How restore Garuda konsole settings
I know there is just konsole with some packages but due to some issues I had to restore some of the packages and it seems now the Garuda modded console came back to normal and it's ugly af. How can I restore to it's default state?
Hi there, welcome.
Not sure I understood correctly, but if you want to reset konsole config to default settings you could try
cp /etc/skel/.config/konsolerc ~/.config/konsolerc
FIxed. Apparently Garuda Assistant has a special option to reset all configs. Looks like the devs thought of everything already :))
Best distro ever
