I have merged several (identical and solved) threads into this one.
You have apparently solved this twice already. Please stop abusing this community.
I thought I just figured it out, sorry
Not working ![]()
You can also switch browser itself. Try using Chrome / chromium.
Also, what exactly is your issue?
Screen tearing or screen tearing during a particular test?
Screen tearing on any screen. For example in telegram, vscode. And I heard from nvidia-settings that I should do Force Composition Pipeline On, but I don't have X server settings or confugration.
Why are you working on NVIDIA stuff when your Intel iGPU is your GUI GPU?
The tearing could also be due to intel, right?
So how do I fix screen tearing on intel?
So is it tearing on the intel IGPU?
I don’t know which gpu is being used while screen tearing is happening. Either intel or nvidia
I think he is actively using intel.
glxinfo -B #Needs mesa-demos
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Intel (0x8086)
Device: Mesa Intel(R) UHD Graphics (TGL GT1) (0x9a68)
Version: 22.1.7
Accelerated: yes
Video memory: 10471MB
Unified memory: yes
Preferred profile: core (0x1)
Max core profile version: 4.6
Max compat profile version: 4.6
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) UHD Graphics (TGL GT1)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 22.1.7
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 22.1.7
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 22.1.7
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
McFly: Upgrading McFly DB to version 3, please wait...thread 'main' panicked at 'McFly error: Unable to add cmd_tpl to commands (duplicate column name: cmd_tpl)', src/history/schema.rs:41:17
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
you are on the igpu
So how do we fix screen tearing?
So this then is happening on your igpu and nvidia graphics?
If so i would boot up the live usb and see if that has tearing too just to rule out hardware?
Live usb has more tearing.
Ok then i would download say linux mint and try the live usb as this is starting to look like it is hardware?
Also check in your bios that you have it set to igpu
I installed pop os 'and no screen tearing.
