Hello everyone,
I recently attempted to update my Garuda Linux system, but ran into dependency issues related to qemu-base and qemu-desktop. Specifically, I get a long list of broken dependencies when trying to update qemu-base to version 8.1.0-2.
╭─q42@q42 in ~
╰─λ garuda-update
[sudo] password for q42:
garuda is up to date
core is up to date
extra is up to date
multilib is up to date
chaotic-aur 2.6 MiB 4.29 MiB/s 00:01 [------------------------------------] 100%
garuda downloading...
core downloading...
extra downloading...
multilib downloading...
chaotic-aur downloading...
:: Replace exa with extra/eza? [Y/n] y
warning: qemu-base: ignoring package upgrade (8.0.4-2 => 8.1.0-2)
resolving dependencies...
warning: ignoring package qemu-base-8.1.0-2
warning: cannot resolve "qemu-base=8.1.0-2", a dependency of "qemu-desktop"
:: The following package cannot be upgraded due to unresolvable dependencies:
qemu-desktop
:: Do you want to skip the above package for this upgrade? [y/N] y
y
:: networkmanager-support and networkmanager-fortisslvpn are in conflict. Remove networkmanager-fortisslvpn? [y/N]
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
╭─q42@q42 in ~ as 🧙 took 56s
Here’s a snippet of the error message:
:: installing qemu-common (8.1.0-2) breaks dependency 'qemu-common=8.0.4-2' required by qemu-audio-alsa
:: installing qemu-common (8.1.0-2) breaks dependency 'qemu-common=8.0.4-2' required by qemu-audio-dbus
:: installing qemu-common (8.1.0-2) breaks dependency 'qemu-common=8.0.4-2' required by qemu-ui-spice-core
:: installing qemu-common (8.1.0-2) breaks dependency 'qemu-common=8.0.4-2' required by qemu-vhost-user-gpu
I’ve tried to manually update qemu-base using sudo pacman -S qemu-base, but it didn’t resolve the issue.
Has anyone else encountered this problem, and if so, how did you resolve it? Any guidance would be greatly appreciated.
Thank you!
Kernel: 6.4.11-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=eb3c6daf-a51b-40c6-b919-5d0844c5116b rw rootflags=subvol=@
resume=UUID=1232fa25-bece-4a36-a25f-220cc22e4c1a loglevel=3 apparmor=1
security=apparmor ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING II v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4901
date: 07/25/2022
Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3541 high: 3600 min/max: 2200/4467 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3500 2: 3598
3: 3500 4: 3500 5: 3500 6: 3500 7: 3500 8: 3599 9: 3598 10: 3599 11: 3600
12: 3500 bogomips: 83997
Device-1: AMD Tonga PRO [Radeon R9 285/380] vendor: PC Partner / Sapphire
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: DP-1,DVI-D-1 empty: DVI-D-2,HDMI-A-1 bus-ID: 07:00.0
chip-ID: 1002:6939 class-ID: 0300 temp: 64.0 C
Screen-1: 0 s-res: 4240x1622 s-dpi: 96 s-size: 1121x429mm (44.13x16.89")
s-diag: 1200mm (47.26")
Monitor-1: DVI-D-1 mapped: DVI-D-0 pos: bottom-l model: Acer AL2216W
serial: <filter> built: 2006 res: 1680x1050 hz: 60 dpi: 90 gamma: 1.2
size: 473x296mm (18.62x11.65") diag: 558mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
Monitor-2: DP-1 mapped: DisplayPort-0 pos: primary,top-right
model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 2560x1440
hz: 120 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x350
API: OpenGL v: 4.6 Mesa 23.1.6 renderer: AMD Radeon R9 380 Series (tonga
LLVM 15.0.7 DRM 3.52 6.4.11-zen2-1-zen) direct-render: Yes
Device-1: AMD Tonga HDMI Audio [Radeon R9 285/380]
vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:aad8 class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.4.11-zen2-1-zen status: kernel-api with: aoss
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 04:00.0
Local Storage: total: 945.98 GiB used: 251.96 GiB (26.6%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Kingston model: SNVS500G
lanes: 4 tech: SSD serial: <filter> fw-rev: S8542105 temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SNVS500G
lanes: 4 tech: SSD serial: <filter> fw-rev: S8H40104 temp: 41.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Verbatim model: STORE N GO
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 8.07 scheme: GPT
ID-1: / raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
used: 251.93 GiB (56.2%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:2
used: 25.9 MiB (8.7%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-4: /var/log raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.4 GiB size: 448.4 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.51 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3
System Temperatures: cpu: 65.0 C mobo: 52.0 C gpu: amdgpu temp: 64.0 C
Fan Speeds (rpm): cpu: 2033 case-1: 1138 case-2: 1138 case-3: 1081
gpu: amdgpu fan: 548
Power: 12v: 10.03 5v: N/A 3.3v: N/A vbat: 3.27 gpu: amdgpu watts: 52.14
Processes: 336 Uptime: 1h 1m wakeups: 0 Memory: total: 16 GiB
available: 15.52 GiB used: 3.83 GiB (24.7%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 2043
pm: pacman pkgs: 2039 libs: 563 tools: octopi,paru,yay pm: rpm pkgs: 0
pm: flatpak pkgs: 4 Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.29
System install date: 2023-05-14
Last full system update: 2023-08-23
