Hi,
after i wake my laptop from suspend or sleep state my audio drivers aren't working. I have to manually reset my audio driver every time.
I use this command
systemctl --user restart pipewire pipewire-pulse
systemctl --user daemon-reload
I am looking for more of a permanent solution and automatic one.
My system info
pipewire: 0.3.40
Gnome version: 41.2
kernal version: 5.15.7.hardened1-1
cpu: ryzen 4600h
gpu: nvidia 1660ti mobile
PS. I posted it here because i am not sure if it's related to gnome or garuda.
inxi -Faz
System: Kernel: 5.15.6-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2cb817f1-62dd-48cc-b94b-84c237d9c509 rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=a78efde3-a998-44ee-bd36-e7f1a08d17a2 loglevel=3
Desktop: GNOME 41.1 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 41.0 Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: HP product: OMEN Laptop 15-en0xxx v: N/A serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8786 v: 22.58 serial: <superuser required> UEFI: AMI v: F.13 date: 03/04/2021
Battery: ID-1: BAT0 charge: 59.1 Wh (92.9%) condition: 63.6/63.6 Wh (100.0%) volts: 12.4 min: 11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Discharging cycles: 572
CPU: Info: 6-Core model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600106 cache: L1: 384 KiB L2: 3 MiB L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 71868
Speed: 1521 MHz min/max: 1400/3000 MHz boost: enabled Core speeds (MHz): 1: 1484 2: 1519 3: 1595 4: 1805 5: 2178
6: 2244 7: 2041 8: 2074 9: 1965 10: 1383 11: 1832 12: 2270
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Hewlett-Packard driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 06:00.0
Device-3: Luxvisions Innotech Limited HP Wide Vision HD Camera type: USB driver: uvcvideo bus-ID: 3-3:3
chip-ID: 30c9:000e class-ID: 0e02
Display: x11 server: X.Org 1.21.1.1 compositor: gnome-shell driver: loaded: modesetting,nvidia display-ID: :1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3") s-diag: 1055mm (41.6")
Monitor-2: HDMI-1-0 res: 1920x1080 hz: 144 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
Audio: Device-1: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x bus-ID: 06:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.6-zen2-1-zen running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:5 chip-ID: 8087:0029 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block: hardware: no software: yes
address: <filter>
Drives: Local Storage: total: 476.94 GiB used: 337.82 GiB (70.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000H1 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: HPS0NEXF temp: 38.9 C
Partition: ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 16.77 GiB (55.9%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-2: /boot/efi raw-size: 501 MiB size: 500 MiB (99.80%) used: 576 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p7
maj-min: 259:7
ID-3: /home raw-size: 80.95 GiB size: 80.95 GiB (100.00%) used: 32.22 GiB (39.8%) fs: btrfs dev: /dev/nvme0n1p8
maj-min: 259:8
ID-4: /var/log raw-size: 30 GiB size: 30 GiB (100.00%) used: 16.77 GiB (55.9%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-5: /var/tmp raw-size: 30 GiB size: 30 GiB (100.00%) used: 16.77 GiB (55.9%) fs: btrfs dev: /dev/nvme0n1p5
maj-min: 259:5
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: swap-2 type: zram size: 15.06 GiB used: 1.81 GiB (12.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 47.0 C mobo: N/A gpu: amdgpu temp: 45.0 C
Info: Processes: 417 Uptime: 11h 52m wakeups: 1 Memory: 15.06 GiB used: 10.35 GiB (68.7%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1227 lib: 346 Shell: fish v: 3.3.1
default: Bash v: 5.1.12 running-in: gnome-terminal inxi: 3.3.09
