Sorry if this is a really trivial topic but I rather liked the default ASCII art that came with Konsole. Somehow it’s gone now and I’m trying to restore it. I’ve tried resetting configs with Garuda assistant, I searched this forum, and tried the solution in this post:
I tried reinstalling the Konsole package in octopi. I’ve also spent a good deal of time poking around in all of the konsole settings where I learned about some cool customization options in the process but couldn’t find anything pertaining to the ASCII startup art that’s the default on Garuda.
Kernel: 5.15.50-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=285dc42e-3e8b-4156-b54a-00cb7a9ca722 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 4801
date: 03/02/2022
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3 gen: 4
built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
stepping: 2 microcode: 0xA201205
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3611 high: 3888 min/max: 2200/4950 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3888 2: 3593
3: 3592 4: 3592 5: 3592 6: 3592 7: 3585 8: 3591 9: 3591 10: 3591 11: 3592
12: 3586 13: 3740 14: 3596 15: 3592 16: 3588 17: 3660 18: 3588 19: 3592
20: 3578 21: 3586 22: 3589 23: 3587 24: 3593 bogomips: 177262
STIBP: always-on, RSB filling
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA 2
lanes: 16 ports: active: DP-2,HDMI-A-1 empty: DP-1,DP-3 bus-ID: 11:00.0
chip-ID: 1002:73bf class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: DP-2 mapped: DisplayPort-1 pos: primary,right
model: Sceptre L27 built: 2020 res: 1920x1080 dpi: 81 gamma: 1.2
size: 600x330mm (23.62x12.99") diag: 685mm (27") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: Sceptre L27
serial: <filter> built: 2020 res: 1920x1080 dpi: 81 gamma: 1.2
OpenGL: renderer: AMD Radeon RX 6900 XT (sienna_cichlid LLVM 13.0.1 DRM
3.42 5.15.50-1-lts)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
pcie: bus-ID: 3-2:3 gen: 4 chip-ID: 0d8c:0158 class-ID: 0300 speed: 16 GT/s
lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:ab28 class-ID: 0403
bus-ID: 14:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Hifi Audio type: USB
Sound Server-1: ALSA v: k5.15.50-1-lts running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 0a:00.0
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 9.1 TiB used: 28.79 GiB (0.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Smart Modular Tech.
model: SHGP31-1000GM-2 size: 931.51 GiB block-size: physical: 512 B
rev: 41062C20 temp: 45.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Smart Modular Tech.
rev: 41062C20 temp: 43.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000NE001-2MA101
type: HDD rpm: 7200 serial: <filter> rev: EN01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000NE001
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: SN07 scheme: GPT
used: 28.79 GiB (3.1%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 58.0 C
mem: 60.0 C
Processes: 472 Uptime: 52m wakeups: 0 Memory: 31.27 GiB
used: 5.93 GiB (19.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1986
lib: 550 Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-17
Last full system update: 2022-06-26 ↻
