I don't know exactly what I did to create the problem but the snapshot list no longer loads in the snapper menu of BTRFS assistant and therefore I cannot create snapshots.
I assume I'm stuck in a btrfs subvolume created from the snapper menu in grub. I think so because in btrfs subvolumes I see this:
https://imgur.com/a/ykDpElz
inxi -Faz
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=53ea36ed-72a2-452d-976b-6b79d65a182f rw rootflags=subvol=@
mitigations=off acpi_enforce_resources=lax snd_hda_intel.dmic_detect=0
snd-intel-dspcfg.dsp_driver=1
Mobo: ASUSTeK model: ROG MAXIMUS XII FORMULA v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 2301 date: 07/13/2021
ID-1: hidpp_battery_0 charge: 81% condition: N/A volts: 4.0 min: N/A
serial: <filter> status: Charging
Info: model: Intel Core i9-10900K socket: LGA1200 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: 0xA5 (165) stepping: 5 microcode: 0xEC
Topology: cpus: 1x cores: 10 tpc: 2 threads: 20 smt: enabled cache:
L1: 640 KiB desc: d-10x32 KiB; i-10x32 KiB L2: 2.5 MiB desc: 10x256 KiB
L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 5246 high: 5306 min/max: 800/5300 base/boost: 3700/8300
scaling: driver: intel_pstate governor: performance volts: 1.0 V
ext-clock: 100 MHz cores: 1: 5292 2: 5266 3: 5277 4: 5298 5: 5204 6: 5295
7: 5299 8: 5213 9: 5149 10: 5298 11: 5301 12: 5069 13: 5299 14: 5306
15: 5306 16: 5098 17: 5218 18: 5158 19: 5300 20: 5278 bogomips: 147994
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Gigabyte driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b81
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.2:16 chip-ID: 046d:082d
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 7280x1440 s-dpi: 109 s-size: 1696x333mm (66.8x13.1")
s-diag: 1728mm (68")
Monitor-1: DP-0 res: 1920x1080 dpi: 92 size: 531x298mm (20.9x11.7")
diag: 609mm (24")
Monitor-2: DP-2 res: 1920x1080 hz: 60 dpi: 92
size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-3: DP-4 res: 3440x1440 hz: 50 dpi: 110
size: 797x334mm (31.4x13.1") diag: 864mm (34")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-2: NVIDIA GP104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0
Device-3: Logitech HD Pro Webcam C920 type: USB
Device-4: Generalplus USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-4:7 chip-ID: 1b3f:2008
Device-5: RODE Microphones RODE NT-USB type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 19f7:0003
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-2: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: ASUSTeK driver: atlantic v: kernel port: N/A bus-ID: 04:00.0
chip-ID: 1d6a:07b1 class-ID: 0200
Device-3: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
bus-ID: 1-14:13 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Comet Lake PCH-H RAID driver: ahci v: 3.0 port: 4020
bus-ID: 00:17.0 chip-ID: 8086:06d6 rev: class-ID: 0104
Local Storage: total: 698.66 GiB used: 43.24 GiB (6.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2B6Q temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 269d 19h cycles: 2691
written: 25.34 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
rev: 2B6Q temp: 24 C
SMART: yes state: enabled health: PASSED on: 1y 317d 6h cycles: 2966
written: 40.9 TiB
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
rev: 1B6Q temp: 24 C
SMART: yes state: enabled health: PASSED on: 3y 106d 12h cycles: 2555
written: 40.93 TiB
used: 43.24 GiB (18.6%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.16 GiB used: 2 MiB (0.0%) priority: 100
System Temperatures: cpu: 33.0 C mobo: 30.0 C gpu: nvidia temp: 34 C
Fan Speeds (RPM): fan-1: 0 fan-2: 1569 fan-3: 0 fan-4: 0 fan-5: 0
fan-6: 1127 fan-7: 0 gpu: nvidia fan: 0%
Processes: 484 Uptime: 16m wakeups: 3 Memory: 31.16 GiB
used: 5.85 GiB (18.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1682 lib: 472 Shell: Bash (su)
v: 5.1.16 running-in: konsole inxi: 3.3.12
Restore to another snapshot using grub menu (I get an infinite load).
