╰─λ sudo garuda-inxi
[sudo] password for dan:
Kernel: 5.16.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: PRIME X399-A v: Rev 1.xx
serial: <filter> UEFI: American Megatrends v: 1203 date: 10/09/2019
Info: model: AMD Ryzen Threadripper 2920X socket: SP3r2 bits: 64
type: MT MCP MCM arch: Zen+ family: 0x17 (23) model-id: 8 stepping: 2
microcode: 0x800820D
Topology: cpus: 1x cores: 6 tpc: 4 threads: 24 dies: 2 smt: enabled
cache: L1: 1.1 MiB desc: d-12x32 KiB; i-12x64 KiB L2: 6 MiB
desc: 12x512 KiB L3: 32 MiB desc: 4x8 MiB
Speed (MHz): avg: 3500 min/max: 2200/3500 boost: enabled
base/boost: 3500/4300 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3500 2: 3500 3: 3500 4: 3500
5: 3500 6: 3500 7: 3500 8: 3500 9: 3500 10: 3500 11: 3500 12: 3500
13: 3500 14: 3500 15: 3500 16: 3500 17: 3500 18: 3500 19: 3500 20: 3500
21: 3500 22: 3500 23: 3500 24: 3500 bogomips: 167665
Device-1: NVIDIA TU104 [GeForce RTX 2070 SUPER] vendor: Gigabyte
driver: nouveau v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max:
gen: 3 speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
bus-ID: 42:00.0 chip-ID: 10de:1e84 class-ID: 0300
Display: server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: nouveau
s-diag: 777mm (30.58")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: Samsung C27H71x
serial: <filter> built: 2017 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
max: 2560x1440 min: 720x400
OpenGL: renderer: NV164 v: 4.3 Mesa 21.3.7 direct render: Yes
Device-1: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0b:00.3
Device-2: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 42:00.1 chip-ID: 10de:10f8 class-ID: 0403
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 1000 bus-ID: 05:00.0
Device-2: Broadcom vendor: ASUSTeK driver: brcmfmac v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 14e4:43c3
IF: wlp6s0 state: up mac: <filter>
Local Storage: total: 3.64 TiB used: 862.35 GiB (23.1%)
ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: PNY model: CS3030 1000GB SSD
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: CS303224
temp: 28.9 C scheme: GPT
SMART: yes health: PASSED on: 1y 195d 2h cycles: 1,202
read-units: 20,574,202 [10.5 TB] written-units: 43,775,950 [22.4 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: PNY model: CS3030 1000GB SSD
SMART: yes health: PASSED on: 1y 194d 17h cycles: 1,202
read-units: 23,037,379 [11.7 TB] written-units: 23,048,000 [11.8 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 2TB
family: based SSDs size: 1.82 TiB block-size: physical: 512 B
logical: 512 B sata: 3.2 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 3B6Q temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 187d 6h cycles: 1137
written: 203.24 GiB
ID-1: / raw-size: 398.17 GiB size: 398.17 GiB (100.00%)
used: 20.61 GiB (5.2%) fs: btrfs block-size: 4096 B dev: /dev/sda1
maj-min: 8:1
used: 78 MiB (81.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p2
maj-min: 259:4
ID-3: /home raw-size: 398.17 GiB size: 398.17 GiB (100.00%)
maj-min: 8:1
ID-4: /var/log raw-size: 398.17 GiB size: 398.17 GiB (100.00%)
maj-min: 8:1
ID-5: /var/tmp raw-size: 398.17 GiB size: 398.17 GiB (100.00%)
maj-min: 8:1
ID-1: swap-1 type: zram size: 31.26 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 46.5 C mobo: N/A gpu: nouveau temp: 32.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 871
Processes: 502 Uptime: 1h 14m wakeups: 5 Memory: 31.26 GiB
used: 4.74 GiB (15.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1944 lib: 552 Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2022-03-23
Last full system update: 2022-03-26
Windows dual boot: Yes
I have an open question on Unix.SE but I'm not sure if it is some specific of the garuda setup that I am missing : grub - Adding a working boot option to get to my pacstrap/chroot install on a luks partition - Unix & Linux Stack Exchange
To be clear there is nothing wrong with my Garuda install - that's all good - Thank you for the distro!! I am simply hoping that knowledge of the Garuda implementation will help solve my issue.
From the link:
I know there are are a lot of questions like this but the examples I have found differ enough to confuse me, I'm hoping someone can help clarify this for me.
To briefly explain my setup. I have a windows 10 install and then on a different disk I have a garuda linux install. Both work fine but were set up for me by a the respective gui installers. I have now installed arch linux to separate partition (luks encrypted) from my garuda install (pacstrap) and would like to be able to boot into it. I can chroot into the install and have done bind mount for /dev /proc and /sys so I can see all devices and have successfully run an update and installed some bins.
disk/partition setup is as follows:
Windows disk and EFI:
Device Start End Sectors Size Type
/dev/nvme0n1p1 2048 1085439 1083392 529M Windows recovery environment
/dev/nvme0n1p2 1085440 1290239 204800 100M EFI System
/dev/nvme0n1p3 1290240 1323007 32768 16M Microsoft reserved
/dev/nvme0n1p4 1323008 519925759 518602752 247.3G Microsoft basic data
/dev/nvme0n1p5 519925760 1953523711 1433597952 683.6G Microsoft basic data
and then for linux:
/dev/sda1 2048 835028991 835026944 398.2G Linux filesystem (garuda)
/dev/sda2 835028992 1859028991 1024000000 488.3G Linux filesystem (arch -no boot)
sda1 & sda2 are both on btrfs partitions with luks encryption. However, I am not entirely clear how the garuda one was set up (gui installer). I am currently logged into garuda and have both drives unencrypted however I only see the dev/mapper for the device Im not booted into (dev/sda2) and that is the only one that show up with a luks map in lsblk:
✦ ╰─λ lsblk -o name,uuid,type
NAME UUID TYPE
sda disk
├─sda1 c42114f3-adea-4625-8ec7-1d9ef08c00d5 part
├─sda2 35308676-366b-495a-afd3-9c65701ec867 part
│ └─luks-35308676-366b-495a-afd3-9c65701ec867 fb72ec72-1352-4e5c-849d-a44c69ba4b16 crypt
The unencrypted device is mounted to /run/media/dan/nix_e1
with the arch install visible.
/boot
(garuda ) I have grub dir, kernels and the efi partition mounted to /efi :
✦ ╰─λ ls /boot
drwxr-xr-x - root 1 Jan 1970 efi
drwxr-xr-x - root 29 Mar 02:28 grub
drwxr-xr-x - root 8 Mar 05:09 memtest86+
.rw-r--r-- 51k root 11 Mar 19:21 amd-ucode.img
.rw------- 68M root 26 Mar 16:27 initramfs-linux-zen-fallback.img
.rw------- 43M root 26 Mar 16:27 initramfs-linux-zen.img
.rw-r--r-- 11M root 23 Mar 16:37 vmlinuz-linux-zen
/etc/fstab (garuda):
UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 / btrfs subvol=/@,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 /home btrfs subvol=/@home,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 /root btrfs subvol=/@root,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 /srv btrfs subvol=/@srv,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 /var/cache btrfs subvol=/@cache,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 /var/log btrfs subvol=/@log,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=c42114f3-adea-4625-8ec7-1d9ef08c00d5 /var/tmp btrfs subvol=/@tmp,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=C61E-FDE5 /boot/efi vfat defaults 0 1
I haven't mounted anything to /boot on the arch install yet, so it just has copies of the same kernels as garuda (also arch based) and I have created the efi directory ready for the mount. I have setup the fstab (though Im not entirely sure if I have used the correct uuid - will it see it with the crypt uuid or the part uuid?)
/etc/fstab (arch):
# <file system> <dir> <type> <options> <dump> <pass>
# /dev/mapper/luks-35308676-366b-495a-afd3-9c65701ec867 LABEL=nix_e1
UUID=fb72ec72-1352-4e5c-849d-a44c69ba4b16 / btrfs rw,nosuid,nodev,relatime,ssd,space_cache=v2,subvolid=5,subvol=/ 0 0
UUID=fb72ec72-1352-4e5c-849d-a44c69ba4b16 /home btrfs subvol=/@home,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=fb72ec72-1352-4e5c-849d-a44c69ba4b16 /root btrfs subvol=/@root,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=fb72ec72-1352-4e5c-849d-a44c69ba4b16 /srv btrfs subvol=/@srv,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=fb72ec72-1352-4e5c-849d-a44c69ba4b16 /var/cache btrfs subvol=/@cache,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=fb72ec72-1352-4e5c-849d-a44c69ba4b16 /var/log btrfs subvol=/@log,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
UUID=fb72ec72-1352-4e5c-849d-a44c69ba4b16 /var/tmp btrfs subvol=/@tmp,defaults,noatime,autodefrag,compress=zstd,discard=async,ssd 0 0
# /dev/zram0
/dev/zram0 none swap defaults,pri=100 0 0
Now this is the point where I get a little lost:
From reading I understand I need an initcpio hook, now I am guessing this is already in place for my garuda install. I can see grub-btrfs-overlayfs has been added to the hooks and it seems to have the crypt hook is part of the install... I'm assuming I dont need to do this on the arch partition as well unless I want to update grub from there too (saw some advice not to update grub from two installs).
I think next I need to run sudo mkinitcpio -p linux-zen
(not sure if I have missed some configuration step). However I have added this device to /etc/crypttab
and now it gets auto-mounted and unlocked when I enter the password once (which is the same for both partitions) - so at login to garuda both drives are unlocked... I think this suggests it is set up correctly.
Now some seem to suggest that a grub update should pick up the install at this point but it doesn't add a menu entry on update
So I have added a menu entry manually to grub:
/etc/grub.d/40_custom
menuentry "Arch" {
search --set=root --fs-uuid 35308676-366b-495a-afd3-9c65701ec867 linux-zen /boot/linux-zen root=UUID=35308676-366b-495a-afd3-9c65701ec867 rw quiet
Now I get an entry in my grub boot menu but on booting it says device 35308676-366b-495a-afd3-9c65701ec867 cannot be found, I have also tried with the uuid fb72ec72-1352-4e5c-849d-a44c69ba4b16 and got the same error.
I would appreciate if somebody could confirm what I have done so far is correct and point me in the right direction to get this working.
Thank you in advance.
