Attempting reloading deprecated 32 bit lib environments in 64 bit OS
Hello.
sudo apt-get curl libfltk1.3-dev portaudio19-dev libopus-dev libmp3lame-dev libvorbis-dev libogg-dev libflac-dev libfdk-aac-dev libdbus-1-dev libsamplerate0-dev libssl-dev
((RETURNS ARGUMENT)) —> sudo: apt-get: command not found - So this is a continued attempt to install missing 32 bit libs that are critical for proper functionality of various music programs such as specifically “Vivox” microphone/voice chat, video and live streaming “BUTT” - streaming tool/app butt (broadcast using this tool) download | SourceForge.net that are all necessary for www.secondlife.com & firestorm viewer https://wiki.firestormviewer.org/fs_voice that is used to access SL and other virtual world “games” that i and others use to play live music, DJ and in my case original instrumental guitar music… Thank you again, Namaste @TNE
pacman/Rosetta - ArchWiki thank you for the additional very helpful link @BluishHumility i am very new to Arch environment came from years of fails with complications of Debian/Mint/Ubuntu specifically so i have alot more to learn!
Kernel: 5.17.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=ffd2cbda-1b3f-469b-b162-600ad680d696 rw rootflags=subvol=@
Mobo: ASUSTeK model: ROG STRIX B550-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 2423
date: 08/10/2021
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Device-2: hidpp_battery_0
model: Logitech Marathon Mouse/Performance Plus M705 serial: <filter>
Info: model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 family: 0x19 (25) model-id: 0x50 (80) stepping: 0
microcode: 0xA50000C
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2529 high: 2994 min/max: 1400/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2392 2: 2393
3: 2988 4: 2392 5: 2994 6: 2391 7: 2393 8: 2395 9: 2394 10: 2395 11: 2772
12: 2395 13: 2994 14: 2395 15: 2393 16: 2389 bogomips: 121368
STIBP: always-on, RSB filling
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: eVga.com. driver: nvidia
v: 470.103.01 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 4 link-max: lanes: 16 bus-ID: 03:00.0 chip-ID: 10de:1401
Device-2: AMD Cezanne vendor: ASUSTeK driver: N/A alternate: amdgpu pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 08:00.0 chip-ID: 1002:1638 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 3840x1080 s-dpi: 93 s-size: 1049x292mm (41.30x11.50")
s-diag: 1089mm (42.87")
Monitor-1: DVI-I-0 pos: primary,right res: 1920x1080 hz: 60 dpi: 94
size: 521x293mm (20.51x11.54") diag: 598mm (23.53") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 1920x1080 hz: 60 dpi: 305
size: 160x90mm (6.3x3.54") diag: 184mm (7.23") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2
v: 4.6.0 NVIDIA 470.103.01 direct render: Yes
Device-1: NVIDIA GM206 High Definition Audio vendor: eVga.com.
link-max: lanes: 16 bus-ID: 03:00.1 chip-ID: 10de:0fba class-ID: 0403
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.1 chip-ID: 1002:1637
link-max: gen: 4 speed: 16 GT/s bus-ID: 08:00.6 chip-ID: 1022:15e3
Device-4: Arturia AudioFuse type: USB driver: snd-usb-audio
bus-ID: 3-2.1:23 chip-ID: 1c75:af02 class-ID: fe01
Sound Server-1: ALSA v: k5.17.3-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 06:00.0 chip-ID: 8086:15f3
IF-ID-2: enp1s0f0u2c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 3.64 TiB used: 24.73 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 type: SSD serial: <filter> rev: P7CR402 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 type: SSD serial: <filter> rev: P7CR402 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 24.73 GiB (1.3%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
used: 24.73 GiB (1.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
ID-1: swap-1 type: zram size: 30.71 GiB used: 18 MiB (0.1%) priority: 100
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 62 C
Processes: 374 Uptime: 6d 11h 47m wakeups: 324 Memory: 30.71 GiB
used: 4.21 GiB (13.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1465 lib: 348 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date:     2022-04-18
Last full system update: 2022-04-28 ↻
Failed units:            bluetooth-autoconnect.service
No worries, welcome.
This is just a list of packages to install, probably dependencies for your game. The equivalent here would be Pacman, although I don’t know if those package names will be the same. You can try, and troubleshoot packages that fail based on errors you get. First fully update:
garuda-update
Then try to install your packages with Pacman:
sudo pacman -S curl libfltk1.3-dev portaudio19-dev libopus-dev libmp3lame-dev libvorbis-dev libogg-dev libflac-dev libfdk-aac-dev libdbus-1-dev libsamplerate0-dev libssl-dev
In the forum, please format your terminal outputs with code formatting by adding three tildes (~) before and after:
Like this
Did i edit it correctly? Thanks again @BluishHumility ~~~ × sudo pacman -S curl libfltk1.3-dev portaudio19-dev libopus-dev libmp3lame-dev libvorbis-dev libogg-dev libflac-dev libfdk-aac-dev libdbus-1-dev libsamplerate0-dev libssl-dev
warning: curl-7.82.0-3 is up to date -- reinstalling
error: target not found: libfltk1.3-dev
error: target not found: portaudio19-dev
error: target not found: libopus-dev
error: target not found: libmp3lame-dev
error: target not found: libvorbis-dev
error: target not found: libogg-dev
error: target not found: libflac-dev
error: target not found: libfdk-aac-dev
error: target not found: libdbus-1-dev
error: target not found: libsamplerate0-dev
error: target not found: libssl-dev ~~~
I am pretty sure all of those packages have a different name in arch. What you can do is take the name you have there and type it into the search on this site Arch Linux - Package Search maybe without the numbers and -dev. like just search portaudio for example. it will give you the package name of lib32-portaudio for that one so that one you can install using:
sudo pacman -S lib32-portaudio
Also, since you are looking for 32bit stuff, look for the one that is in the multilib repo as that is going to be where your 32bit stuff is.
i keep trying the same steps in process you recommended…
λ garuda-update
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
--> Refreshing mirrorlists using rate-mirrors, please be patient..
core                                  156.3 KiB   618 KiB/s 00:00 [------------------------------------] 100%
extra                                1700.7 KiB  3.24 MiB/s 00:01 [------------------------------------] 100%
community                               6.6 MiB  3.69 MiB/s 00:02 [------------------------------------] 100%
multilib                              174.4 KiB   724 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur                          1738.4 KiB   487 KiB/s 00:04 [------------------------------------] 100%
spawn pacman -Su
there is nothing to do
Checking for plugin updates
Nothing to install / update
System updated! 🐧
lightsight@lightsight in ~ as 🧙 took 1m40s
λ sudo pacman -S curl libfltk1.3-dev portaudio19-dev libopus-dev libmp3lame-dev libvorbis-dev libogg-dev libflac-dev libfdk-aac-dev libdbus-1-dev libsamplerate0-dev libssl-dev
[sudo] password for lightsight:
warning: curl-7.83.0-1 is up to date -- reinstalling
You know what they say about trying the same thing over and over and expecting different results, right? :wink:
Your original list of packages, wherever you got it from, is a list of Debian packages. They would be packages you would use on Debian or Ubuntu or Pop OS or one of the many other Debian-based distros out there. Garuda does not use apt for package management though, so the packages sometimes will be named differently or missing altogether.
My suggestion--to keep the list, but substitute "pacman" for "apt-get" was just a stab in the dark in case you got lucky and most or all of the packages wound up having the same name. They didn't, so no reason to keep after it.
I'm not sure if you skimmed over the advice @djwyman posted above, but it was excellent advice so double back and read it--I think that will for sure be a solution for getting the packages you need.
Both posts. :point_up_2:
That's because these packages have different names in Arch. They are going to be called lib32- and whatever the name is. Check the names against the link I posted above. The packages you are trying to install are the Debian names, not the arch names.
i made some progress by installing flatpack... and then installed Ardour & that installed some of the missing 32bitLibs... that got my https://mictests.com/ functioning but still not Download butt (broadcast using this tool) from SourceForge.net or the "Vivox" program which is critical for voice/microphone support in many platforms... By studying this Empowering player communications with Vivox | Unite Now 2020 - YouTube video it showed to me that it does not natively support Linux... so without resorting to a virtualbox or container env. this is where i am at in continued attempts to get voice support and live streaming support, specifically for SL "SecondLife" https://my.secondlife.com/xocel/picks/33f36edf-3b0a-0083-9390-243db9a020b8 that i use more professionally for live benefit performances and as a general musician/guitarist who has been known to collaborate with more than a few well-known internationally famous Professionals... I must assure you all that i do read and re-read the provided suggestions and links for application... so thank you all for your continued brainstorming to resolve my complex issues as a relatively new user learning Garuda/Arch OS who migrated from Ubuntu/Debian... Garuda has now been mentioned in SL for you all CONGRATULATIONS!!! So they provided more specific information of what was missing to install specifically for Arch/Manjaro/Garuda, etc... here is my new terminal output
 .%;888:8898898:               ---------------------------------------
x;XxXB%89b8:b8%b88:             OS: Garuda Linux
.8Xxd                8X:.          Host: ASUSTeK COMPUTER INC. ROG STRIX B550-F GAMING
.8Xx;                    8x:.        Kernel: 5.17.5-zen1-1-zen
.tt8x          .d            x88;      Uptime: 2 days, 2 hours, 1 min
.@8x8;          .db:              xx@;    Packages: 1479 (pacman), 7 (flatpak)
,tSXX°          .bbbbbbbbbbbbbbbbbbbB8x@;   Shell: bash
.SXxx            bBBBBBBBBBBBBBBBBBBBbSBX8;   DE: Plasma 5.24.5
,888S                                     pd!   WM: KWin
8X88/                                       q    Terminal: konsole
GBB.                                             CPU: AMD Ryzen 7 5700G with Radeon Graphics (16) @ 3.8GHz
x%88        d888@8@X@X@X88X@@XX@@X@8@X.         GPU: AMD ATI Cezanne
dxXd    dB8b8b8B8B08bB88b998888b88x.          GPU: NVIDIA GeForce GTX 960
dxx8o                      .@@;.             Memory: 4.05GiB / 30.71GiB
dx88                   .t@x.
d:SS@8ba89aa67a853Sxxad.
.d988999889889899dd.    ~~~
λ sudo pacman -S glu gtk2 libxcrypt-compat
warning: glu-9.0.2-3 is up to date -- reinstalling
warning: gtk2-2.24.33-2 is up to date -- reinstalling
warning: libxcrypt-compat-4.4.28-2 is up to date -- reinstalling
resolving dependencies...
Packages (3) glu-9.0.2-3  gtk2-2.24.33-2  libxcrypt-compat-4.4.28-2
Total Installed Size:  36.83 MiB
Net Upgrade Size:       0.00 MiB
:: Proceed with installation? [Y/n] Y
(3/3) checking keys in keyring                                     [------------------------------------] 100%
(3/3) checking package integrity                                   [------------------------------------] 100%
(3/3) loading package files                                        [------------------------------------] 100%
(3/3) checking for file conflicts                                  [------------------------------------] 100%
(3/3) checking available disk space                                [------------------------------------] 100%
==> root: 115
(1/3) reinstalling glu                                             [------------------------------------] 100%
(2/3) reinstalling gtk2                                            [------------------------------------] 100%
(3/3) reinstalling libxcrypt-compat                                [------------------------------------] 100%
(1/7) Arming ConditionNeedsUpdate...
(2/7) Foreign/AUR package notification
firestorm-bin 6.5.3.65658-1
kipi-plugins 21.12.3-1
libkipi 21.12.3-1
(3/7) Probing GTK2 input method modules...
(4/7) Orphaned package notification...
containerd 1.6.3-1
elfutils 0.187-1
libcroco 0.6.13-2
libmms 0.6.4-3
libofa 0.9.3-9
neard 0.18-1
nm-connection-editor 1.26.0-1
xf86-video-intel 1:2.99.917+916+g31486f40-2
(5/7) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/locale.gen.pacnew
/etc/pamac.conf.pacnew
/etc/paru.conf.pacnew
Please check and merge
(6/7) Performing snapper post snapshots for the following configurations...
==> root: 116
(7/7) Syncing all file systems...
lightsight@lightsight in ~ as 慄 took 10s
λ sudo pacman -S gst-plugins-bad gst-plugins-base gst-plugins-good gst-plugins-ugly lib32-gst-plugins-base li
b32-gst-plugins-good lib32-libpulse lib32-alsa-plugins lib32-alsa-lib libidn11 lib32-libidn11
warning: gst-plugins-bad-1.20.2-1 is up to date -- reinstalling
warning: gst-plugins-base-1.20.2-1 is up to date -- reinstalling
warning: gst-plugins-good-1.20.2-1 is up to date -- reinstalling
warning: gst-plugins-ugly-1.20.2-1 is up to date -- reinstalling
warning: lib32-alsa-lib-1.2.6.1-1 is up to date -- reinstalling
warning: dependency cycle detected:
warning: lib32-harfbuzz will be installed before its lib32-freetype2 dependency
Packages (86) alsa-plugins-1:1.2.6-3  lib32-aalib-1.4rc5-2  lib32-at-spi2-atk-2.38.0-2
lib32-at-spi2-core-2.44.1-1  lib32-atk-2.38.0-1  lib32-cairo-1.17.6-2  lib32-cdparanoia-10.2-3
lib32-colord-1.4.6-1  lib32-fontconfig-2:2.14.0-1  lib32-freetype2-2.12.1-1
lib32-fribidi-1.0.12-1  lib32-gdk-pixbuf2-2.42.8-1  lib32-giflib-5.2.1-1
lib32-glib-networking-2.72.0-1  lib32-glib2-2.72.1-1  lib32-gmp-6.2.1-1  lib32-gnutls-3.7.4-1
lib32-gpm-1.20.7-2  lib32-gst-plugins-base-libs-1.20.2-1  lib32-gstreamer-1.20.2-1
lib32-gtk3-3.24.33-1  lib32-harfbuzz-4.2.1-1  lib32-imlib2-1.9.0-2  lib32-json-glib-1.6.6-2
lib32-lcms2-2.13.1-1  lib32-libasyncns-0.8+3+g68cd5af-2  lib32-libavc1394-0.5.4-2
lib32-libcaca-0.99.beta20-1  lib32-libcanberra-1:0.30+r2+gc0620e4-1  lib32-libcups-2.4.1-1
lib32-libdatrie-0.2.13-1  lib32-libdv-1.0.0-5  lib32-libepoxy-1.5.10-1  lib32-libgudev-237-2
lib32-libiec61883-1.2.0-2  lib32-libjpeg-turbo-2.1.3-1  lib32-libltdl-2.4.7-1
lib32-libnghttp2-1.47.0-1  lib32-libpng-1.6.37-3  lib32-libproxy-0.4.17-2
lib32-libraw1394-2.1.2-2  lib32-librsvg-2:2.54.1-1  lib32-libshout-2.4.6-1
lib32-libsoup-2.74.2-1  lib32-libsoup3-3.0.6-1  lib32-libtasn1-4.18.0-1  lib32-libthai-0.1.29-1
lib32-libtheora-1.1.1-13  lib32-libtiff-4.3.0-2  lib32-libvisual-0.4.0-6  lib32-libvpx-1.11.0-2
lib32-libxcomposite-0.4.5-1  lib32-libxcursor-1.2.1-1  lib32-libxft-2.3.4-1
lib32-libxinerama-1.1.4-1  lib32-libxkbcommon-1.4.0-1  lib32-libxtst-1.2.3-2
lib32-libxv-1.0.11-2  lib32-mpg123-1.29.3-1  lib32-nettle-3.7.3-1  lib32-orc-0.4.32-2
lib32-p11-kit-0.24.1-1  lib32-pango-1:1.50.7-1  lib32-pcre-8.45-1  lib32-pixman-0.40.0-1
lib32-popt-1.18-1  lib32-rest-0.8.1-4  lib32-speex-1.2.0-2  lib32-speexdsp-1.2.0-1
lib32-sqlite-3.38.3-1  lib32-taglib-1.12-1  lib32-tdb-1.4.6-1  lib32-twolame-0.4.0-2
lib32-v4l-utils-1.22.1-1  lib32-wavpack-5.4.0-1  gst-plugins-bad-1.20.2-1
gst-plugins-base-1.20.2-1  gst-plugins-good-1.20.2-1  gst-plugins-ugly-1.20.2-1
lib32-alsa-lib-1.2.6.1-1  lib32-alsa-plugins-1.2.6-1  lib32-gst-plugins-base-1.20.2-1
lib32-gst-plugins-good-1.20.2-1  lib32-libidn11-1.33-2  lib32-libpulse-15.0-2  libidn11-1.33-2
Total Download Size:   22.67 MiB
Total Installed Size:  88.87 MiB
Net Upgrade Size:      75.61 MiB
:: Retrieving packages...
lib32-glib2-2.72.1-1-x86_64          1194.1 KiB  1883 KiB/s 00:01 [------------------------------------] 100%
lib32-gst-plugins-base-libs-1.20...  1516.6 KiB  1177 KiB/s 00:01 [------------------------------------] 100%
lib32-libvpx-1.11.0-2-x86_64         1140.9 KiB  1788 KiB/s 00:01 [------------------------------------] 100%
lib32-librsvg-2:2.54.1-1-x86_64         2.6 MiB  1574 KiB/s 00:02 [------------------------------------] 100%
lib32-gst-plugins-good-1.20.2-1-...  1918.7 KiB  1117 KiB/s 00:02 [------------------------------------] 100%
lib32-gnutls-3.7.4-1-x86_64           850.4 KiB  1032 KiB/s 00:01 [------------------------------------] 100%
lib32-gstreamer-1.20.2-1-x86_64      1018.6 KiB  1175 KiB/s 00:01 [------------------------------------] 100%
lib32-cairo-1.17.6-2-x86_64           622.3 KiB  1347 KiB/s 00:00 [------------------------------------] 100%
lib32-gtk3-3.24.33-1-x86_64             2.9 MiB  1292 KiB/s 00:02 [------------------------------------] 100%
lib32-harfbuzz-4.2.1-1-x86_64         663.8 KiB  1286 KiB/s 00:01 [------------------------------------] 100%
lib32-sqlite-3.38.3-1-x86_64          569.4 KiB  2.47 MiB/s 00:00 [------------------------------------] 100%
lib32-freetype2-2.12.1-1-x86_64       355.4 KiB  1684 KiB/s 00:00 [------------------------------------] 100%
lib32-pcre-8.45-1-x86_64              379.4 KiB  1518 KiB/s 00:00 [------------------------------------] 100%
lib32-p11-kit-0.24.1-1-x86_64         349.0 KiB  1678 KiB/s 00:00 [------------------------------------] 100%
lib32-gst-plugins-base-1.20.2-1-...   329.2 KiB  1646 KiB/s 00:00 [------------------------------------] 100%
lib32-nettle-3.7.3-1-x86_64           319.2 KiB  2.08 MiB/s 00:00 [------------------------------------] 100%
lib32-taglib-1.12-1-x86_64            302.0 KiB  2.50 MiB/s 00:00 [------------------------------------] 100%
lib32-gmp-6.2.1-1-x86_64              283.0 KiB  1444 KiB/s 00:00 [------------------------------------] 100%
lib32-libpulse-15.0-2-x86_64          281.5 KiB  1564 KiB/s 00:00 [------------------------------------] 100%
lib32-mpg123-1.29.3-1-x86_64          270.8 KiB  1651 KiB/s 00:00 [------------------------------------] 100%
lib32-pixman-0.40.0-1-x86_64          258.0 KiB  1517 KiB/s 00:00 [------------------------------------] 100%
lib32-libcups-2.4.1-1-x86_64          242.6 KiB  1957 KiB/s 00:00 [------------------------------------] 100%
lib32-libsoup-2.74.2-1-x86_64         228.6 KiB  2.57 MiB/s 00:00 [------------------------------------] 100%
lib32-pango-1:1.50.7-1-x86_64         226.1 KiB  2.23 MiB/s 00:00 [------------------------------------] 100%
lib32-libepoxy-1.5.10-1-x86_64        217.1 KiB  1974 KiB/s 00:00 [------------------------------------] 100%
lib32-libjpeg-turbo-2.1.3-1-x86_64    209.8 KiB  1840 KiB/s 00:00 [------------------------------------] 100%
lib32-v4l-utils-1.22.1-1-x86_64       214.1 KiB  1598 KiB/s 00:00 [------------------------------------] 100%
lib32-libsoup3-3.0.6-1-x86_64         208.6 KiB  1896 KiB/s 00:00 [------------------------------------] 100%
lib32-libtiff-4.3.0-2-x86_64          202.7 KiB  2.33 MiB/s 00:00 [------------------------------------] 100%
lib32-libcaca-0.99.beta20-1-x86_64    198.2 KiB  2002 KiB/s 00:00 [------------------------------------] 100%
lib32-libtheora-1.1.1-13-x86_64       180.5 KiB  2.48 MiB/s 00:00 [------------------------------------] 100%
lib32-imlib2-1.9.0-2-x86_64           185.9 KiB  2.06 MiB/s 00:00 [------------------------------------] 100%
lib32-orc-0.4.32-2-x86_64             166.6 KiB  2.62 MiB/s 00:00 [------------------------------------] 100%
lib32-lcms2-2.13.1-1-x86_64           162.0 KiB  2.43 MiB/s 00:00 [------------------------------------] 100%
lib32-fontconfig-2:2.14.0-1-x86_64    144.4 KiB  2.66 MiB/s 00:00 [------------------------------------] 100%
lib32-libpng-1.6.37-3-x86_64          129.7 KiB  2.69 MiB/s 00:00 [------------------------------------] 100%
lib32-libxkbcommon-1.4.0-1-x86_64     129.2 KiB  2.80 MiB/s 00:00 [------------------------------------] 100%
lib32-gdk-pixbuf2-2.42.8-1-x86_64     124.6 KiB  2.48 MiB/s 00:00 [------------------------------------] 100%
lib32-colord-1.4.6-1-x86_64           116.6 KiB  2.65 MiB/s 00:00 [------------------------------------] 100%
alsa-plugins-1:1.2.6-3-x86_64          87.6 KiB  2.38 MiB/s 00:00 [------------------------------------] 100%
lib32-libvisual-0.4.0-6-x86_64         87.2 KiB  1982 KiB/s 00:00 [------------------------------------] 100%
lib32-at-spi2-core-2.44.1-1-x86_64     75.5 KiB  1542 KiB/s 00:00 [------------------------------------] 100%
lib32-alsa-plugins-1.2.6-1-x86_64      70.2 KiB  1670 KiB/s 00:00 [------------------------------------] 100%
lib32-libcanberra-1:0.30+r2+gc06...    64.8 KiB  1271 KiB/s 00:00 [------------------------------------] 100%
lib32-libnghttp2-1.47.0-1-x86_64       63.8 KiB  1181 KiB/s 00:00 [------------------------------------] 100%
lib32-json-glib-1.6.6-2-x86_64         61.5 KiB  1254 KiB/s 00:00 [------------------------------------] 100%
lib32-at-spi2-atk-2.38.0-2-x86_64      61.2 KiB   851 KiB/s 00:00 [------------------------------------] 100%
lib32-glib-networking-2.72.0-1-x...    55.9 KiB  1472 KiB/s 00:00 [------------------------------------] 100%
lib32-wavpack-5.4.0-1-x86_64           81.9 KiB   416 KiB/s 00:00 [------------------------------------] 100%
libidn11-1.33-2-x86_64                 54.4 KiB  1359 KiB/s 00:00 [------------------------------------] 100%
lib32-libshout-2.4.6-1-x86_64          51.4 KiB  1317 KiB/s 00:00 [------------------------------------] 100%
lib32-libproxy-0.4.17-2-x86_64         51.3 KiB  1349 KiB/s 00:00 [------------------------------------] 100%
lib32-libidn11-1.33-2-x86_64           50.8 KiB  1270 KiB/s 00:00 [------------------------------------] 100%
lib32-twolame-0.4.0-2-x86_64           50.5 KiB  1328 KiB/s 00:00 [------------------------------------] 100%
lib32-speex-1.2.0-2-x86_64             48.1 KiB  1301 KiB/s 00:00 [------------------------------------] 100%
lib32-libdv-1.0.0-5-x86_64             49.3 KiB   726 KiB/s 00:00 [------------------------------------] 100%
lib32-atk-2.38.0-1-x86_64              44.7 KiB  1242 KiB/s 00:00 [------------------------------------] 100%
lib32-tdb-1.4.6-1-x86_64               42.3 KiB   671 KiB/s 00:00 [------------------------------------] 100%
lib32-cdparanoia-10.2-3-x86_64         41.8 KiB   684 KiB/s 00:00 [------------------------------------] 100%
lib32-aalib-1.4rc5-2-x86_64            41.5 KiB   601 KiB/s 00:00 [------------------------------------] 100%
lib32-rest-0.8.1-4-x86_64              40.0 KiB   656 KiB/s 00:00 [------------------------------------] 100%
lib32-libxft-2.3.4-1-x86_64            39.6 KiB   694 KiB/s 00:00 [------------------------------------] 100%
lib32-libtasn1-4.18.0-1-x86_64         39.0 KiB   765 KiB/s 00:00 [------------------------------------] 100%
lib32-speexdsp-1.2.0-1-x86_64          36.5 KiB   716 KiB/s 00:00 [------------------------------------] 100%
lib32-popt-1.18-1-x86_64               25.5 KiB   749 KiB/s 00:00 [------------------------------------] 100%
lib32-fribidi-1.0.12-1-x86_64          22.3 KiB   675 KiB/s 00:00 [------------------------------------] 100%
lib32-libxcursor-1.2.1-1-x86_64        21.1 KiB   620 KiB/s 00:00 [------------------------------------] 100%
lib32-libltdl-2.4.7-1-x86_64           18.5 KiB   545 KiB/s 00:00 [------------------------------------] 100%
lib32-giflib-5.2.1-1-x86_64            17.5 KiB   449 KiB/s 00:00 [------------------------------------] 100%
lib32-libraw1394-2.1.2-2-x86_64        24.9 KiB   109 KiB/s 00:00 [------------------------------------] 100%
lib32-libthai-0.1.29-1-x86_64          17.2 KiB   265 KiB/s 00:00 [------------------------------------] 100%
lib32-libdatrie-0.2.13-1-x86_64        16.5 KiB   485 KiB/s 00:00 [------------------------------------] 100%
lib32-libgudev-237-2-x86_64            14.5 KiB   439 KiB/s 00:00 [------------------------------------] 100%
lib32-libiec61883-1.2.0-2-x86_64       20.5 KiB  97.8 KiB/s 00:00 [------------------------------------] 100%
lib32-libavc1394-0.5.4-2-x86_64        14.2 KiB   274 KiB/s 00:00 [------------------------------------] 100%
lib32-libxtst-1.2.3-2-x86_64           11.3 KiB   289 KiB/s 00:00 [------------------------------------] 100%
lib32-libasyncns-0.8+3+g68cd5af-...    10.6 KiB   203 KiB/s 00:00 [------------------------------------] 100%
lib32-libxv-1.0.11-2-x86_64             9.3 KiB   128 KiB/s 00:00 [------------------------------------] 100%
lib32-libxcomposite-0.4.5-1-x86_64      5.7 KiB   178 KiB/s 00:00 [------------------------------------] 100%
lib32-libxinerama-1.1.4-1-x86_64        5.6 KiB   168 KiB/s 00:00 [------------------------------------] 100%
lib32-gpm-1.20.7-2-x86_64              11.3 KiB  58.2 KiB/s 00:00 [------------------------------------] 100%
Total (81/81)                          22.7 MiB  4.83 MiB/s 00:05 [------------------------------------] 100%
(86/86) checking keys in keyring                                   [------------------------------------] 100%
(86/86) checking package integrity                                 [------------------------------------] 100%
(86/86) loading package files                                      [------------------------------------] 100%
(86/86) checking for file conflicts                                [------------------------------------] 100%
(86/86) checking available disk space                              [------------------------------------] 100%
==> root: 117
( 1/86) reinstalling gst-plugins-bad                               [------------------------------------] 100%
( 2/86) reinstalling gst-plugins-base                              [------------------------------------] 100%
( 3/86) reinstalling gst-plugins-good                              [------------------------------------] 100%
( 4/86) reinstalling gst-plugins-ugly                              [------------------------------------] 100%
( 5/86) installing lib32-pcre                                      [------------------------------------] 100%
( 6/86) installing lib32-glib2                                     [------------------------------------] 100%
( 7/86) installing lib32-libxtst                                   [------------------------------------] 100%
( 8/86) installing lib32-at-spi2-core                              [------------------------------------] 100%
( 9/86) installing lib32-atk                                       [------------------------------------] 100%
(10/86) installing lib32-at-spi2-atk                               [------------------------------------] 100%
(11/86) installing lib32-libjpeg-turbo                             [------------------------------------] 100%
(12/86) installing lib32-libtiff                                   [------------------------------------] 100%
(13/86) installing lib32-lcms2                                     [------------------------------------] 100%
(14/86) installing lib32-colord                                    [------------------------------------] 100%
(15/86) installing lib32-libpng                                    [------------------------------------] 100%
(16/86) installing lib32-gdk-pixbuf2                               [------------------------------------] 100%
Optional dependencies for lib32-gdk-pixbuf2
lib32-librsvg: Load .svg, .svgz, and .svg.gz [pending]
(17/86) installing lib32-json-glib                                 [------------------------------------] 100%
(18/86) installing lib32-gmp                                       [------------------------------------] 100%
(19/86) installing lib32-nettle                                    [------------------------------------] 100%
(20/86) installing lib32-libtasn1                                  [------------------------------------] 100%
(21/86) installing lib32-p11-kit                                   [------------------------------------] 100%
(22/86) installing lib32-gnutls                                    [------------------------------------] 100%
(23/86) installing lib32-libcups                                   [------------------------------------] 100%
(24/86) installing lib32-libepoxy                                  [------------------------------------] 100%
(25/86) installing lib32-harfbuzz                                  [------------------------------------] 100%
(26/86) installing lib32-freetype2                                 [------------------------------------] 100%
(27/86) installing lib32-fontconfig                                [------------------------------------] 100%
Rebuilding 32-bit fontconfig cache...
(28/86) installing lib32-pixman                                    [------------------------------------] 100%
(29/86) installing lib32-cairo                                     [------------------------------------] 100%
(30/86) installing lib32-libdatrie                                 [------------------------------------] 100%
(31/86) installing lib32-libthai                                   [------------------------------------] 100%
(32/86) installing lib32-libxft                                    [------------------------------------] 100%
(33/86) installing lib32-fribidi                                   [------------------------------------] 100%
(34/86) installing lib32-pango                                     [------------------------------------] 100%
(35/86) installing lib32-librsvg                                   [------------------------------------] 100%
(36/86) installing lib32-libxcomposite                             [------------------------------------] 100%
(37/86) installing lib32-libxcursor                                [------------------------------------] 100%
(38/86) installing lib32-libxinerama                               [------------------------------------] 100%
(39/86) installing lib32-libxkbcommon                              [------------------------------------] 100%
(40/86) installing lib32-libproxy                                  [------------------------------------] 100%
(41/86) installing lib32-glib-networking                           [------------------------------------] 100%
(42/86) installing lib32-sqlite                                    [------------------------------------] 100%
(43/86) installing lib32-libsoup                                   [------------------------------------] 100%
Optional dependencies for lib32-libsoup
samba: Windows Domain SSO
(44/86) installing lib32-rest                                      [------------------------------------] 100%
(45/86) installing lib32-libltdl                                   [------------------------------------] 100%
(46/86) reinstalling lib32-alsa-lib                                [------------------------------------] 100%
(47/86) installing lib32-libasyncns                                [------------------------------------] 100%
(48/86) installing lib32-libpulse                                  [------------------------------------] 100%
Optional dependencies for lib32-libpulse
lib32-alsa-plugins: ALSA support [pending]
lib32-glib2: mainloop integration [installed]
(49/86) installing lib32-tdb                                       [------------------------------------] 100%
(50/86) installing lib32-libcanberra                               [------------------------------------] 100%
(51/86) installing lib32-gtk3                                      [------------------------------------] 100%
(52/86) installing lib32-gstreamer                                 [------------------------------------] 100%
(53/86) installing lib32-orc                                       [------------------------------------] 100%
(54/86) installing lib32-libxv                                     [------------------------------------] 100%
(55/86) installing lib32-gst-plugins-base-libs                     [------------------------------------] 100%
(56/86) installing lib32-cdparanoia                                [------------------------------------] 100%
(57/86) installing lib32-libvisual                                 [------------------------------------] 100%
(58/86) installing lib32-libtheora                                 [------------------------------------] 100%
(59/86) installing lib32-gst-plugins-base                          [------------------------------------] 100%
(60/86) installing lib32-libnghttp2                                [------------------------------------] 100%
(61/86) installing lib32-libsoup3                                  [------------------------------------] 100%
Optional dependencies for lib32-libsoup3
(62/86) installing lib32-wavpack                                   [------------------------------------] 100%
(63/86) installing lib32-gpm                                       [------------------------------------] 100%
(64/86) installing lib32-aalib                                     [------------------------------------] 100%
(65/86) installing lib32-taglib                                    [------------------------------------] 100%
(66/86) installing lib32-popt                                      [------------------------------------] 100%
(67/86) installing lib32-libdv                                     [------------------------------------] 100%
(68/86) installing lib32-speexdsp                                  [------------------------------------] 100%
(69/86) installing lib32-speex                                     [------------------------------------] 100%
(70/86) installing lib32-libshout                                  [------------------------------------] 100%
(71/86) installing lib32-libvpx                                    [------------------------------------] 100%
(72/86) installing lib32-giflib                                    [------------------------------------] 100%
(73/86) installing lib32-imlib2                                    [------------------------------------] 100%
Optional dependencies for lib32-imlib2
lib32-libid3tag: ID3 loader
lib32-librsvg: SVG loader [installed]
lib32-libwebp: WEBP loader
(74/86) installing lib32-libcaca                                   [------------------------------------] 100%
(75/86) installing lib32-libraw1394                                [------------------------------------] 100%
(76/86) installing lib32-libavc1394                                [------------------------------------] 100%
(77/86) installing lib32-libiec61883                               [------------------------------------] 100%
(78/86) installing lib32-v4l-utils                                 [------------------------------------] 100%
(79/86) installing lib32-libgudev                                  [------------------------------------] 100%
(80/86) installing lib32-mpg123                                    [------------------------------------] 100%
Optional dependencies for lib32-mpg123
lib32-sdl: for additional audio support
(81/86) installing lib32-twolame                                   [------------------------------------] 100%
(82/86) installing lib32-gst-plugins-good                          [------------------------------------] 100%
(83/86) installing alsa-plugins                                    [------------------------------------] 100%
Optional dependencies for alsa-plugins
dbus: for maemo plugin [installed]
jack: for pcm_jack plugin [installed]
libavtp: for pcm_aaf plugin [installed]
libsamplerate: for rate_samplerate plugin [installed]
libpulse: for conf_pulse, ctl_pulse and pcm_pulse plugins [installed]
speexdsp: for pcm_speex and rate_speexrate plugins [installed]
ffmpeg: for pcm_a52 plugin [installed]
(84/86) installing lib32-alsa-plugins                              [------------------------------------] 100%
Optional dependencies for lib32-alsa-plugins
lib32-dbus: for maemo plugin [installed]
lib32-jack: for pcm_jack plugin [installed]
lib32-libavtp: for pcm_aaf plugin
lib32-libsamplerate: for rate_samplerate plugin
lib32-libpulse: for conf_pulse, ctl_pulse and pcm_pulse plugins [installed]
lib32-speexdsp: for pcm_speex and rate_speexrate plugins [installed]
(85/86) installing libidn11                                        [------------------------------------] 100%
(86/86) installing lib32-libidn11                                  [------------------------------------] 100%
(1/9) Arming ConditionNeedsUpdate...
(2/9) Foreign/AUR package notification
libkipi 21.12.3-1
(3/9) Probing 32-bit GDK-Pixbuf loader modules...
(4/9) Updating 32-bit GIO module cache...
(5/9) Probing 32-bit GTK3 input method modules...
(6/9) Orphaned package notification...
containerd 1.6.3-1
elfutils 0.187-1
libcroco 0.6.13-2
libmms 0.6.4-3
libofa 0.9.3-9
neard 0.18-1
(7/9) Checking for .pacnew and .pacsave files...
.pac* files found:
==> root: 118
lightsight@lightsight in ~ as 慄 took 13s
λ yay -S lib32-libstdc++5 lib32-libstdc++28
:: Resolving dependencies...
:: Calculating conflicts...
:: Calculating inner conflicts...
Repo Make (1) rpmextract-1.0-9
Aur (2) lib32-libstdc++5-3.3.6-8  lib32-libstdc++28-2.8.0+14-3
:: Proceed to review? [Y/n]: Y
:: Downloading PKGBUILDs...
(2/2) lib32-libstdc++28-2.8.0+14-3                  [------------------------------------------------------]
/home/lightsight/.cache/paru/clone/lib32-libstdc++5/PKGBUILD
# Maintainer: Chris Severance aur.severach aATt spamgourmet dott com
# Contributor: Florian Pritz <bluewind@xinu.at>
set -u
pkgname='lib32-libstdc++5'
pkgver='3.3.6'
pkgrel='8'
pkgdesc='Legacy GNU Standard C++ library version 3 (32 bit)'
arch=('x86_64')
url='http://gcc.gnu.org'
license=('GPL' 'LGPL')
depends=('lib32-gcc-libs')
makedepends=('gcc-multilib' 'binutils' 'bash')
options=('!buildflags')
source=(
"https://gcc.gnu.org/pub/gcc/releases/gcc-${pkgver}/gcc-"{core,g++}"-${pkgver}.tar.bz2"
'gcc-3.4.3-no_multilib_amd64.patch'
md5sums=('18c52e6fb8966b7700665dca289d077f'
'6b3d00b8d079805be1b895f7f6ce47a0'
'8504bb22dae9d49e8b6d70d7e6910f1b')
sha256sums=('4f9bee8ac57711508d6b8031d5ecfefc16fcf37ec81568b3f8344ef5f4cdfeb6'
'7ee9fdf2771084c4933bb0a31d2fd9bfe8df746f9f47d76562b7a9e302a29d92'
'dc2dc473071887ff6129c121950052398ed7c6fa1075ed839376030772068857') ~~~
prepare() {
: ~~~ the "AUR" install process is also new to me and i am not sure if it completely finished doing what it needs or what i need to do to execute ./?
This is in the AUR.
i cannot seem to find it @jonathon do you have some kind of direct link you could post here?
Namaste
Please format your post.
Read
paru butt
Use 1, check PKGBUILD. Install or not install :slight_smile:
λ sudo pacman -Syu
Garuda Linux is updated via the "garuda-update" command instead of pacman -Syu. https://wiki.garudalinux.org/en/garuda-update
Would you like to run "garuda-update" instead? (i = never ask again/ignore) [y/N/i] y
core                                  156.2 KiB   827 KiB/s 00:00 [------------------------------------] 100%
extra                                1699.3 KiB  2.70 MiB/s 00:01 [------------------------------------] 100%
community                               6.6 MiB  4.75 MiB/s 00:01 [------------------------------------] 100%
multilib                              173.9 KiB   874 KiB/s 00:00 [------------------------------------] 100%
chaotic-aur                          1741.7 KiB   462 KiB/s 00:04 [------------------------------------] 100%
core                                  156.2 KiB   982 KiB/s 00:00 [------------------------------------] 100%
extra                                1699.3 KiB  1263 KiB/s 00:01 [------------------------------------] 100%
community                               6.6 MiB  4.26 MiB/s 00:02 [------------------------------------] 100%
multilib                              173.9 KiB   327 KiB/s 00:01 [------------------------------------] 100%
chaotic-aur                          1741.7 KiB   511 KiB/s 00:03 [------------------------------------] 100%
spawn pacman -Su
Packages (10) brave-nightly-bin-1.40.36-1  jre-openjdk-18.0.1.1.u2-1  jre-openjdk-headless-18.0.1.1.u2-1
krename-5.0.1-4  lib32-libxcb-1.15-1  libxcb-1.15-1  podofo-0.9.8-1
python-setuptools-1:59.6.0-1  sqlite-3.38.4-1  xcb-proto-1.15-1
Total Download Size:   164.45 MiB
Total Installed Size:  471.76 MiB
Net Upgrade Size:       -0.17 MiB
podofo-0.9.8-1-x86_64                 804.2 KiB  1347 KiB/s 00:01 [------------------------------------] 100%
sqlite-3.38.4-1-x86_64               1760.2 KiB  2.67 MiB/s 00:01 [------------------------------------] 100%
libxcb-1.15-1-x86_64                  998.9 KiB  1452 KiB/s 00:01 [------------------------------------] 100%
lib32-libxcb-1.15-1-x86_64            184.5 KiB   843 KiB/s 00:00 [------------------------------------] 100%
python-setuptools-1:59.6.0-1-any      562.9 KiB  1268 KiB/s 00:00 [------------------------------------] 100%
krename-5.0.1-4-x86_64                479.5 KiB  1153 KiB/s 00:00 [------------------------------------] 100%
jre-openjdk-18.0.1.1.u2-1-x86_64      182.1 KiB  1917 KiB/s 00:00 [------------------------------------] 100%
xcb-proto-1.15-1-any                  112.7 KiB  1483 KiB/s 00:00 [------------------------------------] 100%
jre-openjdk-headless-18.0.1.1.u2...    37.1 MiB  5.29 MiB/s 00:07 [------------------------------------] 100%
brave-nightly-bin-1.40.36-1-x86_64    122.4 MiB  3.92 MiB/s 00:31 [------------------------------------] 100%
Total (10/10)                         164.5 MiB  5.27 MiB/s 00:31 [------------------------------------] 100%
(10/10) checking keys in keyring                                   [------------------------------------] 100%
(10/10) checking package integrity                                 [------------------------------------] 100%
(10/10) loading package files                                      [------------------------------------] 100%
(10/10) checking for file conflicts                                [------------------------------------] 100%
(10/10) checking available disk space                              [------------------------------------] 100%
==> root: 119
( 1/10) upgrading xcb-proto                                        [------------------------------------] 100%
( 2/10) upgrading libxcb                                           [------------------------------------] 100%
( 3/10) upgrading sqlite                                           [------------------------------------] 100%
( 4/10) upgrading brave-nightly-bin                                [------------------------------------] 100%
( 5/10) upgrading jre-openjdk-headless                             [------------------------------------] 100%
( 6/10) upgrading jre-openjdk                                      [------------------------------------] 100%
( 7/10) upgrading podofo                                           [------------------------------------] 100%
( 8/10) upgrading krename                                          [------------------------------------] 100%
( 9/10) upgrading lib32-libxcb                                     [------------------------------------] 100%
(10/10) upgrading python-setuptools                                [------------------------------------] 100%
(1/8) Arming ConditionNeedsUpdate...
(2/8) Foreign/AUR package notification
libkipi 21.12.3-1
(3/8) Updating icon theme caches...
(4/8) Orphaned package notification...
containerd 1.6.3-1
elfutils 0.187-1
libcroco 0.6.13-2
libmms 0.6.4-3
libofa 0.9.3-9
neard 0.18-1
(5/8) Checking for .pacnew and .pacsave files...
.pac* files found:
(6/8) Updating the desktop file MIME type cache...
(7/8) Performing snapper post snapshots for the following configurations...
==> root: 120
(8/8) Syncing all file systems...
System updated! 🐧 ~~~
Please, edit this post
so i read all you presented @SGS and continue to study when i can... there is terrible storms and flooding going on here in Kansas and too many other issues upon my fathers death i am having to deal with just FYI compassion.... i appreciate everything you all are continuing to do and have so far been able to perform one new song for my friends using vivox "voice/mic" in SL SecondLife and that is my most important goal is to get back to my only means of income and continue to use my talents to help others in much more desparate situations... Namaste... and here is the "AUR" output that i am still confused about... i hope this is helping others here on the forum despite my bad grammar and annoyances being a "newB"
lightsight@lightsight-systemproductname
.tt8x          .d            x88;      Uptime: 2 days, 14 hours, 16 mins
.@8x8;          .db:              xx@;    Packages: 1560 (pacman), 7 (flatpak)
,888S                                     pd!   WM: KWin
dxx8o                      .@@;.             Memory: 4.42GiB / 30.71GiB
dx88                   .t@x.
λ paru butt
133 aur/nwg-bar-bin 0.1.0-1 [+0 ~0.00]
GTK3-based button bar for sway and other wlroots-based compositors
132 aur/juno-standard-buttons-gtk-theme-git r148.f0704a4-1 [+0 ~0.00]
GTK themes inspired by epic vscode themes
131 aur/juno-palenight-standard-buttons-gtk-theme-git r156.f0a3818-1 [+0 ~0.00]
130 aur/juno-ocean-standard-buttons-gtk-theme-git r149.6d73f68-1 [+0 ~0.00]
129 aur/juno-mirage-standard-buttons-gtk-theme-git r156.11dd089-1 [+0 ~0.00]
128 aur/gnome-shell-extension-hibernate-status 1.10.2-1 [+0 ~0.00]
Gnome Shell extension that adds a hibernate/hybrid suspend button in Status menu.
127 aur/libjxl-metrics-git v0.3.7.870.g373c5928-2 [+0 ~0.00]
JPEG XL image format reference implementation with butteraugli and ssimulacra (git version)
126 aur/python-sphinx-copybutton-doc 0.5.0-1 [+0 ~0.00]
Documentation for Sphinx-Copybutton extension
125 aur/clonehero-launcher 0.9.488-2 [+0 ~0.00]
Launcher for Clone Hero. Clone Hero is a free rhythm game, which can be played with any 5 or 6 button
guitar controller, game controllers, or just your standard computer keyboard.
124 aur/spice-gtk-extra-mouse-buttons 0.39-4.4 [+0 ~0.00] [Orphaned]
GTK+ client library for SPICE (with support for extra mouse buttons)
123 aur/spice-vdagent-extra-mouse-buttons 0.21.0-1.2 [+0 ~0.00] [Orphaned]
Spice agent for Linux guests (with support for extra mouse buttons)
122 aur/buttermilk 0.2.0-1 [+0 ~0.00]
A basic personal terminal emulator based on VTE
121 aur/python-sphinx-togglebutton 0.3.0-1 [+0 ~0.00]
Toggle page content and collapse admonitions in Sphinx
120 aur/cross-code-bin 1.3-2 [+0 ~0.00]
A retro-inspired 2D Action RPG set in the distant future. CrossCode combines 16-bit SNES-style graphics
with butter-smooth physics, a fast-paced combat system, and engaging puzzle mechanics, served with a
gripping sci-fi story.
119 aur/mumble-one-ptt-git 1:1.4.0.development.snapshot.006.r285.g756be79be-1 [+0 ~0.00]
mumble-git, with push-to-talk modified to handle only one button
118 aur/xfce4-windowck-plugin-xfwm4-theme-support 0.4.5+40+g585ba47-1 [+0 ~0.00]
Xfce panel plugin for displaying window title and buttons (xfwm4 theme support reenabled)
117 aur/xfce4-windowck-plugin-git 1:0.4.5+38+g16d4a27-1 [+0 ~0.00]
116 aur/gnome-shell-extension-activities-icons-git r6.f29ee60-1 [+0 ~0.00]
A Gnome Shell extension that replaces the Activities button with 2 icons for selecting between
Applications and Workspaces.
115 aur/applet-window-buttons-git 0.9.0.r2.g9910320-2 [+0 ~0.00] [Out-of-date: 2022-02-12]
This is a Plasma 5 applet that shows window buttons in your panels
114 aur/go-ssb-room-git r531.d8da4ae-1 [+0 ~0.00]
The Secure-Scuttlebutt Room v2 server, written in Go
113 aur/firefox-awesome-rss 1.3.5-1 [+0 ~0.00]
Puts an RSS/Atom subscribe button back in URL bar
112 aur/bbb-recorder-git 0.0.0+81-3 [+0 ~0.00]
Tool to download recordings from Big Blue Button
111 aur/flova-lightdm-webkit-theme-sequoia-git r30.378dd0c-1 [+0 ~0.00]
A simple LightDM theme (Flova fork, fixes buttons alignement)
110 aur/buttersink-git 0.6.9.r9.g5cc37e3-1 [+0 ~0.00]
Buttersink is like rsync for btrfs snapshots
109 aur/oasis 2.17.0-2 [+0 ~0.00] [Orphaned]
Helps you follow friends and discover new ones on Secure Scuttlebutt (SSB).
108 aur/mediad 0.1.3-1 [+0 ~0.00]
A Simple and lightweight daemon to handle keyboard media buttons easily
107 aur/vdrpbd 2.1.0-1 [+0 ~0.00]
A daemon to handle ACPI power button event on VDR systems
106 aur/btnx-config-git r30.0b30428-1 [+0 ~0.00] [Orphaned]
A configuration tool for btnx (Button Extension)
105 aur/btnx-git r23.ef3f5b9-1 [+0 ~0.00] [Out-of-date: 2021-09-04] [Orphaned]
A daemon that enables rerouting of mouse button events through uinput as keyboard and other mouse button
combinations
104 aur/plasma5-applets-latte-sidebar-button-git 0.1.0.r1.gd6fcf1e-1 [+0 ~0.00]
Plasma applet to show and hide Latte Sidebars
103 aur/firefox-extension-image-block 5.0-1 [+0 ~0.00]
Image Block adds a toggle button that conditionally blocks/allows loading of images on webpages.
102 aur/minetest-mods-dmobs-git 73.0e43362-2 [+0 ~0.00]
D00Med mobs mod, some animals and monsters, ie. butterfly, nyancat, golem or skeleton.
101 aur/butterflight-configurator 10.2.0-1 [+0 ~0.00] [Out-of-date: 2018-09-26]
Crossplatform configuration tool for the Butterflight flight control system
100 aur/audacious-plugins-yuune-git 2018.01.29-1 [+0 ~0.00]
Plugins for Audacious, with toolbar to bottom and hide volume button tweak
99 aur/butteraugli-git r33.g856a4da-1 [+0 ~0.00]
A tool for measuring perceived differences between images
98 aur/chrome-window-title-bar-xfwm-theme 2.0-1 [+0 ~0.00]
For those of you who would like the chrome-os window buttons
97 aur/button-lua 0.0.5-1 [+0 ~0.00]
Used with Button. Allows generating build descriptions with Lua.
96 aur/button 0.1.2-1 [+0 ~0.00]
A fast, correct, and robust build system
95 aur/mysticmine-git 2fc0a5e-2 [+0 ~0.00]
A one-button multiplayer mining cart game
94 aur/midijoystick-git a98d0d6-1 [+0 ~0.00]
JACK client to map joystick buttons to MIDI events
93 aur/plusberrypi-shutdown 1.0.2-3 [+0 ~0.00]
A systemd service for shutting down your PlusberryPi with the power button.
92 aur/morseall 0.5.0-1 [+0 ~0.00]
Morse Code UI, control your computer with one button.
91 aur/butter-git 0.1.0.r71.44fec7f-1 [+1 ~0.74]
GTK application for Btrfs snapshot management
90 aur/python-pygame-widgets 1.0.0-1 [+1 ~0.21]
A module for use with Pygame. Includes fully customisable buttons, textboxes and sliders, as well as the
ability to create and run animations on these widgets.
89 aur/gnome-shell-extension-workspaces-bar-git r15.5983c75-1 [+1 ~0.16]
GNOME Shell extension that shows workspaces buttons in top panel
88 aur/plasma5-applets-latte-sidebar-button 0.2.1-1 [+1 ~0.00]
87 aur/g15daemon-git 3.0.4.r0.g1f4e8b4-1 [+1 ~0.06]
A daemon that makes it possible to use the G-Buttons and draw on the G15 LCD
86 aur/jslisten-git 1:r48.3c84610-1 [+1 ~0.00]
This program listen in the background for gamepad inputs. If a special button combination is getting
pressed, the provided command line will be invoked.
85 aur/discordrpcmaker 2.1.1-1 [+1 ~0.00]
Discord RPC Maker lets you make and manage custom Discord Rich Presences with buttons!
84 aur/otf-keypad 1.001-1 [+1 ~0.00]
A font showing keyboard/keypad buttons
83 aur/gnome-shell-extension-hide-activities-git master.r11.2180572-2 [+1 ~0.60]
A simple GNOME Shell extension to hide the Activities button from the status bar
82 aur/turbo-button-git r3.2b98e03-1 [+1 ~0.00]
Simple tray app to toggle performance/power preference
81 aur/ssb-server 16.0.1-2 [+1 ~0.00]
The gossip and replication server for Secure Scuttlebutt - a distributed social network
80 aur/hid-sony-ds3usb-dkms 5.6.13-1 [+1 ~0.64]
The hid_sony kernel module with a patch to fix buttons on Sony DualShock 3 USB adapters
79 aur/mate-window-buttons-applet 20.04.0-1 [+1 ~0.00] [Out-of-date: 2021-10-03] [Orphaned]
An applet for mate-panel to shows the close,minimize,actions in a panel.
78 aur/emacs-buttercup 1.21-1 [+1 ~0.00] [Orphaned]
Behavior-driven development framework for testing Emacs Lisp code
77 aur/pax-britannica 20110514-2 [+1 ~0.00]
A one-button real-time strategy game for up to 4 players
76 aur/wayland-mouse-mapper-git 0.3-1 [+1 ~0.00] [Out-of-date: 2021-05-09] [Orphaned]
Maps mouse buttons to keys in wayland, configured to swap workspaces under gnome
75 aur/gnome-settings-daemon-shutdown 3.30.1.2-1 [+1 ~0.00]
The GNOME Settings daemon with shutdown button action
74 aur/butterflight-configurator-rc 10.4.3-1 [+1 ~0.00]
Crossplatform configuration tool for the Butterflight flight control system. Release Candidate.
73 aur/firefox-extension-undo-close-tab-button 1.7-1 [+1 ~0.00]
Browser extension that adds toolbar buttons for quick access to undo the closing of tabs
72 aur/gnome-shell-extension-middleclickclose-git 1.1.1-1 [+1 ~0.00]
Close windows with a button click when in overview mode
71 aur/onewireviewer 3.13.40-8 [+1 ~0.00]
demonstration application for exploring iButton or 1-Wire® chip features
70 aur/keepass-password-counter 0.1-1 [+1 ~0.00]
This plugin provides a button in the entry dialog with the number of entries that use the password of the
open entry, too. It is possible to get the complete list of entries that use the reference password.
69 aur/gnome-shell-extension-wintitle-git r19-1 [+1 ~0.00]
Shows the title of window when scrolled on the appMenu button.
68 aur/wmbutton 0.7.0-2 [+1 ~0.00]
A dockapp displaying configurable buttons
67 aur/butterfly-git r282.ec25edb-1 [+1 ~0.00]
Butterfly is a xterm compatible terminal that runs in your browser.
66 aur/maya-gtk3-theme 0.0.2-1 [+1 ~0.00] [Out-of-date: 2019-02-24]
Numix-like theme with Macbuntu buttons added.
65 aur/xfwm4-theme-hers 0.1.0-1 [+1 ~0.00] [Orphaned]
This is a slightly modified version of axiom with buttons from XGTK
64 aur/controlscontrol 0.1.0-2 [+1 ~0.00]
A simple space shooter with a plot twist - control buttons keep being changed.
63 aur/sleeptimer 0.4.2-1 [+1 ~0.00]
Simple single button lirc-aware shut down timer with an OSD
62 aur/vdrpbd-git 1-1 [+1 ~0.00]
61 aur/nwg-bar 0.1.0-1 [+2 ~0.75]
60 aur/gnome-shell-extension-mpris-indicator-button 20-1 [+2 ~1.10]
A full featured MPRIS indicator button extension for GNOME Shell 3.38+
59 aur/gnome-shell-extension-mpris-indicator-button-git r183.11af7e8-1 [+2 ~0.00]
58 aur/xgraph-bin 4.38-1 [+2 ~0.00]
XGRAPH is a general purpose x-y data plotter with interactive buttons for panning, zooming, printing, and
selecting display options.
57 aur/perl-tk-gbarr 2.08-7.2 [+2 ~0.00]
Perl/CPAN Module Tk::TFrame,Cloth,NumEntry,NumEntryPlain,FireButton
56 aur/ssb-patchwork-git 3.10.1.r301.g9750bc4d-1 [+2 ~0.00]
A decentralized messaging and sharing app built on top of Secure Scuttlebutt (SSB)
55 aur/gnome-shell-extension-bettervolume-git r38.1a66fab-1 [+2 ~0.00]
Allow better interaction with the volume indicator, via mouse scroll/middle-button.
54 aur/joydevmap-git r5.0fa6015-1 [+2 ~0.00]
a small userspace tool to change the axis and button mappings of joysticks and gamepads in Linux
53 aur/gnome-shell-extension-refresh-wifi-git 3.18.0.r5.g4ae5dad-1 [+2 ~0.00] [Out-of-date: 2021-11-22]
This extension adds a refresh button to the Wifi connection selection dialog to request for a network scan
manually.
52 aur/butter 11-1 [+2 ~0.00]
butter is a btrfs snapshot manager
51 aur/tpb 0.6.4-2 [+2 ~0.00] [Orphaned]
Access the special buttons on a ThinkPad-Laptop using xosd
50 aur/tk-resizebutton 0.01-3 [+2 ~0.00]
provides a resizeable button to be used in an HList column header.
49 aur/xfce-classiclooks 2.2.0-2 [+3 ~0.00]
The Xfce Evolution theme attempts to rid the Xfce desktop of visual distractions by providing a more
consistent look (buttons, scrollbars, menus, etc) across older and newer applications.
48 aur/antimicrox-git 3.1.3.r16.gf27aa8d0-1 [+3 ~0.00]
Map keyboard and mouse actions to gamepad buttons, inspired by qjoypad. Antimicro fork
47 aur/patchbay-git 7.14.0.r38.af7e412-1 [+3 ~0.00]
An alternative Secure Scuttlebutt client interface that is fully compatible with Patchwork
46 aur/gedit-panel-toggler 0.2.0-1 [+3 ~0.00]
Gedit 3 plugin to toggle side and bottom panels using buttons in header bar
45 aur/fittstool master-1 [+3 ~0.00]
This utility allows you to do just that - bind commands to mouse button events on the screen corners, viaa
simple and concise configuration file.
44 aur/whitebutterfly 1.1-3 [+3 ~0.00]
Wreak destruction through three pastel-shaded shmup stages.
43 aur/polymc-curseforge 1.4.1-2 [+4 ~1.87]
Adds support for Curseforge's Install button to PolyMC
42 aur/wmdrawer 0.10.5-4 [+4 ~0.00]
Dockapp with retractable button bar to launch applications
41 aur/gnome-shell-extension-no-title-bar-git v8.r20.g54ea99c-0 [+4 ~0.00]
No Title Bar removes the title bar, moves the window title and buttons to the top panel.
40 aur/sienna-git 1.0b.r0.g57bee5c-1 [+4 ~0.00]
Simple, fast-paced one-button platformer (development version)
39 aur/multimc-curseforge 1.3.1-2 [+5 ~0.07]
Adds support for Curseforge's Install button to MultiMC
38 aur/g15daemon 3.0.4-1 [+5 ~0.03]
37 aur/patchbay 8.1.0-1 [+5 ~0.00]
36 aur/oblogout-blurlock 20190226-1 [+6 ~0.00]
Systemd/OpenRC-compatible logout script for Openbox, Fluxbox and others. Including blurlock and additional
new button themes by UgoYak
35 aur/buttermanager 2.4.3-1 [+7 ~0.00]
Graphical tool to create BTRFS snapshots, balance filesystems and upgrade the system safetly
34 aur/plasma5-applets-window-buttons-git 0.9.0.r0.g4bfd361-1 [+7 ~0.00]
Plasma 5 applet in order to show window buttons in your panels
33 aur/tbe 0.9.3.1-1 [+7 ~0.00]
The Butterfly Effect is a physics-based puzzle game
32 aur/butterflow 0.2.3-1 [+8 ~0.00] [Out-of-date: 2019-03-22] [Orphaned]
Make slow motion and motion interpolated videos from the command line
31 aur/lightdm-flexiserver 1.0.0-1 [+8 ~0.00]
Shell script to relay gdmflexiserver calls, such as from the Xfce Action Buttons panel plugin's Switch
User command, to lightdm
30 aur/gnome-shell-extension-hibernate-status-git 1.10.r18.g32008bc-1 [+9 ~0.03]
GNOME Shell extension that adds a hibernate/hybrid suspend button in Status menu.
29 aur/xfce4-mpc-plugin-update 0.5.2-1 [+9 ~0.00]
Updates the toggle button icon depending on what MPD is doing
28 aur/input-remapper-git 1.4.1-1 [+10 ~3.72]
A tool to change and program the mapping of your input device buttons.
27 aur/gnome-shell-extension-suspend-button-git r24.b04fe35-1 [+10 ~0.00]
Allows to modify the suspend/shutdown button in the status menu.
26 aur/xmousepasteblock-git 1.2.r1.gec5cc5c-1 [+11 ~0.02]
Userspace tool to disable middle mouse button paste in Xorg
25 aur/scanbd 1.5.1-5 [+11 ~0.02] [Orphaned]
Scanner button daemon looking for scanner button pressed
24 aur/butterfly 3.2.5-5 [+12 ~0.00]
A sleek web based terminal emulator
23 aur/buttercup-desktop 2.14.2-2 [+13 ~0.00]
Javascript Password Vault - Multi-Platform Desktop Application
22 aur/nordic-bluish-accent-standard-buttons-theme 2.1.0-3 [+13 ~0.66]
Nord-derived themes for GTK and other platforms
21 aur/nordic-darker-standard-buttons-theme 2.1.0-3 [+13 ~0.66]
20 aur/nordic-polar-standard-buttons-theme 2.1.0-3 [+13 ~0.66]
19 aur/nordic-standard-buttons-theme 2.1.0-3 [+13 ~0.66]
18 aur/ocztoolbox 4.9.0.634-4 [+13 ~0.00]
The OCZ Toolbox is designed to update firmware and BIOS, secure erase, view SMART attributes, and view
drive details of your OCZ SSD with the click of a button.
17 aur/glui 2.36-6 [+16 ~0.00]
A GLUT-based C++ user interface library which provides controls such as buttons, checkboxes, radio
buttons, and spinners to OpenGL applications
16 aur/ssb-patchwork 3.18.1-1 [+20 ~0.01]
15 aur/gnome-shell-extension-activities-config 66-1 [+21 ~0.00] [Out-of-date: 2020-08-17]
Configure the Activities Button via the Gnome Shell Extension Preferences Tool.
14 aur/gnome-shell-extension-window-buttons-git 2.9-1 [+21 ~0.00]
Extension which puts minimize, maximize and close buttons in the top panel.
13 aur/xfce4-windowck-plugin 1:0.4.5+38+g16d4a27-1 [+27 ~0.02]
12 aur/antimicrox 3.2.3-1 [+114 ~0.71]
Graphical program used to map keyboard buttons and mouse controls to a gamepad
11 chaotic-aur/plasma5-applets-window-buttons-git 0.11.1.r0.g90e3750-1 [127.27KiB 408.37KiB]
10 chaotic-aur/plasma5-applets-latte-sidebar-button 0.2.1-1 [9.84KiB 12.49KiB]
9 chaotic-aur/nwg-bar 0.1.0-1 [1.39MiB 4.38MiB]
8 chaotic-aur/multimc-curseforge 1.3.1-2 [1.79MiB 4.00MiB]
7 chaotic-aur/input-remapper-git 1.4.2.r8.g2f24202-1 [207.40KiB 673.67KiB]
6 chaotic-aur/buttermanager 2.4.3-1 [102.21KiB 489.21KiB]
5 chaotic-aur/antimicrox 3.2.3-1 [1.37MiB 4.81MiB]
4 community/python-sphinx-copybutton 0.5.0-1 [14.61KiB 34.20KiB]
Sphinx extension to add a "copy" button to code blocks
3 community/plasma5-applets-window-buttons 0.11.1-1 [0B 352.48KiB] [Installed]
2 extra/xorg-xmodmap 1.0.10-2 [22.46KiB 49.09KiB] [Installed] (xorg-apps xorg)
Utility for modifying keymaps and button mappings
1 aur/butt 0.1.34-1 [+13 ~0.01]
Easy to use, multi OS streaming tool
:: Packages to install (eg: 1 2 3, 1-3):
:: 1
Aur (1) butt-0.1.34-1
(1/1) butt-0.1.34-1                                 [------------------------------------------------------]
/home/lightsight/.cache/paru/clone/butt/PKGBUILD
# Maintainer: linuxer <linuxer@artixlinux.org>
# Maintainer: Josef Miegl <josef@miegl.cz>
# Contributor: goll <adrian.goll+aur[at]gmail>
# Contributor: Kosava <kosava@gmail.com>
pkgname=butt
pkgver=0.1.34
pkgrel=1
pkgdesc="Easy to use, multi OS streaming tool"
arch=('i686' 'x86_64' 'aarch64' 'armv7h')
license=('GPL2')
url="http://butt.sourceforge.net/"
depends=('fltk' 'dbus' 'portaudio' 'libfdk-aac' 'libvorbis' 'libogg' 'lame' 'flac' 'opus' 'libsamplerate')
source=(${pkgname}-${pkgver}.tar.gz::"http://sourceforge.net/projects/${pkgname}/files/${pkgname}/${pkgname}->
b2sums=('2f5bf14b79805103e6d5fe72669103b1fabfa567da051225c5ab733d53d413b74c727c23ac8cf11cdb86a56f1c810c0bf452>
build() {
cd "${pkgname}-${pkgver}"
./configure --prefix=/usr
make
package() {
make DESTDIR="${pkgdir}" install
...skipping...
pkgname=butt
pkgver=0.1.34
pkgrel=1
license=('GPL2')
build() {
make
package() {
# Desktop file
install -Dm644 "usr/share/applications/${pkgname}.desktop" "${pkgdir}/usr/share/applications/${pkgname}.des>
# Icons
for size in 16 22 24 32 48 64 96 128 256 512; do
format="${size}x${size}"
install -Dm644 "icons/icon_${format}.png" "${pkgdir}/usr/share/icons/hicolor/${format}/apps/${pkgname}.pn>
done
install -Dm644 "icons/icon_scalable.svg" "${pkgdir}/usr/share/icons/hicolor/scalable/apps/${pkgname}.svg"
# Documentation
for doc in AUTHORS ChangeLog KNOWN_BUGS NEWS README THANKS; do
install -Dm644 "${doc}" "${pkgdir}/usr/share/doc/${pkgname}/${doc}"
done
# Pixmaps
for file in usr/share/pixmaps/"${pkgname}"*; do
filename=`basename "${file}"`
install -Dm644 "${file}" "${pkgdir}/usr/share/pixmaps/${filename}"
done
# vim:set ts=2 sw=2 et:
At the end of the review, if you type q it should then ask you to install, which you should answer y (yes).
Please edit your previous posts to so that your terminal output has ~~~ before and after.
terminal output example
This will make it so much easier for anyone attempting to help you.
If you have exited without installing, if you do paru -S butt it may avoid the 133 possible matches, and your output may be shorter.
< Thank You So Much @haakoth !!!! I think that was the missing info that was eluding me, im about to test... I have been adding the "3 tildas " ~~~ before and after the Terminal outputs... so i dont know why they are not showing up in all the posts i triple checked them all... I would be happy to show hopefully the final terminal/Aur output but dont want to continue to annoy those concerned... i hope to be a useful present here in continuation of future... so for now here is a pastebin ... [Namaste] > (PrivateBin)
It’s because you need to add a newline before and after. This won’t work:
~~~ text ~~~
It needs to be this:
text
That looks like it was a successful install and garuda-update. Hopefully that is now working for you and you are closer to your goal.
As to Vivox, as you noted, they do not support Linux currently. I don't have any experience in that area, add music, my suggestions would be near incompetent likely. There is almost always a Linux alternative out there though, and hope you can find it.
https://alternativeto.net/ as sample.
