Previously, I used linux mint in that i used this repo GitHub - kelebek333/rtl8188fu: RTL8188FU driver for Linux 4.15.x ~ 5.11.x . Now i am completely into Garuda i can't find any repo's for it. CAn please help me to fix my wifi driver
Please help me or even suggest me a repo to install. Or any previous question like this to solve my issue.
This package is up on AUR. Seems the same.
https://aur.archlinux.org/packages/8188fu-kelebek333-dkms-git/
When i check dependencies dkms. The result of it:
dkms may be found in the following packages:
extra/dkms 2.8.4-1 /usr/bin/dkms
is it tp link one
It's not tp link. I forget the company name of dongle. But i'm sure it is Realtek RTL8188FTV. As it is shown in terminal when i use lsusb command.
Realtek Semiconductor Corp. RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
I found the driver for in arch linux user repository AUR (en) - 8188eu-aircrack-dkms-git . While installing garuda i installed with opensource drivers. But my Computer dkms dependeies is showing like this.
Please help in installating dkms
use firmware app in garuda
it almost installs everything
Search works:
Sir, I had issue with dkms. When i run dkms. It shows like this:
How to install dkms. [i installed garuda linux with open source drivers]
Please post:
inxi -Fxxxxza
Do not post a picture post the output as text.
System: Kernel: 5.12.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c42b2243-4bc0-42b4-9fca-e2bcffdc80fc
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: OEGStone product: DH61WW v: N/A serial: <filter>
Mobo: Intel model: DH61WW v: AAG23116-204 serial: <filter> BIOS: Intel
v: BEH6110H.86A.0023.2011.0524.1826 date: 05/24/2011
CPU: Info: Quad Core model: Intel Core i5-2400 bits: 64 type: MCP arch: Sandy Bridge family: 6
model-id: 2A (42) stepping: 7 microcode: 2F cache: L2: 6 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 24741
Speed: 3297 MHz min/max: 1600/3400 MHz Core speeds (MHz): 1: 3297 2: 3293 3: 3294 4: 3292
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:0102 class-ID: 0300
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel
Monitor-1: VGA1 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.1x9.1") diag: 470mm (18.5")
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1) v: 3.3 Mesa 21.1.1 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20 class-ID: 0403
Sound Server-1: ALSA v: k5.12.8-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Intel 82579V Gigabit Network driver: e1000e v: kernel port: f080 bus-ID: 00:19.0
chip-ID: 8086:1503 class-ID: 0200
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter type: USB driver: N/A
bus-ID: 2-1.6:20 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
IF-ID-1: enp0s29u1u5 state: unknown speed: N/A duplex: N/A mac: <filter>
Bluetooth: Device-1: Motorola PCS Lenovo K8 type: USB driver: rndis_host v: kernel bus-ID: 2-1.5:18
chip-ID: 22b8:2e25 class-ID: 0a00 serial: <filter>
Drives: Local Storage: total: 465.76 GiB used: 12.82 GiB (2.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: KC66 scheme: MBR
Partition: ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 12.82 GiB (2.8%) fs: btrfs
dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 12.82 GiB (2.8%) fs: btrfs
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 12.82 GiB (2.8%) fs: btrfs
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 12.82 GiB (2.8%) fs: btrfs
ID-1: swap-1 type: zram size: 958.8 MiB used: 96.6 MiB (10.1%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 958.8 MiB used: 98.5 MiB (10.3%) priority: 32767 dev: /dev/zram1
Sensors: System Temperatures: cpu: 67.0 C mobo: N/A
Info: Processes: 213 Uptime: 5h 13m wakeups: 14 Memory: 3.75 GiB used: 2.71 GiB (72.3%) Init: systemd
v: 248 tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1211 lib: 324
Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04```
Please post:
pacman -Qi dkms
Format your code blocks properly by placing three ~~~ before and after your code outputs.
╭─abhiram@abhiram010 in ~ took 5s
╰─λ pacman -Qi dkms
error: package 'dkms' was not found
Do not post a summary, post the exact input and the exact output or the post is meaningless.
Please post the full input/output of my prior command.
Sure sir, I edited the above posts.
There is no command input for either:
[htpc@htpc2 ~]$ pacman -Qi dkms
Version : 2.8.4-1
Description : Dynamic Kernel Modules System
Architecture : any
URL : https://github.com/dell/dkms
Licenses : GPL2
Groups : None
Provides : None
Depends On : bash kmod gcc make patch
Optional Deps : linux-headers: build modules against the Arch kernel
linux-lts-headers: build modules against the LTS kernel [installed]
linux-zen-headers: build modules against the ZEN kernel
linux-hardened-headers: build modules against the HARDENED kernel
Required By : None
Optional For : None
Conflicts With : None
Replaces : None
Installed Size : 176.58 KiB
Packager : Sébastien Luttringer <seblu@seblu.net>
Build Date : Fri 11 Dec 2020 12:54:28 AM
Install Date : Fri 18 Dec 2020 01:19:38 AM
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
Or:
dkms status
╰─λ pacman -Qi dkms
Now you understand how things work when troubleshooting.
You must always include the input and output.
Thank you for the proper I/O.
Please run in terminal:
sudo pacman -Syu dkms
Once your system has completed updating and dkms is properly installed, if the driver versions you have tested are not working try installing this driver version:
https://aur.archlinux.org/packages/8188eu-dkms-git
If you are still having no success, then I would advise installing the linux-lts kernel. Be sure that you also have the linux-lts-headers installed as well.
What method have you been using to install the different drivers?
Have you been installing the drivers from the AUR or the Chaotic AUR?
If the driver is available in the Chaotic AUR then be sure to test that version first.
Edited:
Changed the driver to the version you had not tested.
