inxi -Fxxxza
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d4d79d01-6e17-4866-8389-b984d5ad9c24 rw rootflags=subvol=@
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
Mobo: HP model: 86D5 v: 96.45 serial: <superuser required> UEFI: AMI
v: F.12 date: 12/21/2020
ID-1: BAT0 charge: 35.5 Wh (88.1%) condition: 40.3/40.3 Wh (100.0%)
volts: 12.9 min: 11.6 model: Hewlett-Packard Primary type: Li-ion
serial: N/A status: Charging cycles: 362
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1540 high: 1958 min/max: 1400/2100 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1681 2: 1958
3: 1353 4: 1588 5: 1349 6: 1827 7: 1335 8: 1230 bogomips: 33538
STIBP: disabled, RSB filling
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile
Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300
Device-3: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 3-1:2 chip-ID: 0408:5365 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x bus-ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
port: e000 bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
bus-ID: 1-4:2 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
Local Storage: total: 1.14 TiB used: 13.27 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-GSM2NE3256GNTD size: 238.47 GiB block-size: physical: 512 B
rev: EDFM20.0 temp: 11.8 C scheme: GPT
model: WD10SPZX-60Z10T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A04 scheme: GPT
ID-1: / raw-size: 50 GiB size: 50 GiB (100.00%) used: 12.97 GiB (25.9%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 576 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 97.99 GiB size: 97.99 GiB (100.00%)
used: 309.7 MiB (0.3%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 50 GiB size: 50 GiB (100.00%)
used: 12.97 GiB (25.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-5: /var/tmp raw-size: 50 GiB size: 50 GiB (100.00%)
ID-1: swap-1 type: zram size: 13.59 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 329 Uptime: 3m wakeups: 1 Memory: 13.59 GiB
used: 2.25 GiB (16.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1200 lib: 299 Shell: fish
The wifi is automatically showing limited connectivity
The wifi is showing limited connectivity automatically, reconnecting temporarily solves the problem but it occurs again.
I have done a fresh install and have tried restoring snapshots and reinstalling the OS altogether. Neither seems to work. Would appreciate any help on the issue. And respond if any other output is needed.
