All issues related to Garuda Linux and its assistance
In order to my display work correctly, displayin RGB colors I need to load a custom edid.bin,
on every other distro all I need to do is create a folder and move the file there, then add to the default grub cmd linux line the following command: drm_kms_helper.edid_firmware=edid/edid.bin.
it works flawlessly on any other distro, or base such as arch or debian, but on garuda the edid simply seems not be loaded, why? what do I need to do for it to work?
there are no terminal inputs or outputs on my post.
Don't misunderstand, it's a standard request to give info to get better help, faster!
SGS
19 March 2021 19:50
5
yeah, the size of my edid.bin is correct, and the second one is related to nvidia issues, not my case
Exactly! And that’s the problem.
You have to post your system info, so we know how to give the proper advice.
inxi -Fxxxza
mhwd -li
bash -c 'for Xconf in $(ls /etc/X11/xorg.conf.d/*.conf | grep -v keyboard); do echo -e "\n" $Xconf ; cat $Xconf ; done'
bash -c 'for Xlog in $(ls /var/log/Xorg.?.log); do echo -e "\n" $Xlog ; grep -E "(EE)|(WW)|failed|Time" $Xlog ; done'
We may (or not) need more…
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=9b0a526a-a8a8-4a39-9f1f-6f2788a977bb
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop System: ASUS product: All Series v: N/A serial: <filter>
Mobo: ASUSTeK model: B85M-E/BR v: Rev X.0x serial: <filter> UEFI: American Megatrends v: 2110
date: 04/29/2016
CPU: Info: Quad Core model: Intel Core i5-4460 bits: 64 type: MCP arch: Haswell family: 6
model-id: 3C (60) stepping: 3 microcode: 28 L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 25543
Speed: 3194 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 3194 2: 3193 3: 3193 4: 3193
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] vendor: Sapphire Limited
driver: amdgpu v: kernel bus ID: 03:00.0 chip ID: 1002:731f class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 52 size: 930x523mm (36.6x20.6")
diag: 1067mm (42")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.40.0 5.11.7-zen1-1-zen LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8c20 class ID: 0403
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel bus ID: 03:00.1
chip ID: 1002:ab38 class ID: 0403
Sound Server: ALSA v: k5.11.7-zen1-1-zen
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK P8 series
driver: r8169 v: kernel port: d000 bus ID: 05:00.0 chip ID: 10ec:8168 class ID: 0200
Drives: Local Storage: total: 2.69 TiB used: 50.59 GiB (1.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510 size: 447.13 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: ECFM12.3 temp: 35.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000LM007-1R8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter>
rev: ACM1 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SV300S37A240G size: 223.57 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: BBF0
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: SA400S37240G size: 223.57 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: B1E1
Partition: ID-1: / raw size: 97.66 GiB size: 97.66 GiB (100.00%) used: 50.59 GiB (51.8%) fs: btrfs
dev: /dev/sdc2 maj-min: 8:34
ID-2: /boot/efi raw size: 201 MiB size: 197.9 MiB (98.45%) used: 546 KiB (0.3%) fs: vfat
dev: /dev/sdc1 maj-min: 8:33
ID-3: /home raw size: 97.66 GiB size: 97.66 GiB (100.00%) used: 50.59 GiB (51.8%) fs: btrfs
ID-4: /var/log raw size: 97.66 GiB size: 97.66 GiB (100.00%) used: 50.59 GiB (51.8%) fs: btrfs
ID-5: /var/tmp raw size: 97.66 GiB size: 97.66 GiB (100.00%) used: 50.59 GiB (51.8%) fs: btrfs
ID-1: swap-1 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.92 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: partition size: 14.9 GiB used: 0 KiB (0.0%) priority: 1024
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 42.0 C mem: 44.0 C
Info: Processes: 227 Uptime: 11m wakeups: 0 Memory: 7.67 GiB used: 2.95 GiB (38.5%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1876 lib: 554 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.3.01
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2021.02.19 true PCI
Warning: No installed USB configs!
/var/log/Xorg.0.log
[ 5.106] Current Operating System: Linux riox-garuda 5.11.7-zen1-1-zen #1 ZEN SMP PREEMPT Wed, 17 Mar 2021
16:59:53 +0000 x86_64
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 5.106] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Mar 19 17:01:01 2021
[ 5.112] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5.112] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5.112] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 5.112] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 5.124] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 5.164] (WW) Warning, couldn't open module fbdev
[ 5.164] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 5.164] (WW) Warning, couldn't open module vesa
[ 5.164] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 5.172] (WW) Falling back to old probe method for modesetting
[ 6.645] (II) Initializing extension MIT-SCREEN-SAVER
[ 19.623] (EE) event10 - USB Gaming Mouse: client bug: event processing lagging behind by 16ms, your system
is too slow
there you go
Is this folder/file /lib/firmware/edid/edid.bin ?
Post full Xorg log to bin.garudalinux.org and post link.
/var/log/Xorg.0.log
Also post
journalctl -b -g "edid" --no-hostname --no-pager
This has changed for newer kernels .
Use drm.edid_firmware=edid/edid.bin
yes, that's the folder/file.
λ /var/log/Xorg.0.log
fish: The file “/var/log/Xorg.0.log” is not executable by this user
root@riox in /run/media/riox/Games/backup/edid
[đźš«] Ă— sudo /var/log/Xorg.0.log
sudo: /var/log/Xorg.0.log: command not found
and
riox@riox in ~ took 2s
[đź”´] Ă— sudo journalctl -b -g "edid" --no-hostname --no-pager
-- Journal begins at Fri 2021-03-19 14:12:20 -03, ends at Fri 2021-03-19 17:41:16 -03. --
mar 19 17:40:23 kded5[2658]: Found EDID profile for device "/org/freedesktop/ColorManager/profiles/icc_255fc40e6c28ec974fe1ce0d8ff2a04c_riox_1000" "HDMI-A-0"
mar 19 17:40:23 kded5[2658]: Default Profile Filename "/home/riox/.local/share/icc/edid-c400a85b95d39f365797b16ad709b62f.icc"
mar 19 17:40:23 kded5[2658]: EDID ICC Profile already exists "/home/riox/.local/share/icc/edid-c400a85b95d39f365797b16ad709b62f.icc"
mar 19 17:41:16 dbus-daemon[433]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.79' (uid=0 pid=5959 comm="sudo journalctl -b -g edid --no-hostname --no-page")
mar 19 17:41:16 sudo[5959]: riox : TTY=pts/1 ; PWD=/home/riox ; USER=root ; COMMAND=/usr/bin/journalctl -b-g edid --no-hostname --no-pager
tried that, still doesn't load
rioxrenato:
Really? Oh, where am I pulled in…
That was the file path/name , not a command.
Open the file in kate, select all and copy.
Go to the posted link (bin.garuda…) and paste contents. After Save/Apply, post the address/link of the page.
rioxrenato:
tried that,
What? Use many words please. Help others understand clearly.
Post
grep -i '^Modules\|^file' /etc/mkinitcpio.conf
╰─λ grep -i '^Modules\|^file' /etc/mkinitcpio.conf
MODULES=(intel_agp i915 amdgpu radeon nouveau)
FILES=""
I tried using the line that you mentioned instead of the one that I was using, since you said that on newer kernels it has changed, still didn't get the edid to load
instead of:
here is the grub config file
https://bin.garudalinux.org/?57269f15be6cdd10#HEPgvcvyWGyuDUuyAzVD8LgktkRB4e9tAqaiEnL6zBJS
and here is the edid.bin
riox@riox in /lib/firmware/edidđź”’
╰─λ ls
.rwxrwxrwx 256 riox 4 jan 1:38 ď…› edid.bin
SGS
19 March 2021 21:13
18
By the way @rioxrenato , I hope you understand why certain things can't be solved in telegram as well.
Short terminal output you can post here.
# GRUB boot loader configuration
GRUB_DEFAULT=0
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="Garuda"
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash drm.edid_firmware rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 drm.edid_firmware=edid/edid.bin"
GRUB_CMDLINE_LINUX=""
# Preload both GPT and MBR modules so that they are not missed
GRUB_PRELOAD_MODULES="part_gpt part_msdos"
# Uncomment to enable booting from LUKS encrypted devices
#GRUB_ENABLE_CRYPTODISK="y"
# Set to 'countdown' or 'hidden' to change timeout behavior,
# press ESC key to display menu.
GRUB_TIMEOUT=5
# Uncomment to use basic console
GRUB_TERMINAL_INPUT="console"
# Uncomment to disable graphical terminal
#GRUB_TERMINAL_OUTPUT="console"
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
GRUB_GFXMODE="auto"
# Uncomment to allow the kernel use the same resolution used by grub
GRUB_GFXPAYLOAD_LINUX="keep"
# Uncomment if you want GRUB to pass to the Linux kernel the old parameter
# format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
#GRUB_DISABLE_LINUX_UUID="true"
# Uncomment to disable generation of recovery mode menu entries
GRUB_DISABLE_RECOVERY="true"
# Uncomment and set to the desired menu colors. Used by normal and wallpaper
# modes only. Entries specified as foreground/background.
#GRUB_COLOR_NORMAL="light-blue/black"
#GRUB_COLOR_HIGHLIGHT="light-cyan/blue"
# Uncomment one of them for the gfx desired, a image background or a gfxtheme
#GRUB_BACKGROUND="/path/to/wallpaper"
GRUB_THEME="/usr/share/grub/themes/garuda/theme.txt"
# Uncomment to get a beep at GRUB start
#GRUB_INIT_TUNE="480 440 1"
# Uncomment to make GRUB remember the last selection. This requires
GRUB_DEFAULT=0
#GRUB_SAVEDEFAULT="true"
# Uncomment to disable submenus in boot menu
#GRUB_DISABLE_SUBMENU="y"
And posterity can also find solutions more easily here.
I understand that, but I asked there first to see if there was an easy fix
There is NO clue that your EDID is NOT loaded .
Maybe it's time to use a lot of words (iiiiffff possible...) to describe what do you mean EDID is not loaded .
It looks like an xyproblem .
