I connect my wifi usb adapter but wifi connection is not showing.
Kernel: 5.10.4-107-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: intel_pstate=passive
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-bmq
root=UUID=1519ba5a-3fdd-49de-93e2-5d190615d056 rw rootflags=subvol=@
resume=UUID=093ed383-cb1b-4f22-9d70-7c37a90c29bf loglevel=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Garuda Linux
Type: Desktop Mobo: Micro-Star model: A320M-A PRO MAX (MS-7C52) v: 1.0
serial: <filter> UEFI [Legacy]: American Megatrends v: 2.60
date: 06/10/2020
Info: Quad Core model: AMD Ryzen 5 3400G with Radeon Vega Graphics
bits: 64 type: MT MCP arch: Zen/Zen+ note: check family: 17 (23)
model-id: 18 (24) stepping: 1 microcode: 8108109 L2 cache: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 59263
Speed: 2861 MHz min/max: N/A Core speeds (MHz): 1: 2861 2: 3023 3: 1250
4: 1392 5: 3021 6: 2957 7: 1668 8: 2449
STIBP: disabled, RSB filling
Device-1: AMD Picasso vendor: Micro-Star MSI driver: amdgpu v: kernel
bus ID: 29:00.0 chip ID: 1002:15d8
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
s-diag: 414mm (16.3")
Monitor-1: HDMI-A-0 res: 1366x768 hz: 60 dpi: 81
size: 430x255mm (16.9x10.0") diag: 500mm (19.7")
OpenGL: renderer: AMD Radeon Vega 11 Graphics (RAVEN DRM 3.40.0
5.10.4-107-tkg-bmq LLVM 11.0.1)
v: 4.6 Mesa 20.3.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus ID: 29:00.1 chip ID: 1002:15de
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 29:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.10.4-107-tkg-bmq
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000
bus ID: 25:00.0 chip ID: 10ec:8168
IF: enp37s0 state: down mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
type: USB driver: usb-network bus ID: 3-4:3 chip ID: 0bda:f179
IF-ID-1: enp18s0f0u9 state: unknown speed: N/A duplex: N/A mac: <filter>
Local Storage: total: 447.13 GiB used: 17.73 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
size: 447.13 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: 0102
ID-1: / raw size: 100 GiB size: 100 GiB (100.00%)
used: 17.73 GiB (17.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-2: /home raw size: 100 GiB size: 100 GiB (100.00%)
ID-3: /var/log raw size: 100 GiB size: 100 GiB (100.00%)
ID-4: /var/tmp raw size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
ID-2: swap-2 type: zram size: 743.1 MiB used: 516 KiB (0.1%)
priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 743.1 MiB used: 412 KiB (0.1%)
priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 743.1 MiB used: 532 KiB (0.1%)
priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 743.1 MiB used: 436 KiB (0.1%)
priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 743.1 MiB used: 512 KiB (0.1%)
priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 743.1 MiB used: 448 KiB (0.1%)
priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 743.1 MiB used: 228 KiB (0.0%)
priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 743.1 MiB used: 244 KiB (0.0%)
priority: 32767 dev: /dev/zram7
System Temperatures: cpu: 39.6 C mobo: N/A gpu: amdgpu temp: 39.0 C
Processes: 287 Uptime: 1h 07m wakeups: 0 Memory: 5.81 GiB
used: 2.99 GiB (51.6%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: pacman: 1573 lib: 494 Shell: fish v: 3.1.2
running in: konsole inxi: 3.2.01
