Recent garuda update causes loading minecraft to freeze system
bit of a wild one I’ve rolled back to a prior snapshot and everything seems to work fine but when at current update. when I launch Minecraft the computer fully locks up (have to use the reset button/hard power down) right as the game would render the world there doesn’t seem to be anything meaningful in journal as far as I can tell.
Kernel: 6.16.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=0424638e-9765-44b4-a260-2d0f64442a2f rw rootflags=subvol=@
quiet resume=UUID=4cd2b771-5fa3-451c-8660-107aeb006d17 loglevel=3
Type: Desktop System: ASUS product: All Series v: N/A
Mobo: ASUSTeK model: X99-PRO/USB 3.1 v: Rev 1.xx
serial: <superuser required> part-nu: All uuid: <superuser required>
UEFI: American Megatrends v: 4101 date: 07/10/2019
Info: model: Intel Core i7-5820K bits: 64 type: MT MCP arch: Haswell
gen: core 5 level: v3 note: check built: 2013-15 process: Intel 22nm
family: 6 model-id: 0x3F (63) stepping: 2 microcode: 0x49
desc: 6x256 KiB L3: 15 MiB desc: 1x15 MiB
Speed (MHz): avg: 4080 min/max: 1200/4000 scaling: driver: intel_cpufreq
governor: performance cores: 1: 4080 2: 4080 3: 4080 4: 4080 5: 4080 6: 4080
7: 4080 8: 4080 9: 4080 10: 4080 11: 4080 12: 4080 bogomips: 80794
Device-1: NVIDIA GA102 [GeForce RTX 3070 Ti] vendor: ASUSTeK driver: nvidia
v: 580.82.09 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: DP-1,DP-2
empty: DP-3,HDMI-A-1,HDMI-A-2 bus-ID: 01:00.0 chip-ID: 10de:2207
Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-14.4:11
chip-ID: 046d:08e5 class-ID: 0102 serial: <filter>
alternate: fbdev,nouveau,nv,vesa gpu: nv_platform,nvidia,nvidia-nvswitch
d-rect: 5120x1440 display-ID: 0
Monitor-1: DP-1 pos: right model: Acer XV271U M3 serial: <filter>
built: 2023 res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 109 gamma: 1.2
max: 2560x1440 min: 640x480
Monitor-2: DP-2 pos: primary,left model: VG27AQL3A serial: <filter>
built: 2024 res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 109 gamma: 1.2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.82.09
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070 Ti/PCIe/SSE2
memory: 7.81 GiB display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 13 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3070 Ti driver: nvidia v: 580.82.09 device-ID: 10de:2207
surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 20.1.8 256 bits)
driver: mesa llvmpipe v: 25.2.3-arch1.1 (LLVM 20.1.8)
Device-1: Intel C610/X99 series HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8d20
Device-2: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef
Device-3: YUAN High-Tech Development vendor: Corsair Memory driver: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 4 bus-ID: 03:00.0 chip-ID: 12ab:0710
class-ID: 0480
Device-4: HP HyperX Cloud II Wireless
lanes: 1 mode: 1.1 bus-ID: 3-14.1:10 chip-ID: 03f0:018b class-ID: 0300
Device-5: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
Device-6: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:2
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
API: ALSA v: k6.16.7-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I218-V vendor: ASUSTeK driver: e1000e v: kernel
port: f000 bus-ID: 00:19.0 chip-ID: 8086:15a1 class-ID: 0200
Device-2: Broadcom BCM4352 802.11ac Dual Band Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel modules: bcma pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14e4:43b1 class-ID: 0280
IF: wlp5s0 state: dormant mac: <filter>
Device-1: ASUSTek BCM20702A0 driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10.1:6 chip-ID: 0b05:17cf
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 12.74 TiB used: 3.21 TiB (25.2%)
model: WD8002FZWX-00BKUA0 size: 7.28 TiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
ID-3: /dev/sdc maj-min: 8:32 vendor: Mushkin model: MKNSSDRE1TB
tech: SSD serial: <filter> fw-rev: 7C scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Toshiba model: DT01ACA200
tech: HDD rpm: 7200 serial: <filter> fw-rev: ABB0 scheme: GPT
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A82
ID-1: / raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
used: 786.25 GiB (87.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 26.3 MiB (8.8%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
ID-4: /var/log raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.85 GiB size: 896.85 GiB (100.00%)
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 58.0 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 23.75 GiB (76.0%)
Processes: 412 Power: uptime: 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.44 GiB services: org_kde_powerdevil,
Packages: 1942 pm: pacman pkgs: 1927 libs: 557 tools: octopi,paru
pm: flatpak pkgs: 15 Compilers: gcc: 15.2.1 Shell: Bash v: 5.3.3
default: fish v: 4.0.6 running-in: konsole inxi: 3.3.39
Garuda (2.8.3-2):
System install date:     2025-03-08
Last full system update: 2025-09-19
23/24 checks run in 1.28 seconds ⌛
Powered by garuda-health 🦅
this is from the restored system so pre-update I can run garuda update and provide the inxi from that or provide the list of packages from garuda update as needed.
That’d be great.
extra/bluez                                  5.83-1                  5.84-1                    0.01 MiB
extra/bluez-cups                             5.83-1                  5.84-1                    0.00 MiB
extra/bluez-hid2hci                          5.83-1                  5.84-1                    0.00 MiB
extra/bluez-libs                             5.83-1                  5.84-1                    0.00 MiB
extra/bluez-utils                            5.83-1                  5.84-1                    0.07 MiB
extra/btop                                   1.4.4-1                 1.4.5-1                   0.02 MiB
extra/btrfs-assistant                        2.2-1                   2.2-2                    -0.01 MiB
extra/deskflow                               1.23.0-1                1.24.0-1                 -0.73 MiB
extra/docker-compose                         2.39.3-1                2.39.4-1                  0.00 MiB
extra/dotnet-host                            9.0.8.sdk109-1          9.0.9.sdk110-1            0.00 MiB
extra/dotnet-runtime                         9.0.8.sdk109-1          9.0.9.sdk110-1            0.00 MiB
extra/firefox                                143.0-1                 143.0.1-1                 0.14 MiB
extra/fish                                   4.0.6-1                 4.0.8-1                   0.00 MiB
garuda/garuda-hardware-profile-nvidia        1.1.1-3                 1.1.2-1                   0.00 MiB
garuda/garuda-hardware-profile-standard      1.1.1-3                 1.1.2-1                   0.00 MiB
garuda/garuda-hardware-profile-standard-x11  1.1.1-3                 1.1.2-1                   0.00 MiB
multilib/lib32-libxml2                       2.14.6-1                2.15.0-1                 -0.04 MiB
multilib/lib32-mesa                          1:25.2.3-1              1:25.2.3-2                0.00 MiB
multilib/lib32-p11-kit                       0.25.7-1                0.25.9-1                  0.00 MiB
multilib/lib32-vulkan-intel                  1:25.2.3-1              1:25.2.3-2                0.00 MiB
multilib/lib32-vulkan-mesa-device-select                             1:25.2.3-2                0.09 MiB
multilib/lib32-vulkan-mesa-layers            1:25.2.3-1              1:25.2.3-2               -0.08 MiB
multilib/lib32-vulkan-radeon                 1:25.2.3-1              1:25.2.3-2                0.00 MiB
core/libp11-kit                              0.25.7-1                0.25.9-1                  0.00 MiB
extra/libquotient                            0.9.4-1                 0.9.5-1                   0.00 MiB
core/libtool                                 2.5.4+r62+g6389dce8-1   2.6.0-1                   0.01 MiB
core/libxml2                                 2.14.6-1                2.15.0-1                 -0.16 MiB
extra/linux-zen                              6.16.7.zen1-1           6.16.8.zen1-1             0.00 MiB
extra/linux-zen-headers                      6.16.7.zen1-1           6.16.8.zen1-1             0.28 MiB
extra/lld                                                            20.1.8-1                  6.57 MiB
core/mdadm                                   4.4-1                   4.4-2                     0.05 MiB
extra/mesa                                   1:25.2.3-1              1:25.2.3-2                0.00 MiB
extra/netstandard-targeting-pack             9.0.8.sdk109-1          9.0.9.sdk110-1            0.00 MiB
extra/openrgb                                1.0rc2-2                1.0rc2-3                 -2.14 MiB
core/p11-kit                                 0.25.7-1                0.25.9-1                  0.00 MiB
chaotic-aur/pcsx2-git                        2.5.163.r1.gedc04fb-1   2.5.166.r1.g92ede27-1     0.00 MiB
extra/python-cryptography                    45.0.7-1                46.0.1-1                  0.29 MiB
extra/python-pillow                          11.3.0-3                11.3.0-4                  0.00 MiB
extra/python-psutil                          7.0.0-1                 7.1.0-1                   0.01 MiB
extra/python-pyparsing                       3.2.4-1                 3.2.5-1                   0.00 MiB
extra/python-regex                           2025.7.34-1             2025.9.18-1               0.00 MiB
chaotic-aur/rpcs3-git                        0.0.37.r159.ge995511-1  0.0.37.r166.g9524211-1    0.00 MiB
extra/rust                                   1:1.89.0-1              1:1.90.0-2                3.29 MiB
extra/sfml                                   3.0.1-1                 3.0.2-1                  -0.36 MiB
core/systemd                                 258-1                   258-2                     0.00 MiB
core/systemd-libs                            258-1                   258-2                     0.00 MiB
core/systemd-sysvcompat                      258-1                   258-2                     0.00 MiB
extra/thunderbird                            142.0-1                 143.0-1                   0.96 MiB
extra/vulkan-intel                           1:25.2.3-1              1:25.2.3-2                0.00 MiB
extra/vulkan-mesa-device-select                                      1:25.2.3-2                0.09 MiB
extra/vulkan-mesa-layers                     1:25.2.3-1              1:25.2.3-2               -0.09 MiB
extra/vulkan-radeon                          1:25.2.3-1              1:25.2.3-2                0.00 MiB
extra/vulkan-swrast                          1:25.2.3-1              1:25.2.3-2                0.00 MiB
core/xfsprogs                                6.16.0-2                6.16.0-3                  0.00 MiB
Total Installed Size:  1772.76 MiB
Net Upgrade Size:         8.27 MiB
given when and how the hang happens I’m guessing its something in the graphics side of things oddly there’s not a nvidia driver update though
Heya, do you actively use OpenRGB? Can you try disabling the program? Thanks.
no as far as I know it shouldn’t even start with the system I use Solaar for my keyboard Id been meaning to remove it. its removed
Does that make a difference to your game post update?
If not, we will need the garuda-inxi after the update regardless.
nope still full stalled heres the Inxi on reboot.
Kernel: 6.16.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
Speed (MHz): avg: 1505 min/max: 1200/4000 scaling: driver: intel_cpufreq
governor: performance cores: 1: 1505 2: 1505 3: 1505 4: 1505 5: 1505 6: 1505
7: 1505 8: 1505 9: 1505 10: 1505 11: 1505 12: 1505 bogomips: 80799
driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM 20.1.8)
pcie: gen: 1 speed: 2.5 GT/s lanes: 4 link-max: gen: 2 speed: 5 GT/s
bus-ID: 03:00.0 chip-ID: 12ab:0710 class-ID: 0480
API: ALSA v: k6.16.8-zen1-1-zen status: kernel-api with: aoss
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
fw-rev: 0A82
used: 787.9 GiB (87.9%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
System Temperatures: cpu: 50.0 C mobo: N/A
Memory: total: 32 GiB available: 31.25 GiB used: 4.94 GiB (15.8%)
Processes: 452 Power: uptime: 1m states: freeze,mem,disk suspend: deep
Packages: 1944 pm: pacman pkgs: 1929 libs: 558 tools: octopi,paru
default: fish v: 4.0.8 running-in: konsole inxi: 3.3.39
Garuda (2.8.3-2):
Last full system update: 2025-09-21
23/24 checks run in 1.12 seconds ⌛
    root=UUID=748fc83f-8edc-436a-a837-2ebf04b7a602 rw rootflags=subvol=@
    rd.driver.pre=vfio-pci loglevel=3 iommu=1 amd_iommu=on
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-P v: Rev X.0x
    UEFI: American Megatrends v: 4021 date: 08/09/2021
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
  Speed (MHz): avg: 1754 min/max: 556/4854 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1754 2: 1754 3: 1754
    4: 1754 5: 1754 6: 1754 7: 1754 8: 1754 9: 1754 10: 1754 11: 1754 12: 1754
    13: 1754 14: 1754 15: 1754 16: 1754 bogomips: 121595
    ssse3 svm
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: ASUSTeK driver: nvidia
    status: current (as of 2025-08; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
    link-max: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1,
    DVI-D-1, DVI-D-2, HDMI-A-1 bus-ID: 04:00.0 chip-ID: 10de:1c82
  Device-2: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 580.82.09 alternate: nouveau,nvidia_drm
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-4 empty: DP-2, DP-3,
    HDMI-A-2, HDMI-A-3 bus-ID: 09:00.0 chip-ID: 10de:2504 class-ID: 0300
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:2
  Monitor-1: DP-4 model: Samsung U32J59x serial: <filter> built: 2024 res:
    mode: 3840x2160 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2
    max: 3840x2160 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 1
    drv: nvidia device: 4 drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia
    wayland: drv: nvidia x11: drv: nvidia inactive: device-2,device-3
  API: Vulkan v: 1.4.321 layers: 15 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: nvidia v: 580.82.09
    device-ID: 10de:2504 surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce GTX 1050 Ti driver: nvidia v: 580.82.09
    device-ID: 10de:1c82 surfaces: N/A device: 2 type: cpu name: llvmpipe
    (LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.3-arch1.2 (LLVM
  Device-1: NVIDIA GP107GL High Definition Audio vendor: ASUSTeK
    link-max: lanes: 16 bus-ID: 04:00.1 chip-ID: 10de:0fb9 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    bus-ID: 09:00.1 chip-ID: 10de:228e class-ID: 0403
  Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-5: Focusrite-Novation Scarlett 2i2 3rd Gen driver: snd-usb-audio
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1.4:6
    chip-ID: 1235:8210 class-ID: 0102 serial: <filter>
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 05:00.0 chip-ID: 10ec:8168
  Local Storage: total: 11.88 TiB used: 7.13 TiB (60.0%)
    fw-rev: 2B2QEXM7 temp: 51.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000VN004-3CP101
    size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: SC60 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler 3.0
    size: 57.62 GiB block-size: physical: 512 B logical: 512 B type: USB
    scheme: MBR
    used: 420.47 GiB (45.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: zram size: 31.24 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 44.5 C mobo: 45.0 C
  Fan Speeds (rpm): fan-1: 0 fan-2: 1265 fan-3: 0 fan-4: 1048 fan-5: 3146
    fan-6: 0 fan-7: 0
  Memory: total: 32 GiB available: 31.24 GiB used: 5.05 GiB (16.2%)
  Processes: 466 Power: uptime: 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.4 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 2197 libs: 603 tools: pacseek,pamac,paru,yay
    pm: flatpak pkgs: 0 Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 14 Shell: Bash
    v: 5.3.3 default: fish v: 4.0.8 running-in: konsole inxi: 3.3.39
Garuda (2.8.3-2):
  System install date:     2024-09-28
23/24 checks run in 0.84 seconds ⌛
Just did an update and my Minecraft runs with no issue
interesting the modpack I’m running is using shaders I wonder if that makes a difference the specific point my system hangs is when Minecraft would transition from the menu renderer to the world renderer on top f that I can play regular games fine which has me thinking somethings going weird in opengl rendering given most games run under proton would be using vulkan as I understand it
two additional points of data because I thought to test them vanilla does not cause the crash and turning off shaders in the modded instance does not prevent the crash my best educated guess is something in one of the 3-4 render mods required to make shaders work is whats causing the system hang but its very odd that it only causes that on an updated version of garuda none of this happens when my system is booted to a snapshot from before the update yesterday
Take a look at this topic:
so disabling embedium and affiliated mods did not fix it of some interest I did find this in the journal from the next to last crash from this
Sep 22 07:58:58 Hestia kwin_wayland[6456]: kwin_libinput: Libinput: event2  - Logitech Gaming Mouse G600: client bug: event processing lagging behind by 26ms, your system is too slow
Sep 22 07:59:11 Hestia kwin_wayland[6456]: kwin_wayland_drm: Pageflip timed out! This is a bug in the nvidia-drm kernel driver
Sep 22 07:59:11 Hestia kwin_wayland[6456]: kwin_wayland_drm: Please report this at https://forums.developer.nvidia.com/c/gpu-graphics/linux
Sep 22 07:59:11 Hestia kwin_wayland[6456]: kwin_wayland_drm: With the output of 'sudo dmesg' and 'journalctl --user-unit plasma-kwin_wayland --boot 0'
its not in the crash from my most recent test though
That’s not helpful, nor is posting only fragments of a log. How are we supposed to verify your assumption if we don’t have any logs or if it’s not clear from the log fragments what happened before?
Have you tried excluding the mesa stuff from the update (or downgrading after the update) to rule that out as the cause?
Have you tried a different kernel?
BTW: If the problem only occurs with installed mods, then it’s not a regular package that has been updated that’s to blame, but the corresponding mod.
alright I found my answeres atleast but to respond in order
there was nothing in the initial post template and I logically assumed if my entire system froze there would be something rather obvious in the system logs that snip it I found latter was on the tail end of prisma launchers initialization logs it was also not there any any other run of trying to resolve this issue
also while this is generally true the mods where not updated or modified between garuda being updated so logically the update introduced a bug either in one of the packages or made a bug present in one of the mods reveal itself
for the actual answer it seems one of the mods spark has a bug with the current built of the kernel which was reported here
I can also verify removing that specific mod solves the issue
That bug is WILD. Crashing the entire system from non-root userspace? Crazyyyyy
that’s why I thought it was something in the update itself I mean mine craft runs in java it should be off in a box that cant break anything easily the one time i’ve had something like this happen before it was on windows and it was a graphics driver bug with shaders
I’m using a Legacy driver-only, Nvidia-card myself and maybe had a similar issue.
Something recently from garuda-update also seemed to have possibly broke my fullscreen ability in DotA 2, i rolled back previous to many of the same updates you list above
… sometime around Sept 12-13 i believe was where my issue came from.
i’ve left my system alone… till now. I’m about to try to selectively re-update things from the entire list, excluding suspect ones with the ^ and all that.
Will try and report back here with more useful info.
Blahblah details of my updating habits & good exp in Garuda XFCE for +8 months now.
Hopefully it’s something simple like just one of those WINE, vulkan,or other gfx related lib updates.
it is remotely possible i had more than one issue happen but i spent many hours undoing-and re-testing that part already, (which did not fix anything btw,) and so after trying about all other stuff i could think of [kernel boots etc], in several different combinations, with intention of eliminating the idea of it being multiple issues as well,
i loaded one of my [99?] old snapshots from a day i could remember this problem was not happening … and poof, bang, boom -i was back to ‘business as usual’. :smiling_face_with_three_hearts:
I keep the 4 kernels zen, Linux LTS, CachyOS LTS, and CachyOS ready to be swapped between generally ‘in case’, and that has worked well for months i’d say… till this odd little black-screen–cant-see-but-can-hear-&-click-blindly-on-things happened.
Even doing a manual terminal “update” command about 1-2 times a day had been going smoothly and just fine before. [With exception of the rare need for stuff like a keyring update and that aur-pacman update thingie.]
So it seems quite likely something in that large set of updates around that time did something to my (admittedly older pc with an older nvidia card etc) box that had been running smooth as can be tho.
