Pavucontrol is a great little utility. Use it in conjunction with Paprefs and it should work just fine. What does your experimentation with it show you?
If you mean setting with GUI, why not try?
If you mean automatic setting, this is a personalized preference and is not implemented, since it is easy to do it via classic GUI setting.
Or use a udev rule to run a script or a command.
Here is an example (you need to study about udev and experiment) https://wiki.archlinux.org/index.php/Udev#Execute_on_VGA_cable_plug_in
Being brand new to Linux, I prefer using instructions with little to no modifications, if possible. For now, every time I restart my laptop, fortunately, it is picking up the HDMI Audio Output. Thanks for the input. I'll certainly put sometime into studying udev.
Hier haben wir ein gutes Beispiel dafür welche Benutzer wir nicht im Forum unterstützen werden.
Here we have a good example of which users we will not be supporting in the forum.
[quote="Maverick, post:4, topic:2883"]
[/quote]
Well there is some reasoning behind this. Spoon feeding users can of course be done but there are no long-term benefits. The following wraps it up perfectly imo:
Eh But I can confirm, the above example of the translation does have a completely different meaning the me, first one sounds rather not serious while the seconds one doesnt
