Audio from other programs don't come but kde sound effects do
Hello Garuda users.
Whenever I log in, I don't get any audio from my applications. I searched around and found this forum post.
with the following snippet:
systemctl --user restart pipewire pipewire-pulse
systemctl --user daemon-reload
This snippet gets me back my audio but I don't want to do that every time, How do I fix it completely?
garuda-inxi:
  Kernel: 6.2.9-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=e01c77a9-8744-4c85-afee-cef1f429bd62 rw rootflags=subvol=@
    resume=UUID=f9b0b8af-d574-4661-a0d5-4e2a9f483bd3 loglevel=3 ibt=off
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME A320M-K v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 5220
    date: 09/12/2019
  Info: model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64 type: MCP
    arch: Zen/Zen+ note: check gen: 1 level: v3 note: check built: 2019
    process: GF 12nm family: 0x17 (23) model-id: 0x18 (24) stepping: 1
    microcode: 0x8108109
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
    desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 2538 high: 2954 min/max: 1400/3600 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2140 2: 2954
    3: 2951 4: 2108 bogomips: 28745
    ports: active: HDMI-A-1 empty: DP-1 bus-ID: 07:00.0 chip-ID: 1002:15d8
    class-ID: 0300 temp: 40.0 C
  Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) FULL HD
    serial: <filter> built: 2016 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
    size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
  API: OpenGL v: 4.6 Mesa 23.0.1 renderer: AMD Radeon Vega 8 Graphics
    (raven LLVM 15.0.7 DRM 3.49 6.2.9-zen1-1-zen) direct-render: Yes
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
    vendor: ASUSTeK PRIME B450M-A driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK PRIME B450M-A
    bus-ID: 07:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.2.9-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 0.3.67 status: active with: 1: pipewire-pulse
    speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
  Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
    driver: r8188eu bus-ID: 3-8:3 chip-ID: 0bda:8179 class-ID: 0000
  IF: wlp1s0f0u8 state: up mac: <filter>
    driver: btusb v: 0.8 bus-ID: 3-3:2 chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 1.93 TiB used: 845.93 GiB (42.8%)
    model: WD20EZAZ-00GGJB0 size: 1.82 TiB block-size: physical: 4096 B
    rev: 0A80 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: A-Data model: SU650 size: 111.79 GiB
    serial: <filter> rev: 831a scheme: GPT
  ID-1: / raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
    used: 47.9 GiB (46.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
    used: 608 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-4: /var/log raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-5: /var/tmp raw-size: 102.69 GiB size: 102.69 GiB (100.00%)
  ID-1: swap-1 type: zram size: 5.72 GiB used: 7 MiB (0.1%) priority: 100
    dev: /dev/sdb3 maj-min: 8:19
  System Temperatures: cpu: 40.9 C mobo: N/A gpu: amdgpu temp: 40.0 C
  Processes: 256 Uptime: 19m wakeups: 0 Memory: 5.72 GiB
  used: 2.92 GiB (51.0%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1713
  pm: pacman pkgs: 1707 libs: 382 tools: paru pm: flatpak pkgs: 6 Shell: fish
  v: 3.6.1 running-in: kitty inxi: 3.3.26
  System install date:     2023-01-09
  Last full system update: 2023-04-07
  Failed units:            mnt-volume1.mount shadow.service
Share the journal log just after you get the error with your audio. journalctl -rn 500 |tb would give you an URL, share it.
https://termbin.com/0tp4
here it is, I think I found relevant portion of the log.
Apr 08 12:39:15 garuda systemd[1]: user@965.service: Consumed 1.171s CPU time.
Apr 08 12:39:15 garuda systemd[1]: Stopping User Runtime Directory /run/user/965...
Apr 08 12:39:15 garuda systemd[1]: run-user-965.mount: Deactivated successfully.
Apr 08 12:39:15 garuda systemd[1]: user-runtime-dir@965.service: Deactivated successfully.
Apr 08 12:39:15 garuda systemd[1]: Stopped User Runtime Directory /run/user/965.
Apr 08 12:39:15 garuda systemd[1]: Removed slice User Slice of UID 965.
Apr 08 12:39:15 garuda systemd[1]: user-965.slice: Consumed 1.691s CPU time.
Apr 08 12:39:15 garuda systemd[30387]: Reached target Bluetooth.
Apr 08 12:39:16 garuda wireplumber[30677]: RFCOMM receive command but modem not available: AT+NREC=0
Apr 08 12:39:16 garuda bluetoothd[430]: profiles/audio/avctp.c:avctp_control_confirm() Control: Refusing unexpected connect
Apr 08 12:39:16 garuda wireplumber[30677]: Failed to register battery provider. Error: org.freedesktop.DBus.Error.UnknownMethod
Apr 08 12:39:16 garuda wireplumber[30677]: BlueZ Battery Provider is not available, won't retry to register it. Make sure you are running BlueZ 5.56+ with experimental features to use Battery Provider.
Apr 08 12:39:18 garuda kernel: input: Rockerz 450 (AVRCP) as /devices/virtual/input/input21
Apr 08 12:39:18 garuda systemd-logind[439]: Watching system buttons on /dev/input/event13 (Rockerz 450 (AVRCP))
Apr 08 12:39:19 garuda jamesdsp[30631]: [12:39:19.383] [DBG] PwPipelineManager: Audio/Sink 57 bluez_output.11_11_22_35_3B_E4.1 was added
Apr 08 12:39:19 garuda plasmashell[30524]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_07_00.6.analog-stereo.monitor"
Apr 08 12:39:19 garuda jamesdsp[30631]: [12:39:19.399] [DBG] PwPipelineManager: new metadata property: 0, default.audio.sink, Spa:String:JSON, {"name":"bluez_output.11_11_22_35_3B_E4.1"}
Apr 08 12:39:19 garuda jamesdsp[30631]: [12:39:19.400] [DBG] PwPipelineManager: new metadata property: 0, default.audio.source, Spa:String:JSON, {"name":"bluez_output.11_11_22_35_3B_E4.1"}
Apr 08 12:39:19 garuda jamesdsp[30631]: [12:39:19.400] [DBG] PipewireAudioService: new default output device: bluez_output.11_11_22_35_3B_E4.1
Apr 08 12:39:19 garuda plasmashell[30524]: org.kde.plasma.pulseaudio: No object for name "bluez_output.11_11_22_35_3B_E4.1.monitor"
Apr 08 12:39:19 garuda systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.```
sudo pacman -Rns jamesdsp
...would be a good start.
Done, now what?
It fixed itself, thanks!
