I noticed clicking on ‘GSM’ in the Garuda Welcome screen resulted in nothing popping up. So, I opened Octopi and saw that GSM and GSM-kcm were marked for an upgrade. Weird thing is I used ‘garuda-update’ in terminal and it did not show an upgrade for these two. So, I went ahead and upgraded them in Octopi and I could then open GSM once again. Very strange.
maybe you’ve ignored upgrades for these in /etc/pacman.conf
Maybe Octopi has generated its own mirrorlist? Try updating the pacman mirrolist via mirrors
, reflector or other tools/commands
Nothing wrong with pacman.conf, but I think your second comment is probably true, Octopi probably generates its own mirrorlist. I have updated mirrors, but now there is no way of testing, so I will have to keep an eye on it. Thanks.
Update #2
The update of linux-wifi-hotspot I downloaded was v4.5.0 and it worked perfectly.
I downloaded another update today - v4.7.0-1.
Guess what … it doesn’t work.
Is there any chance it can be removed from the Chaotic AUR and replaced with v4.5.0?
Exactly. Or it will if/when the ‘refresh’ icon is clicked. But it can lead to a partial upgrade situation under certain, specific situations. That said, I use it to hunt/find/install packages after setting up an initial install & config of base & a DE/WM. Even in GNOME, I dislike PAMAC so much.
It’s always the user, never the app, right?
Update #3
linux-wifi-hotspot has now been updated to v4.7.1-1. It still doesn’t work - I click the icon to start it and nothing happens.
Is there an alternative to this software which reliably creates a WiFi hotspot?
I think you can downgrade yw (or maybe install iw-git from AUR):
https://aur.archlinux.org/packages/linux-wifi-hotspot#comment-949206
I tried to uninstall iw-6.7-1 in order to downgrade to iw-git 5.19 and this was displayed…
sudo pacman -Rs iw
[sudo] password for colin:
checking dependencies...
:: removing iw breaks dependency 'iw' required by linux-wifi-hotspot
:: removing iw breaks dependency 'iw' required by wireless-regdb
I got the same error with Pamac.
But is it necessary to remove it first?
I think pacman -U
or the downgrade
command should do.
(downgrade is from downgrade package)
Or try -Rdd to remove it
downgrade iw
Since the recent iw update to 6.7, creating an AP is mostly broken. See Update frequency parsing for iw 6.7 compatibility by joanbm · Pull Request #367 · lakinduakash/linux-wifi-hotspot · GitHub. You will need to either apply the first commit from that PR or downgrade to iw 5.9.
quite curious as last release was in nov and this pr fixes a bug introduced after the kernel release when will be the next release as arch does not have any -git package.
FWIW the AUR package has a new pkgrel which already includes this patch (even though it’s not included in an official release yet) - see apply PR 367 - aur.git - AUR Package Repositories
TBH this is over my head. Is this saying that a patch is forthcoming, if it is I’ll wait for that.
Have you tried the downgrade iw anyway?
I didn’t realise this was an explanation of how to downgrade a file
Anyway, I downgraded iw to 5.19 and reinstalled the update. Still no luck.
Here’s the terminal output when I try and create a hotspot…
wihotspot
(wihotspot-gui:3951): GLib-GObject-CRITICAL **: 19:49:25.984: invalid cast from 'GtkEntry' to 'GtkTextView'
(wihotspot-gui:3951): Gtk-CRITICAL **: 19:49:25.984: gtk_text_view_get_buffer: assertion 'GTK_IS_TEXT_VIEW (text_view)' failed
(wihotspot-gui:3951): GLib-GObject-CRITICAL **: 19:49:25.985: invalid (NULL) pointer instance
(wihotspot-gui:3951): GLib-GObject-CRITICAL **: 19:49:25.985: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
/usr/bin/wihotspot: line 4: 3951 Segmentation fault (core dumped) /usr/bin/wihotspot-gui
As a footnote, here’s the terminal output after restoring the system to its previous settings…
wihotspot
(wihotspot-gui:1995): GLib-GObject-CRITICAL **: 20:01:10.409: invalid cast from 'GtkEntry' to 'GtkTextView'
(wihotspot-gui:1995): Gtk-CRITICAL **: 20:01:10.409: gtk_text_view_get_buffer: assertion 'GTK_IS_TEXT_VIEW (text_view)' failed
(wihotspot-gui:1995): GLib-GObject-CRITICAL **: 20:01:10.410: invalid (NULL) pointer instance
(wihotspot-gui:1995): GLib-GObject-CRITICAL **: 20:01:10.410: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
pkexec --user root create_ap wlp1s0 enp3s0f3u3 'Colins Hotspot' '***********' --mkconfig /etc/create_ap.conf --freq-band 2.4
Config options written to '/etc/create_ap.conf'
Hotspot works.
Less convenient, but you could just use USB phone tethering until the issue is resolved.
If you downgraded, you shouldn`t update, or at least you should put iw in IgnorePkg in /etc/pacman.conf.
I’m a luddite who doesn’t use smartphones.
I did that.
That doesn’t make you a luddite, it simply makes you privacy/security focussed.
This really looks like your error.
Would you feel like trying building from source?
Installation instructions are available (hope you have all the dependencies, since you have the package)
