Sir, I tried all the driver links which but still it is unsuccessful. When i was using linux mint i used this repo: GitHub - kelebek333/rtl8188fu: RTL8188FU driver for Linux 4.15.x ~ 5.11.x is it possible to use in garuda linux. How to build linux header in garuda linux
And the I/O of installation of driver is:
╭─abhiram@abhiram010 in ~
╰─λ git clone https://aur.archlinux.org/8188fu-dkms-git.git
fatal: destination path '8188fu-dkms-git' already exists and is not an empty directory.
╭─abhiram@abhiram010 in ~ took 1ms
[🔴] × cd 8188fu-kelebek333-dkms-git
╭─abhiram@abhiram010 in repo: 8188fu-kelebek333-dkms-git on master [!?]
╰─λ makepkg -si
==> Making package: 8188fu-kelebek333-dkms-git r87.6ac279a-1 (Tuesday 01 June 202106:43:21 AM)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving sources...
-> Updating 8188fu git repo...
Fetching origin
fatal: unable to access 'https://github.com/kelebek333/rtl8188fu.git/': Could not resolve host: github.com
error: Could not fetch origin
==> WARNING: Failure while updating 8188fu git repo
-> Found blacklist-r8188fu.conf
-> Found dkms.conf
==> Validating source files with sha256sums...
8188fu ... Skipped
blacklist-r8188fu.conf ... Passed
dkms.conf ... Passed
==> Extracting sources...
-> Creating working copy of 8188fu git repo...
Switched to a new branch 'makepkg'
==> Starting prepare()...
==> Starting pkgver()...
==> WARNING: A package has already been built, installing existing package...
==> Installing package 8188fu-kelebek333-dkms-git with pacman -U...
[sudo] password for abhiram:
loading packages...
warning: 8188fu-kelebek333-dkms-git-r87.6ac279a-1 is up to date -- reinstalling
resolving dependencies...
Packages (1) 8188fu-kelebek333-dkms-git-r87.6ac279a-1
Total Installed Size: 9.33 MiB
Net Upgrade Size: 0.00 MiB
(1/1) checking keys in keyring [------------------------] 100%
(1/1) checking package integrity [------------------------] 100%
(1/1) loading package files [------------------------] 100%
(1/1) checking for file conflicts [------------------------] 100%
(1/1) checking available disk space [------------------------] 100%
(1/2) Creating Timeshift snapshot before upgrade...
First run mode (config file not found)
Selected default snapshot type: BTRFS
Using system disk as snapshot device for creating snapshots in BTRFS mode
Mounted '/dev/sda1' at '/run/timeshift/backup'
Creating new backup...(BTRFS)
Saving to device: /dev/sda1, mounted at path: /run/timeshift/backup
Created directory: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-01_06-43-45
Created subvolume snapshot: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-01_06-43-45/@
Created control file: /run/timeshift/backup/timeshift-btrfs/snapshots/2021-06-01_06-43-45/info.json
BTRFS Snapshot saved successfully (0s)
Tagged snapshot '2021-06-01_06-43-45': ondemand
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/intel-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot: initramfs-linux-zen-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
Detecting snapshots ...
Info: Separate boot partition not detected
Found snapshot: 2021-06-01 06:43:45 | timeshift-btrfs/snapshots/2021-06-01_06-43-45/@
Found snapshot: 2021-05-31 14:41:05 | timeshift-btrfs/snapshots/2021-05-31_14-41-05/@
Found 2 snapshot(s)
done
(2/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod -m 8188fu -v r87.6ac279a -k 5.12.8-zen1-1-zen
Error! The module/version combo: 8188fu-r87.6ac279a
is not located in the DKMS tree.
(1/1) reinstalling 8188fu-kelebek333-dkms-git [------------------------] 100%
Creating symlink /var/lib/dkms/8188fu/r87.6ac279a/source ->
/usr/src/8188fu-r87.6ac279a
DKMS: add completed.
Kernel preparation unnecessary for this kernel. Skipping...
Building module:
cleaning build area...
'make' all KVER=5.12.8-zen1-1-zen..................................
Kernel cleanup unnecessary for this kernel. Skipping...
DKMS: build completed.
rtl8188fu.ko.xz:
Running module version sanity check.
- Original module
- No original module exists within this kernel
- Installation
- Installing to /usr/lib/modules/5.12.8-zen1-1-zen/kernel/drivers/net/wireless//
depmod.......
DKMS: install completed.
( 1/10) Syncing all file systems...
( 2/10) Arming ConditionNeedsUpdate...
( 3/10) Install DKMS modules
==> dkms install --no-depmod -m 8188fu -v r87.6ac279a -k 5.12.8-zen1-1-zen
==> depmod 5.12.8-zen1-1-zen
( 4/10) Foreign/AUR package notification
=> No foreign/AUR packages found.
( 5/10) Mkinitcpio and GRUB update after transactions...
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 5.12.8-zen1-1-zen
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: wd719x
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
Found 2 snapshot(s)
done
( 6/10) Orphaned package notification...
=> No orphans found.
( 7/10) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/systemd/system.conf.pacnew
/etc/systemd/user.conf.pacnew
Please check and merge
( 8/10) Updating pkgfile database...
( 9/10) Checking which packages need to be rebuilt
(10/10) Syncing all file systems...
…abhiram@abhiram010 in repo: 8188fu-kelebek333-dkms-git on master [!?] took 3m2s
╰─λ
