Hello, i got some problems with my audio. Could somebody help me please?
My Speaker is actually working fine, getting the "pop" Sound (notification) when I change the Volume. But on every program (Chrome, Spotify, etc) i dont get any sounds.
Please post the terminal input and output as text (no pictures) from the the following command:
Included within ~~~ , i.e.:
output of garuda-inxi
╰─λ garuda-inxi
Kernel: 5.18.14-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=b86b0eb5-b046-4c42-9a52-a715861644e5 rw [email protected]
resume=UUID=59c97136-cf5e-446a-9e16-b0577d2ab215 loglevel=3
Desktop: KDE Plasma v: 5.25.3 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: ASUSTeK product: ZenBook UX425JA_UX425JA v: 1.0
Mobo: ASUSTeK model: UX425JA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: UX425JA.306 date: 12/31/2020
ID-1: BAT0 charge: 46.8 Wh (69.5%) condition: 67.3/67.1 Wh (100.3%)
volts: 15.9 min: 15.9 model: ASUSTeK UX425 type: Li-ion serial: <filter>
status: discharging cycles: 30
Info: model: Intel Core i5-1035G1 bits: 64 type: MT MCP arch: Ice Lake
built: 2019-21 process: Intel 10nm family: 6 model-id: 0x7E (126)
stepping: 5 microcode: 0xB0
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1126 high: 1219 min/max: 400/3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 1219 2: 1084 3: 1198
4: 1015 5: 1200 6: 1146 7: 1084 8: 1068 bogomips: 19046
Device-1: Intel Iris Plus Graphics G1 vendor: ASUSTeK driver: i915
v: kernel arch: Gen11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:8a56 class-ID: 0300
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-6:2 chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 model: AU Optronics 0xa48f built: 2020 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (ICL GT1) v: 4.6 Mesa 22.1.4
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
Sound Server-1: ALSA v: k5.18.14-zen1-1-zen running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
v: 3.0 port: 3060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 504.19 GiB used: 19.67 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: HBRPEKNX0202A
speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter> rev: G002
temp: 30.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Intel model: HBRPEKNX0202AO
size: 27.25 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 type: SSD serial: <filter> rev: K5110440 temp: 42.9 C
ID-1: / raw-size: 459.81 GiB size: 459.81 GiB (100.00%)
used: 19.67 GiB (4.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.81 GiB size: 459.81 GiB (100.00%)
ID-4: /var/log raw-size: 459.81 GiB size: 459.81 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.81 GiB size: 459.81 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.3 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.83 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 292 Uptime: 23m wakeups: 1736 Memory: 15.3 GiB
used: 4.46 GiB (29.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1350 lib: 349
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.5-1):
System install date: 2022-07-22
Last full system update: 2022-07-28
I also never had this problem before, all worked fine. I just went 3 minutes away of my laptop and it didnt work
Did it just happen or you've already rebooted?
I'm asking this because I remember issues linked to audio after suspend/resume.
Rather than rebooting, try a:
systemctl --user restart pipewire pipewire-pulse
systemctl --user daemon-reload
It just happened, then I rebooted because I thought it might fix that.
Should I still try your commands?
No, if the issue persists after reboot that won't help probably...
Actually it worked! Thank you
Do you know or have any idea why the sound system "crashed"?
Never say never
Not really, the first hit of a forum search (in relation to sleep/suspend, that was my idea) was
but I didn't even have the time to read it. Go for it
I'd have given a look also here (maybe just the troubleshooting section):
https://wiki.archlinux.org/title/PipeWire
You might start working on the logs, i.e. journal.
Just see if the problem occurs again. It might be a long (but interesting) journey to find the root cause.
Sure, thanks for your help & time!
Have a good Day
