Waydroid not working correctly
So I am having trouble setting up waydroid with magisk. I followed this guide Ultimate Guide to install Waydroid in any Arch-based distro(especially Garuda)
If I use zen, tkg or any kernel that is not linux-cachyos
I get this when trying to run waydroid
[20:29:51] Starting waydroid session
[gbinder] WARNING: Service manager /dev/binder has died
and this is the status of the systemd service
systemctl status waydroid-container.service
● waydroid-container.service - Waydroid Container
     Loaded: loaded (/usr/lib/systemd/system/waydroid-container.service; enabled; preset: disabled)
     Active: active (running) since Sun 2023-07-16 20:29:02 EDT; 5min ago
   Main PID: 769 (python3)
      Tasks: 6 (limit: 38370)
     Memory: 21.7M
        CPU: 204ms
     CGroup: /system.slice/waydroid-container.service
             ├─  769 python3 /usr/bin/waydroid -w container start
             └─22318 dnsmasq --conf-file=/dev/null -u dnsmasq --strict-order --bind-interfaces --pid-file=/run/waydroid-lxc/dnsmasq.pid --listen-address 192.168.240.1 --dhcp-range 192.168.240.2,192.168.240.254 -->
Jul 16 20:29:02 Garuda-Linux systemd[1]: Started Waydroid Container.
Jul 16 20:29:51 Garuda-Linux dnsmasq[22318]: started, version 2.89 cachesize 150
Jul 16 20:29:51 Garuda-Linux dnsmasq[22318]: compile time options: IPv6 GNU-getopt DBus no-UBus i18n IDN2 DHCP DHCPv6 no-Lua TFTP conntrack ipset nftset auth cryptohash DNSSEC loop-detect inotify dumpfile
Jul 16 20:29:51 Garuda-Linux dnsmasq-dhcp[22318]: DHCP, IP range 192.168.240.2 -- 192.168.240.254, lease time 1h
Jul 16 20:29:51 Garuda-Linux dnsmasq-dhcp[22318]: DHCP, sockets bound exclusively to interface waydroid0
Jul 16 20:29:51 Garuda-Linux dnsmasq[22318]: reading /etc/resolv.conf
Jul 16 20:29:51 Garuda-Linux dnsmasq[22318]: using nameserver 192.168.2.1#53
Jul 16 20:29:51 Garuda-Linux dnsmasq[22318]: using nameserver 2600:1700:5230:84d0::41#53
Jul 16 20:29:51 Garuda-Linux dnsmasq[22318]: read /etc/hosts - 12 names
Jul 16 20:29:51 Garuda-Linux waydroid[769]: [20:29:51] waiting 10 seconds for container to start...
on catchy I can run waydroid fine, but I can't install Magisk due to this issue
which says to try a different kernel, but no other kernel allows me to boot way droid (including linux-xanmod-anbox)
  Kernel: 6.4.3-273-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
    parameters: intel_pstate=passive split_lock_detect=off amd_pstate=active
    BOOT_IMAGE=/@/boot/vmlinuz-linux-linux-tkg-bmq-generic_v3
    root=UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d rw rootflags=subvol=@
    sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog
    nmi_watchdog=0 psi=1 drm.edid_firmware=HDMI-A-1:edid/LG-C2.bin
    initrd=@\boot\initramfs-linux-tkg-bmq-generic_v3.img
  Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_wayland vt: 1
    dm: N/A Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
    UEFI: American Megatrends v: P5.10 date: 10/20/2022
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3939 high: 4573 min/max: 550/4651 scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 3620 2: 4255 3: 4063
    4: 4525 5: 3609 6: 3618 7: 3618 8: 4004 9: 4164 10: 4573 11: 3639 12: 3591
    bogomips: 88896
    vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    lanes: 16 ports: active: DP-1,HDMI-A-1,HDMI-A-2 empty: DP-2
    bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
    compositor: kwin_wayland driver: N/A d-rect: 5120x2592 display-ID: 0
  Monitor-1: DP-1 pos: bottom-r res: 2048x864 size: N/A modes: N/A
  Monitor-2: HDMI-A-1 pos: primary,top-left res: 1536x864 size: N/A
    modes: N/A
  Monitor-3: HDMI-A-2 pos: middle-c res: 1536x864 size: N/A modes: N/A
  API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon RX 6700 XT (navi22
    LLVM 15.0.7 DRM 3.52 6.4.3-273-tkg-bmq) direct-render: Yes
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
  Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
    bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Sony INZONE H9 / H7
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:3 chip-ID: 054c:0e53
    class-ID: 0a00
  API: ALSA v: k6.4.3-273-tkg-bmq status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.74 status: active with: 1: pipewire-pulse
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
  Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
  IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-2: waydroid0 state: down mac: <filter>
  Device-1: Edimax Bluetooth Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:2 chip-ID: 7392:c611
  Local Storage: total: 2.96 TiB used: 4.11 TiB (139.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 40.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 37.9 C
  ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
    used: 767.37 GiB (82.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:5
    used: 27.8 MiB (9.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
  ID-1: swap-1 type: zram size: 31.26 GiB used: 512 KiB (0.0%) priority: 100
  System Temperatures: cpu: 80.2 C mobo: 38.0 C gpu: amdgpu temp: 52.0 C
    mem: 54.0 C
  Fan Speeds (RPM): cpu: 0 fan-2: 2954 fan-3: 0 fan-4: 0 fan-5: 0
    gpu: amdgpu fan: 0
  Power: 12v: N/A 5v: N/A 3.3v: 3.14 vbat: 3.28 gpu: amdgpu watts: 27.00
  Processes: 640 Uptime: 2m wakeups: 7 Memory: total: 32 GiB
  available: 31.26 GiB used: 13.08 GiB (41.9%) Init: systemd v: 253
  default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
  Packages: 2629 pm: pacman pkgs: 2600 libs: 589 tools: octopi,paru
  pm: appimage pkgs: 0 pm: flatpak pkgs: 29 Shell: fish v: 3.6.1 default: Bash
  v: 5.1.16 running-in: alacritty inxi: 3.3.28
  System install date:     2023-07-10
  Last full system update: 2023-07-16
  Failed units:            httpd.service systemd-networkd-wait-online.service
Something else that i noticed isn't working (when waydroid is starting e.g on cachy linux kernel) are games like kingdom hearts dark road
trying to install the apk just fails ( copied the apk into the waydroid contanior cuz runing waydroid app install $path_to_apk just does nothing)
You would have got your answer if you had read this :wink:,
Just yesterday only, I posted in the comments:
I did do that
cat /etc/modules-load.d/binder.conf
File: /etc/modules-load.d/binder.conf
binder_linux
second to last option I am passing right before my custom edid
cat /boot/refind_linux.conf
File: /boot/refind_linux.conf
"Boot with standard options"  "amd_pstate=active BOOT_IMAGE=/@/boot/vmlinuz-linux-%v root=UUID=53e270ad-df
d5-4874-a125-69d21ada6b8d rw rootflags=subvol=@ rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel
=3 sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog nmi_watchdog=0 psi=1 drm.edid_firmwar
e=HDMI-A-1:edid/LG-C2.bin"
"Boot to single-user mode"    "amd_pstate=active BOOT_IMAGE=/@/boot/vmlinuz-linux-%v root=UUID=53e270ad-df
=3 sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog nmi_watchdog=0 psi=1 single"
"Boot with minimal options"   "ro root=/dev/nvme0n1p2"
its also on my inxi here
The only kernel I can load Waydroid on is catchy (but then magisk doesn't work correctly) anything else causes it to fail as I said in the OP
with
Can you run xanmod?
For Zen you will have to remove binder_linux from /etc/modules-load.d/binder.conf
So I was using linux-xanmod-anbox and that didn't work tried linux-xanmod and that is indeed working actually and Magisk works as well.
I can't get Waydroid to launch on zen or tkg-bmq though tried removing /etc/modules-load.d/binder.conf and it gives me this now
when trying to run waydroid show-full-ui
[gbinder] ERROR: Can't open /dev/binder: No such file or directory
[21:55:51] Failed to add presence handler: None
tried removing psi from my kernel commands and made no difference
anyway solution is to use linux-xanmod for Waydroid with root and now that I re read the guide I do see it is actually mentioned must of missed it :man_facepalming:
oh and apps not installing was because the arm translation layer didn't get installed correctly I guess re ran the wayland-extras script and reinstalled the ndk one
So you are able to run linux-cachyos without any tweaks?
linux-zen should have worked without any tweaks, just like cachyos.
@NaN, could you confirm that Waydroid worked for you with linux_zen without any tweaks?
That's great!
Actually, I added it to the guide only after your post.
Though I had already mentioned it in the thread comments, I was waiting for a reply from
'Outdated Binder module · Issue #386 · xanmod/linux · GitHub'
to add it to the guide.
Yeah its strange on cachy, waydroid works fine (with no magisk though) with psi=1 and echo binder_linux | sudo tee /etc/modules-load.d/binder.conf haven't tried seeing if removing those 2 tweaks breaks waydroid, I thought they were needed for all kernel's
on the zen kernel and the tkg-bmq (which I think also has binder) I can't get it to work no matter what I try
it just refuses to load with either the no such file or directory error or service manager has died
These two tweaks are only supposed to be needed for kernels with binder drivers as kernel modules, not inbuilt.
Yup, no tweaks needed for me. I just had to follow the steps to load the binder modules at /dev/binder at startup and that was it.
This one?
Yeah that one.
If Zen kernel doesn't work with these
Try doing step 4 of the guide:
zen kernel still gives (after a reboot)
[19:47:48] Failed to add presence handler: None
when following the guide
cat /etc/fstab
File: /etc/fstab
# <file system>                          <mount point>  <type>  <options>  <dump>  <pass>
UUID=4AC6-7B21                            /boot/efi      vfat    umask=0077 0 2
UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d /              btrfs   subvol=/@,defaults,noatime,compress=zstd,
discard=async,ssd 0 0
UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d /home          btrfs   subvol=/@home,defaults,noatime,compress=z
std,discard=async,ssd 0 0
UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d /root          btrfs   subvol=/@root,defaults,noatime,compress=z
UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d /srv           btrfs   subvol=/@srv,defaults,noatime,compress=zs
UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d /var/cache     btrfs   subvol=/@cache,defaults,noatime,compress=
zstd,discard=async,ssd 0 0
UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d /var/log       btrfs   subvol=/@log,defaults,noatime,compress=zs
UUID=53e270ad-dfd5-4874-a125-69d21ada6b8d /var/tmp       btrfs   subvol=/@tmp,defaults,noatime,compress=zs
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
UUID=d6a92575-7181-4506-80d1-84a9594f90e8 /mnt/GAMES     auto    nosuid,nodev,nofail,x-gvfs-show 0 0
none                         /dev/binderfs binder   nofail  0      0
 ╭─zany130@Garuda in ~ via  v3.11.3 took 7ms
 ╰─λ cat /etc/tmpfiles.d/waydroid.conf
File: /etc/tmpfiles.d/waydroid.conf
d! /dev/binderfs 0755 root root
 ╭─zany130@Garuda in ~ via  v3.11.3 took 6ms
 ╰─λ cat /etc/modules-load.d/waydroid.conf
File: /etc/modules-load.d/waydroid.conf
binder_linux
It should be binder.
Edit:
I too am not able to run Waydroid with Zen :thinking:
@NaN, any hint?
Lemme check, I haven't used waydroid in a while. Currently I am traveling in a train so it would take a while for me to respond.
No worries, please you take your time.
@zany130 and @Austin I have just updated my system and also reinstalled waydroid. I am facing no issues using waydroid in linux-zen
binder
╭─siddharth@siddharth in ~ took 29ms
󰂃66%
Redacted /etc/fstab
The only reason for the failure erroneous use of binder_linux in /etc/modules-load.d/waydroid.conf instead of binder.
Oh I also do not use the psi=1 kernel parameter
for me it still gives this on zen
(didn't try a fresh install maybe that would work but then strange its working on cachy and xanmod)
[20:06:57] Failed to add presence handler: None
binder
and
File: /etc/fstab
removed all other tweaks like psi=1
=3 sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog nmi_watchdog=0 drm.edid_firmware=HDMI
=3 sysrq_always_enabled=1 amdgpu.ppfeaturemask=0xffffffff nowatchdog nmi_watchdog=0 single"
I, too am having the same issue as @zany130.
Hmm. I tried reinstalling python-gbinder & libgbinder(followed by a reboot), still, the issue persists.
I don’t know if a Waydroid reinstall should work?
Let us know if someone has the same issue on a fresh Waydroid install.
I would not want to reinstall Waydroid cause I have setup many apps that I use.
But I will do it if nobody can.
