My whole screen is having graphical glitches and I cannot seem to find anything in dmesg or journalctl. It started in the evening all of a sudden. There wasn't any problem with pacman updates. I had to restart lib-input-gestures as instructed in pacman but nothing else stood out during update. I checked compositor in KDE settings and nothing seems wrong there.
Searching the forum I only foudn this unresolved post. However in my case my specs are well above the requirements.
I have also tried to take screen shots of the glitches but the screen becomes fine whenever I tap print screen and flameshot opens up. It seems teh glitches only happen whenever something changes on screen. It seems to be happening as I am typing atm and the letters are appearing well after I press them. My cpu usage is maxing out at 30% according to system monitor.
inxi -Fxxxza
System: Kernel: 5.10.39-1-lts x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=6bffdc79-d9cf-4de9-a3aa-58bbfb0e7a9c rw
systemd.unified_cgroup_hierarchy=1 loglevel=3 intel_iommu=on i915.enable_gvt=1 kvm.ignore_msrs=1
intel_pstate=disable
Console: tty pts/1 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: Dell product: G3 3590 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Dell model: 0DKM3T v: A00 serial: <filter> UEFI: Dell v: 1.8.0 date: 11/11/2019
Battery: ID-1: BAT0 charge: 42.2 Wh (100.0%) condition: 42.2/51.0 Wh (82.8%) volts: 12.5 min: 11.4 model: BYD DELL M4GWP98
type: Li-poly serial: <filter> status: Full
CPU: Info: 6-Core model: Intel Core i7-9750H socket: BGA1440 (U3E1) note: check bits: 64 type: MT MCP arch: Kaby Lake
note: check family: 6 model-id: 9E (158) stepping: A (10) microcode: DE cache: L1: 384 KiB L2: 12 MiB L3: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 800 MHz min/max: 800/2601 MHz base/boost: 2600/2600 boost: enabled volts: 1.2 V ext-clock: 100 MHz
Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Graphics: Device-1: Intel UHD Graphics 630 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: Dell driver: nvidia v: 465.27
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo bus-ID: 1-5:2 chip-ID: 0bda:5521 class-ID: 0e02
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: modesetting,nvidia display-ID: :0 screens: 1
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.1.1 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Dell driver: sof-audio-pci
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0401
Device-2: NVIDIA TU116 High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.10.39-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8169 v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Dell driver: ath10k_pci v: kernel
port: 3000 bus-ID: 04:00.0 chip-ID: 168c:0042 class-ID: 0280
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-14:3 chip-ID: 0cf3:e009 class-ID: e001
Drives: Local Storage: total: 1.38 TiB used: 1.1 TiB (79.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520 NVMe WDC 512GB size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 rotation: SSD serial: <filter> rev: 20220012
temp: 44.9 C scheme: MBR
SMART: yes health: PASSED on: 162d 9h cycles: 1,308 read-units: 51,439,966 [26.3 TB]
written-units: 85,327,916 [43.6 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 family: Mobile HDD size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: ACM1
temp: 34 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 2y 58d 10h cycles: 3360 read: 52.39 TiB written: 38.52 TiB Old-Age:
g-sense error rate: 330 Pre-Fail: attribute: Spin_Retry_Count value: 100 worst: 100 threshold: 97
Partition: ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 425.48 GiB (89.3%) fs: btrfs block-size: 4096 B
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 568 KiB (0.2%) fs: vfat block-size: 512 B
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 425.48 GiB (89.3%) fs: btrfs block-size: 4096 B
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 425.48 GiB (89.3%) fs: btrfs
block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 425.48 GiB (89.3%) fs: btrfs
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 58.0 C mobo: N/A
Info: Processes: 347 Uptime: 8h 52m wakeups: 10667 Memory: 15.43 GiB used: 7.36 GiB (47.7%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1793 lib: 552 Shell: fish (sudo) v: 3.2.2
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
sudo dmesg | grep i915
[ 0.000000] Command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=6bffdc79-d9cf-4de9-a3aa-58bbfb0e7a9c rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 intel_iommu=on i915.enable_gvt=1 kvm.ignore_msrs=1 intel_pstate=disable
[ 0.032103] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=6bffdc79-d9cf-4de9-a3aa-58bbfb0e7a9c rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3 intel_iommu=on i915.enable_gvt=1 kvm.ignore_msrs=1 intel_pstate=disable
[ 1.654404] i915 0000:00:02.0: [drm] VT-d active for gfx access
[ 1.654490] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 1.654762] i915 0000:00:02.0: Direct firmware load for i915/gvt/vid_0x8086_did_0x3e9b_rid_0x00.golden_hw_state failed with error -2
[ 1.671309] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 1.672715] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ 1.705458] i915 0000:00:02.0: [drm] GuC firmware i915/kbl_guc_33.0.0.bin version 33.0 submission:disabled
[ 1.705459] i915 0000:00:02.0: [drm] HuC firmware i915/kbl_huc_4.0.0.bin version 4.0 authenticated:yes
[ 1.712828] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 0
[ 1.723282] fbcon: i915drmfb (fb0) is primary device
[ 1.723284] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ 6.029450] sof-audio-pci 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915]
sudo dmesg | grep 00:02.0 (iGPU bus id)
[ 0.253188] pci 0000:00:02.0: [8086:3e9b] type 00 class 0x030000
[ 0.253194] pci 0000:00:02.0: reg 0x10: [mem 0xa4000000-0xa4ffffff 64bit]
[ 0.253198] pci 0000:00:02.0: reg 0x18: [mem 0x80000000-0x8fffffff 64bit pref]
[ 0.253201] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ 0.253212] pci 0000:00:02.0: BAR 2: assigned to efifb
[ 0.268906] pci 0000:02:00.0: [15b7:5004] type 00 class 0x010802
[ 0.268939] pci 0000:02:00.0: reg 0x10: [mem 0xa5400000-0xa5403fff 64bit]
[ 0.290327] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.290327] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.290327] pci 0000:00:02.0: vgaarb: no bridge control possible
[ 0.395917] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.553238] pci 0000:00:02.0: Adding to iommu group 2
[ 0.553395] pci 0000:02:00.0: Adding to iommu group 15
[ 0.710054] nvme nvme0: pci function 0000:02:00.0
[ 6.029450] sof-audio-pci 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
