Kernel: 5.15.64-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=866e0b23-19e5-43ac-802b-ce0f5de6cac2
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma v: 5.25.4 tk: Qt v: 5.15.5 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: MONSTER product: ABRA A7 V12.5 v: N/A serial: <superuser required> Chassis:
type: 10 serial: <superuser required>
Mobo: MONSTER model: ABRA A7 V12.5 serial: <superuser required> UEFI: INSYDE v: 1.07.10TFB24
date: 12/06/2021
ID-1: BAT0 charge: 48.3 Wh (100.0%) condition: 48.3/47.2 Wh (102.4%) volts: 16.6 min: 14.4
model: Notebook BAT type: Li-ion serial: <filter> status: full
Info: model: 11th Gen Intel Core i5-11400H bits: 64 type: MT MCP arch: Tiger Lake gen: core 11
built: 2020 process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1 microcode: 0x40
Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 480 KiB desc: d-6x48
KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3079 high: 4052 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 2920 2: 2606 3: 1649 4: 3504 5: 3926 6: 3386 7: 2882 8: 4052
9: 3323 10: 2133 11: 3638 12: 2934 bogomips: 64512
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: SW
sequence
Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: CLEVO/KAPOK driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a68 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: CLEVO/KAPOK driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of 2022-07)
arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
Device-3: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 04f2:b729
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3 compositor: kwin_x11 driver: X:
loaded: intel,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: i915
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x285mm (20.00x11.22") s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x0a15 built: 2021 res: 1920x1080 hz: 144
dpi: 128 gamma: 1.2 size: 380x210mm (14.96x8.27") diag: 437mm (17.2") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT1) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Sound Server-1: ALSA v: k5.15.64-1-lts running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chi
p-ID: 8086:43f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 8087:0026
Local Storage: total: 465.76 GiB used: 12.86 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8 size: 465.76 GiB
rev: P2CR048 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 12.83 GiB (5.4%) fs: btrfs
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 29.7 MiB (30.9%) fs: vfat
ID-3: /home raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 12.83 GiB (5.4%) fs: btrfs
ID-4: /var/log raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 12.83 GiB (5.4%)
fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-5: /var/tmp raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 12.83 GiB (5.4%)
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 307 Uptime: 6m wakeups: 1 Memory: 15.41 GiB used: 3.27 GiB (21.2%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pacman: 1239 lib: 317
Client: shell wrapper v: 5.1.16-release inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-31
Last full system update: 2022-09-01
I have screen tearing, how do I fix it?
Kayo
September 1, 2022, 2:37pm
2
Your monitor is 144hz. Make sure it is set in display options is set to 144hz, and if you are experiencing the screen tearing elsewhere (like in a game), make sure the application settings are set for a respectable frame limit or to vsync.
144hz is on in settings. And still doing
Kayo
September 1, 2022, 2:42pm
4
On just the desktop even?
You can try switching to Wayland. Run
sudo pacman -S plasma-wayland-session
then logout and choose Plasma (Wayland) on login screen. If this introduces more issues, choose Plasma (X11).
I guess this solved it How can I be sure about that?
system
Closed
September 3, 2022, 4:51pm
9
Kernel: 5.19.6-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-anbox
root=UUID=866e0b23-19e5-43ac-802b-ce0f5de6cac2 rw rootflags=subvol=@ quiet quiet splash
date: 12/06/2021
ID-1: BAT0 charge: 47.3 Wh (100.0%) condition: 47.3/47.2 Wh (100.4%) volts: 16.6 min: 14.4
Speed (MHz): avg: 2697 high: 4155 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 2851 2: 2700 3: 2740 4: 1759 5: 2761 6: 4155 7: 2937 8: 2700
9: 894 10: 3293 11: 3576 12: 2004 bogomips: 64512
sequence
v: 515.65.01 alternate: nvidiafb,nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
2022-07) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie: gen: 4
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f9d class-ID: 0300
modes: 1920x1080
Sound Server-1: ALSA v: k5.19.6-xanmod1-1 running: yes
4.3
chip-ID: 8086:43f0 class-ID: 0280
Local Storage: total: 465.76 GiB used: 17.11 GiB (3.7%)
rev: P2CR048 temp: 37.9 C scheme: GPT
ID-1: / raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%) fs: btrfs
ID-3: /home raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%) fs: btrfs
ID-4: /var/log raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%)
ID-5: /var/tmp raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 17.08 GiB (7.2%)
ID-1: swap-1 type: zram size: 15.42 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 306 Uptime: 9m wakeups: 1 Memory: 15.42 GiB used: 3.81 GiB (24.7%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pacman: 1378 lib: 333
Garuda (2.6.6-1):
Last full system update: 2022-09-05
Failed units: systemd-oomd.socket
How can I fix my screen tearing?
filo
September 5, 2022, 3:17pm
13
What went wrong after this, which seems to be solved?
Type: Laptop System: MONSTER product: ABRA A7 V12.5 v: N/A serial…
I see a different kernel for example, what else?
You could try searching in the forum if there is anything that might help:
https://forum.garudalinux.org/search?q=screen%20tearing%20status%3Asolved
Also here (see “Garuda Screen Problem” thread) working on the compositor settings might help.
Garuda has the same problem in its own kernel.
And I couldn't figure it out
Does screen tearing happen on games or desktop? Battery or wall power? Does disabling compositor (shift+alt+f12) help?
It is barely noticeable in normal use. But in the screen tearing test I see
And I'm using the computer to charge
Configure your browser to run at monitor refresh rate. It is most likely running at 60 Hz instead of 144 Hz. You can also try disabling your compositor, (shift+alt+f12) switching to Wayland or enabling Vsync for the compositor. (from System Settings)
firedragon is running at 60hz, how do I make 144? It really looks like it's torn because of that.
Kernel: 5.19.7-lqx1-1-lqx arch: x86_64 bits: 64 compiler: gcc v: 12.2.0 parameters: audit=0
intel_pstate=disable hpet=disable rcupdate.rcu_expedited=1
BOOT_IMAGE=/@/boot/vmlinuz-linux-lqx root=UUID=f5ae5af2-c99a-405a-8058-4d6b8d3c8e34 rw
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.5 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
date: 12/06/2021
ID-1: BAT0 charge: 47.3 Wh (100.0%) condition: 47.3/47.2 Wh (100.4%) volts: 16.4 min: 14.4
Speed (MHz): avg: 2803 high: 3838 min/max: 800/2701 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3369 2: 1800 3: 3838 4: 2701 5: 2859
6: 2153 7: 2701 8: 3414 9: 2701 10: 2701 11: 2701 12: 2701 bogomips: 64512
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915
Monitor-1: eDP-1 model: BOE Display 0x0a15 built: 2021 res: 1920x1080 hz: 144 dpi: 128
gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9 modes: 1920x1080
Sound Server-1: ALSA v: k5.19.7-lqx1-1-lqx running: yes
l bus-ID: 00:14.3
Local Storage: total: 465.76 GiB used: 18.76 GiB (4.0%)
rev: P2CR048 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.72 GiB (7.8%) fs: btrfs
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 43.8 MiB (45.7%) fs: vfat
ID-3: /home raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.72 GiB (7.8%) fs: btrfs
ID-4: /var/log raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.72 GiB (7.8%)
ID-5: /var/tmp raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.72 GiB (7.8%)
System Temperatures: cpu: 65.0 C mobo: N/A
Processes: 336 Uptime: 21m wakeups: 1 Memory: 15.42 GiB used: 6.36 GiB (41.3%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pacman: 1539 lib: 381
Garuda (2.6.6-2):
System install date: 2022-09-07
Last full system update: 2022-09-07 ↻
Failed units: systemd-networkd-wait-online.service systemd-oomd.socket
I've been searching for days. But I couldn't come to any conclusion. Drivers are installed. I don't know exactly what caused the tear and I'm about to go crazy
https://wiki.archlinux.org/title/NVIDIA/Troubleshooting#Avoid_screen_tearing
As mentioned here, when I create a file, my computer stays on the black garuda linux startup screen.
Section "Device"
Identifier "NVIDIA Card"
Driver "nvidia"
VendorName "NVIDIA Corporation"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
Option "ForceFullCompositionPipeline" "on"
Option "AllowIndirectGLXProtocol" "off"
Option "TripleBuffer" "on"
EndSection
Or
Section "Device"
Driver "nvidia"
BoardName "NVIDIA GeForce GTX 1650 Mobile / Max-Q"
EndSection
Section "Screen"
Device "Device0"
Monitor "Monitor0"
EndSection
There is no option to set "ForceFullCompositionPipeline" "on" in Nvidia-Screen Application.
parameters: audit=0 intel_pstate=disable hpet=disable
rcupdate.rcu_expedited=1 BOOT_IMAGE=/@/boot/vmlinuz-linux-lqx
root=UUID=f5ae5af2-c99a-405a-8058-4d6b8d3c8e34 rw rootflags=subvol=@
UEFI: INSYDE v: 1.07.10TFB24 date: 12/06/2021
volts: 16.4 min: 14.4 model: Notebook BAT type: Li-ion serial: <filter>
status: full
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 7.5 MiB desc: 6x1.2 MiB
Speed (MHz): avg: 2432 high: 2701 min/max: 800/2701 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2296 2: 2448
3: 1542 4: 2701 5: 1301 6: 2701 7: 2701 8: 2701 9: 2701 10: 2701 11: 2701
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9a68
vendor: CLEVO/KAPOK driver: nvidia v: 515.65.01
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.0
chip-ID: 04f2:b729 class-ID: fe01 serial: <filter>
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
hz: 144 dpi: 128 gamma: 1.2 size: 381x214mm (15x8.43") diag: 437mm (17.2")
direct render: Yes
speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 465.76 GiB used: 18.78 GiB (4.0%)
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: P2CR048
ID-1: / raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.73 GiB
(7.8%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
(45.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.73
GiB (7.8%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.73
ID-5: /var/tmp raw-size: 238.82 GiB size: 238.82 GiB (100.00%) used: 18.73
Processes: 337 Uptime: 33m wakeups: 1 Memory: 15.42 GiB used: 6.95 GiB
(45.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1539 lib: 381 Shell: fish v: 3.5.1
Did you’ve checked the compositor settings?
Whatever application you’re using in the end it needs to go through the compositor. I had a tearing issue myself until I solved it through reactivating the compositor.
There you have a screenshot of the setting on KDE (Garuda Gaming with sweetify theme) although it is a German overlay you’ll identify the compositor settings, I guess.
You’ll find it here:
Nope,
1. you need to do a right click on your desktop background
2. and click on screen settings.
3. Choose compositor and then on the bottom of the window
you might get an information box which tells you that the compositor has deactivated some functions b/c it has detected issues. (This also counts if you have tearing issues additionally to transparency issues). But it isn't necessary to restore the compositor as I'll show you now:
Deactivate compositing click apply and then activate comp…
