Hello everyone, after updating the system (2022-08-19) , there was a problem with the sound when turned on, I'll try to attach a video.
After starting the system, the application that initializes the sound makes an incomprehensible noise (duration up to 1 second)
video of problem Audio problem Garuda Linux - YouTube .
On the video i just click on the sound icon and I hear this sound.
The same happened if i start google chrome and go to youtube, only in first initialization of sound i always hearing something like this.
I am found on the forum Topic with Audio (Audio Problems ) and tryed do the same, but no results.
How it is possible to solve it? thanks in advance)
My inxi:
╭─greg@levc in ~
╰─λ garuda-inxi
Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
root=UUID=0faf27b9-047d-4003-b67d-2b431e93daf8 rw rootflags=subvol=@
Type: Desktop Mobo: Micro-Star model: B450M PRO-M2 MAX (MS-7B84) v: 2.0
serial: <superuser required> UEFI: American Megatrends v: A.70
date: 06/10/2020
Info: model: AMD Ryzen 5 3500X bits: 64 type: MCP arch: Zen 2 gen: 3
built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 32 MiB
desc: 2x16 MiB
Speed (MHz): avg: 2524 high: 3603 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3603 2: 2056
3: 2890 4: 2199 5: 2200 6: 2200 bogomips: 43199
Type: retbleed mitigation: untrained return thunk; SMT disabled
disabled, RSB filling
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2,
DVI-D-1, HDMI-A-2 bus-ID: 29:00.0 chip-ID: 1002:67df class-ID: 0300
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) FULL HD
serial: <filter> built: 2016 res: 1920x1080 hz: 75 dpi: 102 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
OpenGL: renderer: AMD Radeon RX 580 Series (polaris10 LLVM 14.0.6 DRM
3.46 5.18.16-zen1-1-zen) v: 4.6 Mesa 22.1.4 direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 29:00.1 chip-ID: 1002:aaf0 class-ID: 0403
bus-ID: 2b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 912.89 GiB used: 244.32 GiB (26.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 447.13 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM22.6
temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD105
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: A8R0
ID-1: / raw-size: 191.88 GiB size: 191.88 GiB (100.00%) used: 26.07 GiB
(13.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 311.8 MiB size: 311.2 MiB (99.80%) used: 608
KiB (0.2%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-3: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 218.25
GiB (46.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 191.88 GiB size: 191.88 GiB (100.00%) used: 26.07
GiB (13.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 191.88 GiB size: 191.88 GiB (100.00%) used: 26.07
ID-1: swap-1 type: zram size: 15.57 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 55.8 C mobo: N/A gpu: amdgpu temp: 48.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 229
Processes: 285 Uptime: 12m wakeups: 0 Memory: 15.57 GiB used: 2.31 GiB
(14.8%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1525 lib: 479 Shell: fish v: 3.5.1
Garuda (2.6.5-1):
System install date: 2022-06-20
Last full system update: 2022-08-19
filo
August 20, 2022, 7:51am
2
Your
is not consistent with
(should be 5.19)
Have you restored a snapshot?
If not, maybe you could try to
garuda-update
again…
Yes, the first time I restored the snapshot. There were no problems with sound on the old version of garuda) Then I updated again.
filo:
(should be 5.19)
It is possible that after full update kernel was not updated ? )
Just now i started garuda-update, here is my new inxi
╭─greg@levc in ~
╰─λ garuda-inxi
Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
date: 06/10/2020
desc: 2x16 MiB
Speed (MHz): avg: 2492 high: 3943 min/max: 2200/4120 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2267 2: 2198
3: 2200 4: 2199 5: 2146 6: 3943 bogomips: 43200
3.47 5.19.2-zen1-1-zen) v: 4.6 Mesa 22.1.6 direct render: Yes
Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
Local Storage: total: 912.89 GiB used: 249.44 GiB (27.3%)
temp: 46.9 C scheme: GPT
ID-1: / raw-size: 191.88 GiB size: 191.88 GiB (100.00%) used: 31.15 GiB
(16.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 218.29
ID-4: /var/log raw-size: 191.88 GiB size: 191.88 GiB (100.00%) used: 31.15
GiB (16.2%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/tmp raw-size: 191.88 GiB size: 191.88 GiB (100.00%) used: 31.15
System Temperatures: cpu: 57.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 250
Processes: 286 Uptime: 1m wakeups: 0 Memory: 15.57 GiB used: 1.61 GiB
(10.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.1 Packages: pacman: 1547 lib: 480 Shell: fish v: 3.5.1
Garuda (2.6.6-1):
Last full system update: 2022-08-20
filo
August 20, 2022, 8:36am
4
This is unlikely to happen, the update process would stop.
Before rebooting after kernel upgrade, inxi shows the old kernel, but in that case you can see the ↻ symbol after the last full upgrade date. Strange.
Have you tried to switch to the linux-lts kernel now, with fully updated system, to see if you have better luck?
after full update garuda problem was not solved, my kernel now - (Kernel: 5.19.2-zen1-1-zen)
i did some tests,theese artifacts with sound also has in livecd with (5.18.16-zen1-1-zen), when i startup from flash, before install new system.
Just now tryed linux-lts kernel , on this kernel no any problems with sound. Thank you )
Probably on my configuration of PC something wrong with zen kernel, also i install garuda on laptop and make fully upgrade, no any problems on zen kernel on my laptop
system
Closed
August 23, 2022, 1:34pm
8
