Nope. Sway
My inxi just in case and to follow the rules:
Kernel: 6.7.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=5793ae16-f1e7-4078-a854-777471cee4e2 rw rootflags=subvol=@
loglevel=3 pcie_aspm=off ibt=off
Desktop: Sway v: 0.3.2 with: waybar tools: swayidle avail: swaylock
Type: Desktop System: Gigabyte product: Z590I AORUS ULTRA v: -CF serial: N/A
Mobo: Gigabyte model: Z590I AORUS ULTRA serial: N/A
uuid: 035e02d8-04d3-0507-bd06-3a0700080009 UEFI: American Megatrends LLC.
v: F9 date: 06/07/2023
Info: model: 11th Gen Intel Core i7-11700K socket: U3E1 bits: 64
type: MT MCP arch: Rocket Lake gen: core 11 level: v4 note: check
built: 2021+ process: Intel 14nm family: 6 model-id: 0xA7 (167)
stepping: 1 microcode: 0x5D
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 4425 high: 4703 min/max: 800/4900:5000
base/boost: 3500/8500 scaling: driver: intel_pstate governor: performance
volts: 0.9 V ext-clock: 100 MHz cores: 1: 4656 2: 4703 3: 4698 4: 4695
5: 4634 6: 4674 7: 4680 8: 4600 9: 4613 10: 4689 11: 4700 12: 800 13: 4696
14: 4677 15: 4700 16: 4600 bogomips: 115200
Device-1: Intel DG2 [Arc A750] driver: i915 v: kernel arch: Gen-12.7
code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie: gen: 1
speed: 2.5 GT/s lanes: 1 ports: active: DP-2,DP-3 empty: DP-1, DP-4,
HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 03:00.0 chip-ID: 8086:56a1
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.3:7
Display: server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositor: Sway v: 0.3.2 driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 display-ID: :1
Monitor-1: DP-2 model: Dell S2721DGF serial: <filter> built: 2022
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-2: DP-3 model: Dell U2715H serial: <filter> built: 2017
device: 1 drv: swrast surfaceless: drv: iris inactive: gbm,wayland,x11
API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 24.0.2-arch1.1
note: incomplete (EGL sourced) renderer: Mesa Intel Arc A750 Graphics
(DG2), llvmpipe (LLVM 16.0.6 256 bits)
Device-1: Intel Tiger Lake-H HD Audio vendor: Gigabyte driver: snd_hda_intel
chip-ID: 8086:43c8 class-ID: 0403
Device-2: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:4f90 class-ID: 0403
Device-4: Dell AC511 Sound Bar driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4.2:10
chip-ID: 413c:a503 class-ID: 0300
Device-5: SteelSeries ApS Arctis 5
lanes: 1 mode: 1.1 bus-ID: 1-7:8 chip-ID: 1038:12aa class-ID: 0300
API: ALSA v: k6.7.6-zen1-2-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.3 status: n/a (root, process) with:
Device-1: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 09:00.0 chip-ID: 8086:15f3
IF: enp9s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp10s0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:17 chip-ID: 8087:0029
Local Storage: total: 2.73 TiB used: 281.8 GiB (10.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 62.9 C
SMART: yes health: PASSED on: 148d 23h cycles: 514
read-units: 10,863,560 [5.56 TB] written-units: 8,006,661 [4.09 TB]
ID-2: /dev/nvme1n1 maj-min: 259:5 model: Nextorage SSD NE1N2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EIFS31.2 temp: 59.9 C
SMART: yes health: PASSED on: 97d 6h cycles: 545
read-units: 17,162,651 [8.78 TB] written-units: 12,392,949 [6.34 TB]
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 281.8 GiB (15.1%)
fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:7
used: 588 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
maj-min: 259:6
used: 281.8 GiB (15.1%) fs: btrfs block-size: 4096 B dev: /dev/nvme1n1p2
maj-min: 259:7
maj-min: 259:7
maj-min: 259:7
ID-1: swap-1 type: zram size: 31.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 62.0 C mobo: 61.0 C
Fan Speeds (rpm): cpu: 3835 mobo: 1142
Power: 12v: N/A 5v: N/A 3.3v: 3.38 vbat: 3.17
Memory: total: 32 GiB available: 31.21 GiB used: 4.85 GiB (15.5%)
Processes: 508 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: 1719 pm: pacman pkgs: 1705 libs: 466 tools: paru,yay pm: flatpak
pkgs: 14 Compilers: gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.26 running-in: tmux: inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-11-11
Last full system update: 2024-03-02
Windows dual boot: Yes
