I updated my laptop earlier and an issue has arisen that I’ve never had before. Prior to the update I used WiFi without issue via…
…and it was used to enable the smart bit of my TV [i.e. playing YouTube videos on my TV].
I updated my laptop with the following earlier…
hwloc-2.10.0-1 iw-6.7-1 linux-zen-6.6.8.zen1-1 linux-zen-headers-6.6.8.zen1-1 netpbm-10.86.39-2 python-setuptools-1:69.0.2-1 tzdata-2023d-1
The WiFi no longer worked, so something here caused a problem. The above software no longer created a hotspot - I checked to see if the WiFi was enabled and it was, so I’m somewhat baffled.
I have ultimately used the btrfs snapper to return my laptop to its previous state and the WiFi is working again.
If it’s a kernel problem I’ll simply wait until then next one appears before I update again.
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: hpet
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=e0aa6bf1-e32d-48b2-a659-01e4322f83f8 rw rootflags=subvol=@ quiet quiet
resume=UUID=31f5f81c-4fb3-4a39-893a-3e7c25a0feb6 loglevel=3 ibt=off
Desktop: GNOME v: 45.2 tk: GTK v: 3.24.39 wm: gnome-shell dm: GDM v: 45.0.1
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA v: 1.0
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required> UEFI: American Megatrends LLC.
v: X513UA.312 date: 04/26/2022
ID-1: BAT0 charge: 7.9 Wh (20.1%) condition: 39.4/42.1 Wh (93.7%) power: 33.7 W volts: 11.8
min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: charging cycles: 648
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x68 (104) stepping: 1 microcode: 0x8608103
desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 3206 high: 4043 min/max: 400/4056 scaling: driver: amd-pstate-epp
governor: powersave cores: 1: 4018 2: 2292 3: 2041 4: 1780 5: 4042 6: 2697 7: 3087 8: 2373
9: 4042 10: 4043 11: 4020 12: 4042 bogomips: 50308
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 45.0 C
Device-2: Quanta USB2.0 HD UVC WebCam driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 0408:30d4 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 compositor: gnome-shell
gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4161 built: 2020 res: 1920x1080 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.274 layers: 3 device: 0 type: integrated-gpu name: AMD Radeon Graphics
(RADV RENOIR) driver: mesa radv v: 23.3.1-arch1.1 device-ID: 1002:164c
surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM 16.0.6 256 bits)
driver: mesa llvmpipe v: 23.3.1-arch1.1 (LLVM 16.0.6) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.0 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: ap0 state: up mac: <filter>
IF-ID-1: enp3s0f3u3 state: up speed: 150 Mbps duplex: half mac: <filter>
IF-ID-2: wlp1s0 state: down mac: <filter>
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-2:2 chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.1 lmp-v: 10 status: discoverable: no
pairing: no
Device-2: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0032 class-ID: e001
Report: ID: hci1 rfk-id: 1 state: down bt-service: enabled,running rfk-block: hardware: no
software: yes address: <filter> bt-v: 5.3 lmp-v: 12 status: discoverable: no pairing: no
Local Storage: total: 476.94 GiB used: 18.16 GiB (3.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLQ512HALU-00000 size: 476.94 GiB
fw-rev: FXV7101Q temp: 31.9 C scheme: GPT
ID-1: / raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 7.86 GiB (5.4%) fs: btrfs
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%) used: 584 KiB (0.1%) fs: vfat
ID-3: /home raw-size: 321.45 GiB size: 321.45 GiB (100.00%) used: 10.3 GiB (3.2%) fs: btrfs
ID-4: /var/log raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 7.86 GiB (5.4%) fs: btrfs
ID-5: /var/tmp raw-size: 146.49 GiB size: 146.49 GiB (100.00%) used: 7.86 GiB (5.4%) fs: btrfs
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
maj-min: 259:3
ID-2: swap-2 type: zram size: 7.15 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
System Temperatures: cpu: 59.9 C mobo: N/A gpu: amdgpu temp: 47.0 C
Fan Speeds (rpm): cpu: 2300
Processes: 390 Uptime: 2h 28m wakeups: 0 Memory: total: 8 GiB note: est. available: 7.15 GiB
used: 3.73 GiB (52.2%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1407 libs: 431 tools: pamac,paru Client: shell wrapper
v: 5.2.21-release inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-11-17
Last full system update: 2023-12-23
Failed units: cpupower.service
