similar to https://forum.garudalinux.org/t/solved-ish-unable-to-satisfy-dependency-qemu-base-8-1-0-2-required-by-qemu-desktop/
the solution posted there works.
the problem seems to also occur on installations that are “stock”(ie no garuda-setup was run)
firstly, make sure you shut down any vm’s you may be running!!!
on the desktop, open the garuda-welcome application. inside open the garuda assistant application, under the “system components” tab uncheck(uninstall) virt-manager and press apply. after the uninstall is completed you can upgrade your system normally(garuda-update or update or upd). after upgrading go back to the virt-manager option and recheckmark it and press apply. after the reinstallation is complete reboot and your vm’s should be available.(this worked on my systems)
post solution inxi
Kernel: 6.5.4-AMD-znver2 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver2
root=UUID=af8a89ce-dde7-4f59-9555-3606af1da2d7 rw rootflags=subvol=@
loglevel=3 quiet ibt=off
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2
Type: Desktop Mobo: ASRock model: A520M-HDV serial: <superuser required>
UEFI: American Megatrends LLC. v: P3.00 date: 06/29/2023
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3842 high: 3900 min/max: 2200/4559 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3900 2: 3900
3: 3900 4: 3593 5: 3900 6: 3900 7: 3592 8: 3588 9: 3900 10: 3900 11: 3900
12: 3900 13: 3900 14: 3900 15: 3900 16: 3900 bogomips: 124630
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-4
code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2,DVI-D-1 bus-ID: 05:00.0 chip-ID: 1002:67df class-ID: 0300
temp: 54.0 C
s-diag: 1055mm (41.54")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: primary,left
model: Samsung C32F391 serial: <filter> built: 2018 res: 1920x1080 hz: 60
dpi: 70 gamma: 1.2 size: 698x393mm (27.48x15.47") diag: 801mm (31.5")
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: right model: Samsung C32F391
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 70 gamma: 1.2
size: 698x393mm (27.48x15.47") diag: 801mm (31.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 23.1.8-arch1.1 renderer: AMD Radeon RX 570 Series
(polaris10 LLVM 16.0.6 DRM 3.54 6.5.4-AMD-znver2) direct-render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:aaf0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.5.4-AMD-znver2 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: active with: 1: pipewire-pulse
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: br0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.29 TiB used: 1.58 TiB (69.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: SVN139B temp: 28.9 C
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
used: 133.93 GiB (29.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
ID-4: /var/log raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.54 GiB size: 459.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.1 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 35.5 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): fan-1: 1201 fan-2: 1523 fan-3: 0 fan-4: 0 fan-5: 0
gpu: amdgpu fan: 235
Processes: 354 Uptime: 11m wakeups: 0 Memory: total: 16 GiB
available: 15.55 GiB used: 6.81 GiB (43.8%) Init: systemd v: 254
Packages: pm: pacman pkgs: 2541 libs: 615 tools: octopi,pamac,paru
inxi: 3.3.29
System install date: 2022-05-31
Last full system update: 2023-09-22
This time It was not enough to uninstall/install virt-manager with garuda-assistant.
I had to give the following commands:
sudo pacman -nRs qemu-emulators-full
sudo pacman -nRs qemu-tools qemu-hw-s390x-virtio-gpu-ccw qemu-pr-helper
When you uninstall virt-manager the old configuration and vitual machine were not deleted.
A reboot is needed.
My garuda-inxi
Kernel: 6.5.4-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e1b87af6-67e0-4350-97cb-8bdfe430d209 rw rootflags=subvol=@
quiet
cryptdevice=UUID=735c2a29-e901-4fc7-893a-52a88bf43878:luks-735c2a29-e901-4fc7-893a-52a88bf43878
root=/dev/mapper/luks-735c2a29-e901-4fc7-893a-52a88bf43878
resume=/dev/mapper/luks-23c04b79-4698-461f-ade3-f485919f86ca loglevel=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_wayland dm: SDDM
Type: Laptop System: FUJITSU product: LIFEBOOK A544 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: FUJITSU model: FJNBB35 serial: <filter> UEFI: FUJITSU // Phoenix
v: Version 1.13 date: 11/18/2013
ID-1: BAT0 charge: 0.7 Wh (100.0%) condition: 0.7/4.5 Wh (14.8%) volts: 12.4
min: 10.8 model: PTL CP651527-01 type: Li-ion serial: <filter>
status: not charging cycles: 277
Info: model: Intel Core i7-4702MQ socket: rPGA988B (On Board) note: check
bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3 note: check
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x16
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2198 high: 2200 min/max: 800/3200 base/boost: 2200/2200
scaling: driver: intel_cpufreq governor: performance volts: 0.7 V
ext-clock: 100 MHz cores: 1: 2200 2: 2200 3: 2200 4: 2195 5: 2200 6: 2200
7: 2195 8: 2196 bogomips: 35121
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: HDMI-A-1 off: eDP-1 empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: Importek FJ Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 10f1:1a58
class-ID: 0e02
Display: server: X.Org v: 23.2.1 with: Xwayland v: 23.2.1
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.8-arch1.1 renderer: Mesa Intel HD Graphics
4600 (HSW GT2) direct-render: Yes
vendor: Fujitsu driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Fujitsu . 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
API: ALSA v: k6.5.4-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.80 status: n/a (root, process) with:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
vendor: Fujitsu driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
IF-ID-3: virbr2 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:7 chip-ID: 8087:07dc
rfk-block: hardware: no software: no address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 931.51 GiB used: 147.36 GiB (15.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 35 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 199d 22h cycles: 2056
written: 11.44 TiB
ID-1: / raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
used: 147.36 GiB (16.0%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-735c2a29-e901-4fc7-893a-52a88bf43878
used: 694 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-4: /var/log raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 551.5 MiB (7.0%)
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-23c04b79-4698-461f-ade3-f485919f86ca
System Temperatures: cpu: 61.0 C pch: 59.5 C mobo: N/A
Processes: 269 Uptime: 33m wakeups: 1 Memory: total: 8 GiB
available: 7.67 GiB used: 3.16 GiB (41.2%) igpu: 32 MiB Init: systemd v: 254
Packages: pm: pacman pkgs: 1833 libs: 424 tools: pamac,paru
inxi: 3.3.29
System install date: 2021-03-13
Total system updates: 1449
--> Updates per week: 11
sorry if there was ANY confusion, the point of my exercise was to ensure that no vm’s (or their/any configurations) were lost.
thanks for the help with this, I could now update my system
Thanks, and welcome to the forums!!
HipKat
26 September 2023 21:31
6
Yep! I remembered this from last month.
I just install qemu-desktop and then I updated my system, it’s fixed for me.
system
Closed
11 October 2023 10:28
8
