Hello everyone,
I am trying to setup my computer as headless server with cinnamon GUI
(sometimes I am unable to achieve what I need with just SSH connection, still new to linux).
I am using NoMachine to connect to the server via my pc or smartphone.
Only problem is that NoMachine headless connection will give me only 640x480 resolution with no way to change it.
That is why I grabbed edid.bin file from nvidia X server app and tried to apply it.
So far went with this thread without any luck.
Also I read the official Arch wiki page on kernel mode setting - section Forcing modes and EDID
and searched for any error in the parameters I wrote.. also with no luck.
I did basically the same thing in debian 11 so I know it can be done.
Can anyone help me with this problem or have any tips how to do it correctly?
Thanx for any answers in advance.
System info:
Kernel: 5.16.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6d28826f-49cf-4936-a543-f386235f0801 rw [email protected]
quiet splash drm.edid_firmware rd.udev.log_priority=3
vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1
drm.edid_firmware=edid/edid.bin
Desktop: Cinnamon 5.2.7 tk: GTK 3.24.31 wm: muffin vt: 7
dm: LightDM 1.30.0 Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: Gigabyte model: H410M S2H v: x.x
serial: <superuser required> BIOS: American Megatrends v: F5
date: 04/19/2021
Info: model: Intel Core i3-10100F bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 3 microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 4039 high: 4275 min/max: 800/4300 scaling:
driver: intel_pstate governor: performance cores: 1: 3530 2: 4275 3: 4202
4: 4201 5: 4196 6: 3456 7: 4209 8: 4247 bogomips: 57600
Device-1: NVIDIA GM206 [GeForce GTX 950] vendor: ASUSTeK driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1402 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 driver: loaded: nvidia
unloaded: modesetting alternate: fbdev,nouveau,nv,vesa display-ID: :0
Screen-1: 0 s-res: 640x480 s-dpi: 75 s-size: 217x163mm (8.5x6.4")
s-diag: 271mm (10.7")
Device-1: Intel Comet Lake PCH-V cAVS vendor: Gigabyte
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fba
Sound Server-1: ALSA v: k5.16.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.44 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 2.04 TiB used: 32.13 GiB (1.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX001-1NS164
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC41
ID-2: /dev/sdb maj-min: 8:16 vendor: Patriot model: Burst
size: 223.57 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: KB.3 scheme: MBR
ID-1: / raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
used: 10.21 GiB (4.6%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-3: /var/log raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-4: /var/tmp raw-size: 223.57 GiB size: 223.57 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.56 GiB used: 1.8 MiB (0.0%)
System Temperatures: cpu: 16.8 C mobo: 16.8 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 31%
Processes: 285 Uptime: 9m wakeups: 0 Memory: 15.56 GiB
used: 2.04 GiB (13.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1341 lib: 293 Shell: Zsh
v: 5.8 running-in: gnome-terminal inxi: 3.3.12
Garuda (2.5.3-1):
System install date: 2022-01-31
Last full system update: 2022-02-01
Snapshots: Snapper (maybe)
