If this problem occurs, go into garuda-assistant(can be called with garuda-assistant from a terminal window) and select the System Components "tab" and look on the left for Virtualization. under that heading is Virt-manager, unselect it to uninstall it(make sure no vm's are running right now, i don't know what would happen) and click apply. after entering your password and going through the uninstall procedure you should be able to fully update via update or garuda-update.
after installing the update you can go back into that garuda-assistant window and recheck/reinstall virt-manager. after a reboot the "normal" virt-manager will work again.
one affected system
Kernel: 6.5.0-AMD-znver2 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver2
root=UUID=db37640e-243e-401b-9117-5ab4e247db2f rw rootflags=subvol=@
resume=UUID=26f9424d-c98e-4028-849c-9edad2ba726d loglevel=3
initcall_blacklist=acpi_cpufreq_init amd-pstate=passive options amdgpu
ppfeaturemask=0xffffffff sysrq_always_enabled=1 ibt=off
Type: Laptop System: Acer product: Aspire A515-45 v: V1.07
Mobo: LN model: Calla_LC v: V1.07 serial: <superuser required>
UEFI: INSYDE v: 1.07 date: 07/27/2021
ID-1: BAT1 charge: 46.4 Wh (100.0%) condition: 46.4/53.2 Wh (87.2%)
volts: 12.5 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: full
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 3099 high: 4372 min/max: 400/4372 boost: enabled
scaling: driver: amd-pstate governor: performance cores: 1: 2006 2: 3629
3: 3465 4: 2021 5: 1992 6: 1872 7: 2955 8: 1873 9: 1776 10: 4372 11: 4372
12: 1772 13: 4372 14: 4372 15: 4372 16: 4372 bogomips: 57517
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 60.0 C
Device-2: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2 chip-ID: 04f2:b72b
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x4999 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.6-arch1.4 renderer: AMD Radeon Graphics
(renoir LLVM 16.0.6 DRM 3.54 6.5.0-AMD-znver2) direct-render: Yes
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: N/A alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.5.0-AMD-znver2 status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.78 status: active with: 1: pipewire-pulse
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 8087:0029
Local Storage: total: 4.1 TiB used: 1.99 TiB (48.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA000 temp: 33.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT4000MX500SSD1
tech: SSD serial: <filter> fw-rev: 044 scheme: GPT
ID-1: / raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
used: 95.18 GiB (20.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 592 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-4: /var/log raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-5: /var/tmp raw-size: 460.16 GiB size: 460.16 GiB (100.00%)
ID-1: swap-1 type: zram size: 14.99 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.48 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 73.8 C mobo: N/A gpu: amdgpu temp: 59.0 C
Processes: 403 Uptime: 2m wakeups: 1 Memory: total: 16 GiB note: est.
available: 14.99 GiB used: 4.63 GiB (30.9%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2413 libs: 597 tools: octopi,pamac,paru
inxi: 3.3.29
System install date: 2022-06-28
Last full system update: 2023-08-29
