(this is an inxi from the live usb so the kernel and plasma version are not the same as my install, I tried to get an inxi from the chroot but it came back all garbled)
misobasedir=garuda root=miso:LABEL=GARUDA_DR460NIZEDGAMING_RAPTOR quiet
systemd.show_status=1 ibt=off driver=free nouveau.modeset=1
Type: Desktop Mobo: ASRock model: X470 Taichi serial: <superuser required>
UEFI: American Megatrends v: P5.10 date: 10/20/2022
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3673 high: 3700 min/max: 2200/4686 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3700 2: 3577
3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3599 9: 3700 10: 3600 11: 3700
12: 3700 bogomips: 88803
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,HDMI-A-2 off: DP-2 empty: HDMI-A-1
bus-ID: 10:00.0 chip-ID: 1002:73df class-ID: 0300
Screen-1: 0 s-res: 4480x1080 s-dpi: 96 s-size: 1184x285mm (46.61x11.22")
s-diag: 1218mm (47.95")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: LG (GoldStar) HDR WFHD serial: <filter> built: 2021 res: 2560x1080
hz: 60 dpi: 81 gamma: 1.2 size: 798x334mm (31.42x13.15")
diag: 869mm (34.2") modes: max: 2560x1080 min: 640x480
Monitor-2: DP-2 mapped: DisplayPort-1 note: disabled
model: LG (GoldStar) TV SSCR2 serial: <filter> built: 2022 res: 2560x1080
dpi: 61 gamma: 1.2 size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3")
ratio: 16:9 modes: max: 3840x2160 min: 720x400
Monitor-3: HDMI-A-2 mapped: HDMI-A-1 pos: right
model: LG (GoldStar) FULL HD serial: <filter> built: 2023 res: 1920x1080
hz: 75 dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.63")
diag: 551mm (21.7") ratio: 16:9 modes: max: 1920x1080 min: 720x400
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6700 XT (navi22 LLVM
16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:73df memory: 11.72 GiB
unified: no
API: Vulkan v: 1.3.269 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6700 XT (RADV NAVI22) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab28
Device-2: Sony [] driver: cdc_acm,hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3
chip-ID: 054c:0e53 class-ID: 0a00
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Edimax [] driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-1.4.2:8 chip-ID: 7392:c611 class-ID: e001
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 3.7 TiB used: 755.44 GiB (20.0%)
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731120WD temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 35.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DX002-2DV164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC41 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: PNY model: USB 3.1 FD size: 57.77 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: PMAP
scheme: MBR
System Temperatures: cpu: 48.5 C mobo: 26.6 C gpu: amdgpu temp: 40.0 C
mem: 38.0 C
Fan Speeds (rpm): cpu: 1299 fan-3: 1313 fan-4: 1479 fan-5: 1234
gpu: amdgpu fan: 0
Processes: 313 Uptime: 14m wakeups: 2 Memory: total: 32 GiB
available: 31.26 GiB used: 3.6 GiB (11.5%) Init: systemd v: 254
pm: pacman pkgs: 1812 libs: 524 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.17-1):
System install date: 2024-03-13
Last full system update: 2024-03-13 ↻
after updating plasma my system no longer boots. It seems to start the kernel and everything fine (as I see the boot up messages) but then the screen goes blank (it usually does with it gets to loading sddm) and just stays there. I can’t switch to a diffrent tty or do anything. at this point I use the REISUB keys to reboot my system.
I to see if I could boot a snapshot but the snapshot menu seems to now be missing under grub.
I tried also chrooting from a live usb but when I went to inspect the systemd jorunal I got this
root@garuda-dr460nized-gaming /# journalctl
No journal files were found.
one intresting thing I noticed is if I disable the sddm systemd unit like this
systemctl disable sddm.service
I can succsesfully boot into a tty after rebooting. manually starting sddm with systemctl enable sddm.service gets me into the same broken blank screen as before so it seems its a problem with sddm
I tried the restore snapshot in the live usb but it refuses to restore my snapshot saying it “failed to make a backup of target subvolume”
