Screen tear/flickering and random temporary stutter
Hey guys, im facing some really annoying problem with my garuda. from time to time some : apps, elements from the taskbar just flickers and become glitchy and its very annoying.
If please can some body help me that would be great!
my specs :
Intel core i3 -3120M @2.5 Ghz
Intel HD graphics 4000
8gb ram ddr3
oh and btw it is the main os that i use (no vm or dual boot)
ead
please
and post
inxi -Fxxxza
as text.
and
:slight_smile:
LANGUAGE = "",
LC_ALL = (unset),
LC_MEASUREMENT = "co_FR.UTF-8",
LC_MONETARY = "en_US.UTF-8",
LC_NUMERIC = "en_US.UTF-8",
LC_TIME = "en_US.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
System:    Kernel: 5.10.19-1-lts x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=6ed4d321-7b0d-4fd6-bb0a-9e20f2ab4953
systemd.unified_cgroup_hierarchy=1 resume=UUID=da527619-c9cf-4db1-9dca-0b3ecb13162c loglevel=3
Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine:   Type: Laptop System: SAMSUNG product: 300E5EV/300E4EV/270E5EV/270E4EV v: 0.1 serial: <filter>
Chassis: type: 9 v: 0.1 serial: <filter>
Mobo: SAMSUNG model: NP270E5V-K01AE v: FAB1 serial: <filter> UEFI: Phoenix v: P05RBD
date: 05/03/2013
Battery:   ID-1: BAT1 charge: 27.5 Wh condition: 28.1/47.5 Wh (59%) volts: 12.1/10.8
model: SAMSUNG Electronics type: Li-ion serial: N/A status: Unknown cycles: 333
CPU:       Info: Dual Core model: Intel Core i3-3120M bits: 64 type: MT MCP arch: Ivy Bridge family: 6
model-id: 3A (58) stepping: 9 microcode: 21 L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19955
Speed: 2331 MHz min/max: 1200/2500 MHz Core speeds (MHz): 1: 2331 2: 2318 3: 2390 4: 1868
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0166 class ID: 0300
Device-2: Microdia Webcam SC-10HDD12636P type: USB driver: uvcvideo bus ID: 1-1.4:4
chip ID: 0c45:64e0 class ID: 0e02
Display: server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :1 screens: 1
Monitor-1: LVDS1 res: 1366x768 hz: 60 dpi: 99 size: 350x190mm (13.8x7.5") diag: 398mm (15.7")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.3.4 compat-v: 3.0
direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Samsung Co
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20 class ID: 0403
Sound Server: ALSA v: k5.10.19-1-lts
Network:   Device-1: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Samsung Co driver: ath9k
v: kernel port: efa0 bus ID: 01:00.0 chip ID: 168c:0032 class ID: 0280
IF: wlp1s0 state: down mac: <filter>
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Samsung Co driver: r8169 v: kernel
port: 2000 bus ID: 02:00.0 chip ID: 10ec:8136 class ID: 0200
Device-3: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb bus ID: 1-1.3:5
chip ID: 0cf3:3004 class ID: e001 serial: <filter>
Bluetooth: Device-1: Qualcomm Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb v: 0.8 bus ID: 1-1.3:5
Message: Required tool hciconfig not installed. Check --recommends
Drives:    Local Storage: total: 465.76 GiB used: 24.2 GiB (5.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD050 size: 465.76 GiB block size:
physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 2F
scheme: MBR
Partition: ID-1: / raw size: 450.04 GiB size: 450.04 GiB (100.00%) used: 24.2 GiB (5.4%) fs: btrfs
dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw size: 100 MiB size: 98.4 MiB (98.42%) used: 546 KiB (0.5%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 450.04 GiB size: 450.04 GiB (100.00%) used: 24.2 GiB (5.4%) fs: btrfs
ID-4: /var/log raw size: 450.04 GiB size: 450.04 GiB (100.00%) used: 24.2 GiB (5.4%) fs: btrfs
ID-5: /var/tmp raw size: 450.04 GiB size: 450.04 GiB (100.00%) used: 24.2 GiB (5.4%) fs: btrfs
Swap:      Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 1.87 GiB used: 4.5 MiB (0.2%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.87 GiB used: 4.5 MiB (0.2%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.87 GiB used: 4.5 MiB (0.2%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.87 GiB used: 4.5 MiB (0.2%) priority: 32767 dev: /dev/zram3
Sensors:   System Temperatures: cpu: 57.0 C mobo: 29.8 C
Info:      Processes: 254 Uptime: 1d 36m wakeups: 1 Memory: 7.48 GiB used: 5.1 GiB (68.3%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1464 lib: 374 Shell: fish
v: 3.1.2 default: Bash v: 5.1.4 running in: konsole inxi: 3.3.01
Your issue seems hardware related.
GPU use RAM?
KDE plasma is 5.21 but kernel is old
try zen 5.11 or other.
BIOS from 2013, update possible?
my GPU is using integrated graphics(Intel HD 4000), i mean i literally lowered the effects and the animation but that doesn't seem to work at all+ i have changed the kernel to zen 5.11.
Your issue seems is hardware related.
Sorry, seems you need better hardware or just try other Garuda DE’s like Xfce, BSPWM or … ? IDK.
From download page
Minimum requirements
  • 30 GB storage space
  • 4 GB RAM
Recommended requirements
  • 40 GB storage space
  • 8 GB RAM (<- free for CPU)
  • video card with OpenGL 3.3 or better
