Hello Garuda users,
I just installed Garuda Soaring Qtile and I have a problem:
I can't mount my external USB drive, which is encrypted with LUKS and formatted in ext4.
It seems that Garuda does not even feel its presence. I love Garuda and I hope I can fix this. Thanks for any help
garuda-inxi output:
root=UUID=ac484dd4-c23e-4160-a4d3-a7117011b730 rw rootflags=subvol=@
quiet
cryptdevice=UUID=4cf849a1-409c-4eef-9eb0-bc91632db087:luks-4cf849a1-409c-4eef-9eb0-bc91632db087
root=/dev/mapper/luks-4cf849a1-409c-4eef-9eb0-bc91632db087 quiet splash
resume=/dev/mapper/luks-90df1fb2-b8c4-4c9e-831a-2a5a6b74fe00 loglevel=3
Desktop: Qtile v: 0.22.1 wm: LG3D vt: 1 dm: SDDM Distro: Garuda Linux
Type: Desktop System: LENOVO product: 90HU00FXIX v: ideacentre 510-15ICB
Mobo: LENOVO model: 36EB v: SDK0J40700 WIN 3258137300085
serial: <superuser required> UEFI-[Legacy]: LENOVO v: O3QKT34A
date: 04/29/2019
Info: model: Intel Core i5-9400 bits: 64 type: MCP arch: Coffee Lake
desc: 1x9 MiB
Speed (MHz): avg: 3806 high: 4005 min/max: 800/4100 scaling:
driver: intel_pstate governor: performance cores: 1: 4002 2: 4005 3: 3997
4: 2900 5: 3936 6: 4000 bogomips: 34798
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: none empty: DP-3,HDMI-A-2,HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0380
Device-2: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Bitland Information driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 ports: active: HDMI-A-1 empty: DP-1,DP-2
bus-ID: 01:00.0 chip-ID: 1002:699f class-ID: 0300 temp: 38.0 C
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-c4107
driver: X: loaded: amdgpu,modesetting alternate: fbdev,intel,vesa
dri: radeonsi,iris gpu: amdgpu display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: Samsung LF24T35
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
size: 528x297mm (20.79x11.69") diag: 606mm (23.9") ratio: 16:9 modes:
missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Lenovo driver: snd_hda_intel
Device-2: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: Bitland Information driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 01:00.1 chip-ID: 1002:aae0 class-ID: 0403
Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
vendor: Lenovo driver: rtw_8821ce v: N/A modules: rtw88_8821ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:c821
bus-ID: 1-14:5 chip-ID: 0bda:c024 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 931.51 GiB used: 13.77 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1SB102
type: HDD rpm: 7200 serial: <filter> rev: CC63 scheme: MBR
ID-1: / raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
used: 13.77 GiB (1.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-4cf849a1-409c-4eef-9eb0-bc91632db087
ID-2: /home raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-3: /var/log raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-4: /var/tmp raw-size: 922.71 GiB size: 922.71 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.63 GiB used: 28 MiB (0.4%) priority: 100
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-90df1fb2-b8c4-4c9e-831a-2a5a6b74fe00
System Temperatures: cpu: 35.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1998
Processes: 277 Uptime: 3h 48m wakeups: 0 Memory: 7.63 GiB
used: 2.77 GiB (36.4%) Init: systemd v: 253 default: graphical
pkgs: 1400 libs: 360 tools: octopi,pamac,paru Shell: fish v: 3.6.0
default: Bash v: 5.1.16 running-in: alacritty inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-02-25
Last full system update: 2023-02-25 ↻
I obtained this output with the external USB disk connected to the USB port
Thanks again for any help
