No space left on device (28)
[0829/233841.123896:ERROR:crash_report_exception_handler.cc(226)] WriteEverything failed
fish: Job 1, 'vivaldi-stable' terminated by signal SIGTRAP (Trace or breakpoint trap)
Tried the installing uninstalling, removing configs etc etc. amd also --disable-gpu but the result is same.
Can someone please assist.
