Stuck loading initial ramdisk
OkSo this happened:
I tried to update my system. Running pacman - Syu went seemingly fine, but on reboot I get stuck with this screen below.
I tried booting the latest working snapshot, but I get an error saying there is no space left on device. I can login with tty, but can't do much with it. What should I delete to create space for the ayatem to be able to boot?
Maybe you could try to chroot from USB, free some space and retry with the snapshot?
Edit: Sorry, I didn't read you can tty...
I tried booting normally again. Now it says this:
That's progress, right? :sweat_smile:
I can't tty with the latest snapshot. I could tty with older ones and deleted some pacman pkgs, but now those olders snaps don't boot. I get an error saying I need to boot kernel first.
Same with a different kernel, if you have one?
If so, I'd reconsider the chroot
Trying the lts kernel and using nosplash on grub I get this. The kernel is crashing for some reason.
Sorry, we'll need someone more experienced here...
Meanwhile you could try to free up some space as said and maybe again pacman -Syu...
I can't do any terminal stuff cause I can't get to tty.
I'm trying to access chroot, but it says the mount point does not exist. Even though it does exist, I've checked that it does. :thinking:
I have to give up.
My only last suggestion would be to use a live USB and garuda-chroot
I always followed these indications
I'm actually trying this right now. The live usb is an amazing tool. :slight_smile: The chroot tool in the assistant automatically mounted my previous system and chrooted.
I tried to update the system this way, but it wouldn't complete it because of timeshift.
[root@garuda-kde-multimedia miikka]# pacman -Syu
 core        131.2 KiB  1381 KiB/s 00:00 [-----------------------------------------------------------------------------------------] 100%
 extra        1609.6 KiB  4.82 MiB/s 00:00 [-----------------------------------------------------------------------------------------] 100%
 community        5.5 MiB  8.75 MiB/s 00:01 [-----------------------------------------------------------------------------------------] 100%
 multilib        150.4 KiB  29.4 MiB/s 00:00 [-----------------------------------------------------------------------------------------] 100%
 chaotic-aur        969.3 KiB  1049 KiB/s 00:01 [-----------------------------------------------------------------------------------------] 100%
resolving dependencies...
Packages (56) adwaita-icon-theme-40.0-1  bbswitch-dkms-0.8-408  boost-1.75.0-3  boost-libs-1.75.0-3  botan-2.18.0-1  brltty-6.3-2  ca-certificates-mozilla-3.64-1  corectrl-1.1.1-4  enchant-2.2.15-2  gnustep-base-1.27.0-3  harfbuzz-2.8.0-3
              harfbuzz-icu-2.8.0-3  icu-69.1-1  jasper-2.0.28-1  lib32-harfbuzz-2.8.0-3  lib32-icu-69.1-1  lib32-libxml2-2.9.10-4  libcdr-0.1.7-2  libe-book-0.1.3-9  libical-3.0.9-2  libmspub-0.1.4-10  libqalculate-3.18.0-2  libqxp-0.0.2-6
              libreoffice-fresh-7.1.2-3  libsynctex-2020.54586-13  libvisio-0.1.7-5  libxml2-2.9.10-9  libzmf-0.0.2-10  linux-lts-5.10.31-1  linux-lts-headers-5.10.31-1  linux-tkg-bmq-5.11.15-148  linux-tkg-bmq-headers-5.11.15-148
              linux-zen-5.11.15.zen1-2  linux-zen-headers-5.11.15.zen1-2  mtools-4.0.27-1  nss-3.64-1  oath-toolkit-2.6.6-2  postgresql-libs-13.2-2  qca-2.3.2-2  qt5-base-5.15.2+kde+r172-2  qt5-location-5.15.2-3  qt5-svg-5.15.2+kde+r7-1
              qt5-webengine-5.15.3-4  qt5-webkit-5.212.0alpha4-10  qt6-base-6.0.3-2  raptor-2.0.15-16  samba-4.14.2-2  smbclient-4.14.2-2  texlive-bin-2020.54586-13  thunderbird-78.9.1-3  tracker3-3.1.1-2  unarchiver-1.10.7-3
              vte-common-0.64.0-2  vte3-0.64.0-2  webkit2gtk-2.32.0-2  xfsprogs-5.11.0-2
Total Download Size:    734.87 MiB
Total Installed Size:  2248.71 MiB
Net Upgrade Size:        -0.64 MiB
warning: no /var/cache/pacman/pkg/ cache exists, creating...
:: Retrieving packages...
 icu-69.1-1-x86_64        10.6 MiB  8.26 MiB/s 00:01 [-----------------------------------------------------------------------------------------]   1%
 ca-certificates-mozilla-3.64-1-x86_64        10.9 MiB  8.12 MiB/s 00:01 [-----------------------------------------------------------------------------------------]   1%
 nss-3.64-1-x86_64        12.4 MiB  8.48 MiB/s 00:01 [-----------------------------------------------------------------------------------------]   1%
 linux-lts-5.10.31-1-x86_64        87.0 MiB  13.6 MiB/s 00:06 [-----------------------------------------------------------------------------------------]  11%
 linux-lts-headers-5.10.31-1-x86_64        109.9 MiB  14.6 MiB/s 00:08 [-----------------------------------------------------------------------------------------]  14%
 xfsprogs-5.11.0-2-x86_64        111.0 MiB  14.6 MiB/s 00:08 [-----------------------------------------------------------------------------------------]  15%
 harfbuzz-2.8.0-3-x86_64        111.8 MiB  14.6 MiB/s 00:08 [-----------------------------------------------------------------------------------------]  15%
 libxml2-2.9.10-9-x86_64        113.1 MiB  14.6 MiB/s 00:08 [-----------------------------------------------------------------------------------------]  15%
 adwaita-icon-theme-40.0-1-any        123.9 MiB  14.7 MiB/s 00:08 [-----------------------------------------------------------------------------------------]  16%
 boost-libs-1.75.0-3-x86_64        126.3 MiB  14.7 MiB/s 00:09 [-----------------------------------------------------------------------------------------]  17%
 boost-1.75.0-3-x86_64        139.4 MiB  14.6 MiB/s 00:10 [-----------------------------------------------------------------------------------------]  18%
 botan-2.18.0-1-x86_64        141.9 MiB  14.5 MiB/s 00:10 [-----------------------------------------------------------------------------------------]  19%
 brltty-6.3-2-x86_64        143.5 MiB  14.5 MiB/s 00:10 [-----------------------------------------------------------------------------------------]  19%
 qt5-base-5.15.2+kde+r172-2-x86_64        156.4 MiB  14.8 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 qt5-svg-5.15.2+kde+r7-1-x86_64        156.6 MiB  14.7 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 enchant-2.2.15-2-x86_64        156.6 MiB  14.7 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 harfbuzz-icu-2.8.0-3-x86_64        156.6 MiB  14.6 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 jasper-2.0.28-1-x86_64        156.9 MiB  14.6 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 libcdr-0.1.7-2-x86_64        157.8 MiB  14.5 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 libe-book-0.1.3-9-x86_64        158.5 MiB  14.5 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 libical-3.0.9-2-x86_64        159.1 MiB  14.5 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 libmspub-0.1.4-10-x86_64        159.6 MiB  14.5 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 libqalculate-3.18.0-2-x86_64        161.6 MiB  14.5 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  21%
 libqxp-0.0.2-6-x86_64        161.9 MiB  14.4 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  22%
 libvisio-0.1.7-5-x86_64        162.5 MiB  14.4 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  22%
 libzmf-0.0.2-10-x86_64        162.7 MiB  14.4 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  22%
 raptor-2.0.15-16-x86_64        163.1 MiB  14.3 MiB/s 00:11 [-----------------------------------------------------------------------------------------]  22%
 libreoffice-fresh-7.1.2-3-x86_64        298.3 MiB  15.0 MiB/s 00:20 [-----------------------------------------------------------------------------------------]  40%
 libsynctex-2020.54586-13-x86_64        298.3 MiB  14.9 MiB/s 00:20 [-----------------------------------------------------------------------------------------]  40%
 linux-zen-5.11.15.zen1-2-x86_64        395.5 MiB  15.6 MiB/s 00:25 [-----------------------------------------------------------------------------------------]  53%
 linux-zen-headers-5.11.15.zen1-2-x86_64        419.5 MiB  15.7 MiB/s 00:27 [-----------------------------------------------------------------------------------------]  57%
 mtools-4.0.27-1-x86_64        419.7 MiB  15.7 MiB/s 00:27 [-----------------------------------------------------------------------------------------]  57%
 postgresql-libs-13.2-2-x86_64        421.1 MiB  15.7 MiB/s 00:27 [-----------------------------------------------------------------------------------------]  57%
 qca-2.3.2-2-x86_64        421.8 MiB  15.6 MiB/s 00:27 [-----------------------------------------------------------------------------------------]  57%
 qt5-location-5.15.2-3-x86_64        424.7 MiB  15.6 MiB/s 00:27 [-----------------------------------------------------------------------------------------]  57%
 qt5-webengine-5.15.3-4-x86_64        473.6 MiB  15.7 MiB/s 00:30 [-----------------------------------------------------------------------------------------]  64%
 qt5-webkit-5.212.0alpha4-10-x86_64        485.7 MiB  15.7 MiB/s 00:31 [-----------------------------------------------------------------------------------------]  66%
 qt6-base-6.0.3-2-x86_64        498.4 MiB  15.7 MiB/s 00:32 [-----------------------------------------------------------------------------------------]  67%
 smbclient-4.14.2-2-x86_64        505.4 MiB  15.7 MiB/s 00:32 [-----------------------------------------------------------------------------------------]  68%
 samba-4.14.2-2-x86_64        513.3 MiB  15.7 MiB/s 00:33 [-----------------------------------------------------------------------------------------]  69%
 texlive-bin-2020.54586-13-x86_64        527.0 MiB  15.7 MiB/s 00:34 [-----------------------------------------------------------------------------------------]  71%
 thunderbird-78.9.1-3-x86_64        571.6 MiB  15.8 MiB/s 00:36 [-----------------------------------------------------------------------------------------]  77%
 tracker3-3.1.1-2-x86_64        572.4 MiB  15.8 MiB/s 00:36 [-----------------------------------------------------------------------------------------]  77%
 vte-common-0.64.0-2-x86_64        572.4 MiB  15.7 MiB/s 00:36 [-----------------------------------------------------------------------------------------]  77%
 vte3-0.64.0-2-x86_64        572.7 MiB  15.7 MiB/s 00:36 [-----------------------------------------------------------------------------------------]  77%
 webkit2gtk-2.32.0-2-x86_64        595.9 MiB  15.8 MiB/s 00:38 [-----------------------------------------------------------------------------------------]  81%
 bbswitch-dkms-0.8-408-x86_64        595.9 MiB  15.8 MiB/s 00:38 [-----------------------------------------------------------------------------------------]  81%
 gnustep-base-1.27.0-3-x86_64        598.2 MiB  15.8 MiB/s 00:38 [-----------------------------------------------------------------------------------------]  81%
 oath-toolkit-2.6.6-2-x86_64        598.5 MiB  15.8 MiB/s 00:38 [-----------------------------------------------------------------------------------------]  81%
 unarchiver-1.10.7-3-x86_64        599.9 MiB  15.8 MiB/s 00:38 [-----------------------------------------------------------------------------------------]  81%
 lib32-harfbuzz-2.8.0-3-x86_64        600.4 MiB  15.7 MiB/s 00:38 [-----------------------------------------------------------------------------------------]  81%
 lib32-icu-69.1-1-x86_64        610.3 MiB  15.8 MiB/s 00:39 [-----------------------------------------------------------------------------------------]  83%
 lib32-libxml2-2.9.10-4-x86_64        610.9 MiB  15.7 MiB/s 00:39 [-----------------------------------------------------------------------------------------]  83%
 corectrl-1.1.1-4-x86_64        612.0 MiB  14.9 MiB/s 00:41 [-----------------------------------------------------------------------------------------]  83%
 linux-tkg-bmq-5.11.15-148-x86_64        705.3 MiB  15.0 MiB/s 00:47 [-----------------------------------------------------------------------------------------]  95%
 linux-tkg-bmq-headers-5.11.15-148-x86_64        734.9 MiB  13.4 MiB/s 00:55 [-----------------------------------------------------------------------------------------] 100%
(56/56) checking keys in keyring        [-----------------------------------------------------------------------------------------] 100%
(56/56) checking package integrity        [-----------------------------------------------------------------------------------------] 100%
(56/56) loading package files        [-----------------------------------------------------------------------------------------] 100%
(56/56) checking for file conflicts        [-----------------------------------------------------------------------------------------] 100%
(56/56) checking available disk space        [-----------------------------------------------------------------------------------------] 100%
(1/6) Creating Timeshift snapshot before upgrade...
(process:417): GLib-GIO-CRITICAL **: 18:38:38.802: g_file_get_path: assertion 'G_IS_FILE (file)' failed
** (process:417): CRITICAL **: 18:38:38.802: tee_jee_file_system_path_combine: assertion 'path1 != NULL' failed
** (process:417): CRITICAL **: 18:38:38.802: tee_jee_file_system_dir_exists: assertion 'dir_path != NULL' failed
E: System disk not found!
Removed: /var/log/timeshift/2021-03-15_22-00-01_backup.log
Removed: /var/log/timeshift/2021-03-15_22-29-21_ondemand.log
Removed: /var/log/timeshift/2021-03-15_22-29-22_delete.log
Removed: /var/log/timeshift/2021-03-15_22-29-22_list-snapshots.log
Removed: /var/log/timeshift/2021-03-15_23-00-01_backup.log
Removed: /var/log/timeshift/2021-03-16_00-00-01_backup.log
Removed: /var/log/timeshift/2021-03-16_01-00-01_backup.log
Removed: /var/log/timeshift/2021-03-16_02-00-01_backup.log
Removed: /var/log/timeshift/2021-03-16_03-00-01_backup.log
Removed: /var/log/timeshift/2021-03-16_03-01-12_list-snapshots.log
Removed: /var/log/timeshift/2021-03-16_03-01-12_ondemand.log
Removed: /var/log/timeshift/2021-03-16_03-01-13_delete.log
Removed: /var/log/timeshift/2021-03-16_04-00-01_backup.log
Removed: /var/log/timeshift/2021-03-16_05-00-01_backup.log
Removed: /var/log/timeshift/2021-03-16_23-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_00-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_01-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_02-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_03-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_04-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_05-00-02_backup.log
Removed: /var/log/timeshift/2021-03-17_06-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_19-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_20-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_21-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_22-00-01_backup.log
Removed: /var/log/timeshift/2021-03-17_23-00-01_backup.log
Removed: /var/log/timeshift/2021-03-18_00-00-02_backup.log
Removed: /var/log/timeshift/2021-03-18_01-00-01_backup.log
Removed: /var/log/timeshift/2021-03-18_02-00-01_backup.log
Removed: /var/log/timeshift/2021-03-18_03-00-01_backup.log
Removed: /var/log/timeshift/2021-03-18_04-00-02_backup.log
Removed: /var/log/timeshift/2021-03-18_05-00-01_backup.log
Removed: /var/log/timeshift/2021-03-18_06-00-01_backup.log
Removed: /var/log/timeshift/2021-03-18_15-00-01_backup.log
Removed: /var/log/timeshift/2021-03-18_16-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_00-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_01-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_02-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_03-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_04-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_05-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_06-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_14-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_15-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_16-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_17-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_22-00-01_backup.log
Removed: /var/log/timeshift/2021-03-19_23-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_00-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_01-00-02_backup.log
Removed: /var/log/timeshift/2021-03-20_02-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_03-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_04-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_05-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_06-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_07-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_08-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_09-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_10-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_11-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_12-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_13-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_14-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_15-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_16-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_17-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_18-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_19-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_20-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_21-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_22-00-01_backup.log
Removed: /var/log/timeshift/2021-03-20_23-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_00-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_01-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_02-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_03-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_04-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_05-00-02_backup.log
Removed: /var/log/timeshift/2021-03-21_06-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_07-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_07-40-12_ondemand.log
Removed: /var/log/timeshift/2021-03-21_07-40-13_delete.log
Removed: /var/log/timeshift/2021-03-21_07-40-13_list-snapshots.log
Removed: /var/log/timeshift/2021-03-21_07-53-11_list-snapshots.log
Removed: /var/log/timeshift/2021-03-21_07-53-11_ondemand.log
Removed: /var/log/timeshift/2021-03-21_07-53-12_delete.log
Removed: /var/log/timeshift/2021-03-21_15-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_16-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_17-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_18-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_19-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_20-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_21-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_22-00-01_backup.log
Removed: /var/log/timeshift/2021-03-21_23-00-01_backup.log
Removed: /var/log/timeshift/2021-03-22_00-00-01_backup.log
Removed: /var/log/timeshift/2021-03-22_01-00-01_backup.log
Removed: /var/log/timeshift/2021-03-22_02-00-01_backup.log
Removed: /var/log/timeshift/2021-03-22_02-11-35_list-snapshots.log
Older log files removed
Unable to run timeshift-autosnap! Please close Timeshift and try again. Script will now exit...
error: failed to commit transaction (failed to run transaction hooks)
Risky, but maybe you could try to temporarily disable timeshift-autosnap?
I can't find any clear instruction on how to disable it. Do I just uninstall the package?
I was thinking to:
/etc/timeshift-autosnap.conf options:
  • skipAutosnap - if set to true script won’t be executed
Ok cool, that works too. I tried just uninstalling the autosnap package for now and it seems to be running the update just fine now. Fingers crossed.
sudo SKIP_AUTOSNAP= pacman -Syu
Thanks for the help so far. Update went through, I think. I still get the same hang on loading ramdisk.
Any other ideas?
I'm trying to clear space, but it seems to do nothing. Still 0 bytes of free space.
Maybe a btrfs balance could help?
I tried to uninstall one of the kernels I don't use, just for fun. I get an error "unable to lock database" and then the regular no space left on device.
Maybe
sudo rm /var/lib/pacman/db.lck
No such file or dierectory.
