There's this problem I've been having for a while. For the most part, the system runs perfectly fine. Every now and then, maybe after watching 30min or an hour of videos, on YouTube or SMPlayer, it will pause or restart randomly, stop the video, or the volume will jump up or jump down.
I tried kernels Zen and Xanmod and it happens in both.
Any idea what could be causing this? It's very occasional and random.
My computer is a Helios 300 laptop.
Kernel: 6.0.3-x64v2-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod-edge
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Desktop: KDE Plasma v: 5.27.2 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 41.7 Wh (97.9%) condition: 42.6/58.8 Wh (72.5%)
volts: 16.6 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3067 high: 4597 min/max: 800/5000 scaling:
driver: intel_pstate governor: performance cores: 1: 1378 2: 1918 3: 1959
4: 4455 5: 2569 6: 4550 7: 4439 8: 3598 9: 2600 10: 2600 11: 2147 12: 4597
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 515.76
alternate: nvidiafb,nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0408:a061 class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0x82ed
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6.0 NVIDIA 515.76 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel bus-ID: 1-1.3:6 v: kernel
alternate: snd_sof_pci_intel_cnl chip-ID: 08bb:29b0 class-ID: 0300
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC type: USB
Sound API: ALSA v: k6.0.3-x64v2-xanmod1-1 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 3.19 TiB used: 1.17 TiB (36.7%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
rev: 234200WD temp: 59.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
rev: 11101100 temp: 24.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
type: HDD rpm: 7200 serial: <filter> rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 441.9 GiB (23.9%)
fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:7
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:5
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 441.9 GiB (23.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:7
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 1.16 GiB (7.5%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:6
System Temperatures: cpu: 65.0 C pch: 78.0 C mobo: N/A gpu: nvidia
temp: 63 C
Processes: 380 Uptime: 2h 28m wakeups: 1 Memory: 15.47 GiB
used: 4.35 GiB (28.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 alt: 11 clang: 15.0.7 Packages:
pm: pacman pkgs: 2090 libs: 552 tools: octopi,pamac,paru pm: appimage
pkgs: 0 Shell: fish v: 3.6.0 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2021-11-24
Last full system update: 2023-03-04 ↻
Failed units: systemd-oomd.socket
Nobody has any idea? What component could be responsible for this?
I tried with a different keyboard, and without ckb-next service handling keyboard stuff. Issue persisted so that excludes faulty keyboard sending weird signals.
kilo
21 March 2023 13:14
3
Do you have JamesDSP running? I had some very strange issues with this in the past. I'd get YouTube videos that wouldn't start until I clicked the Audio Devices, pausing videos, weird stuff like that happening. I actually almost gave up on Garuda because of it, until I tried closing this program and the issue vanished. Unfortunately, I don't have anything based in evidence to go off of here, only personal experience. Your install date goes back to late 2021, though I'm not sure when they added/removed this audio effect processor from Garuda.
I don't have JamesDSP installed
An interesting observation. I have some audio players that I programmed myself that are running 24/7 in the background. I never experience that problem with those software (that are based on BASS audio engine ).
It only happens when YouTube or MPlayer are open, and if I close those apps, the problem immediately stops. My other players don't go jumping around in volume if neither YouTube nor MPlayer is open.
Now that that WPS Office spellcheck is fixed, this remains the only issue left to resolve.
So far I tried:
Switching kernel
Switching keyboard and closing ckb-next
Closing competing audio apps
The issue persists. Occasionally.
Is there any way I can debug what's going on behind the scene when the audio device goes berserk? I was just trying to listen to some videos and it wouldn't let me.
Perhaps we can at least identify what component(s) could be responsible?
Random Pause/Play is at the player level, not the audio driver... so does that exclude Pipewire?
My own media player apps are not affected by the problem, but they do not listen to keyboard media buttons.
Is there something that could cause bogus media keyboard buttons to be processed occasionally? As I said, I tried switching keyboard and closing ckb-next app. Perhaps the daemon was still running though.
I haven't had the issue since stopping ckb-next-daemon, the service handling Corsair keyboard, so that seems to be responsible.
I opened a ticket on the ckb-next side.
That would explain why nobody seems to have the issue; very few would use a Corsair keyboard when it's not even supported on Linux.
system
Closed
25 April 2023 19:47
9
As a follow-up to this issue.
After disabling ckb-next keyboard service, the problem occurred a lot less; but it's still happening, it seems more with Vivaldi web browser.
So it seems that the problem is triggered by something that is used by ckb-next and vivaldi. But the problem is neither of these.
NaN
28 April 2023 06:36
12
you have pulse audio installed which is known for causing conflict and issues in garuda. Remove it and reinstall pipewire following this article.
I posted this fix today for broken sound/youtube, etc. See if it works for you....
Remove all the configuration files in /etc/pipewire (sudo mv /etc/pipewire /tmp)
Reinstall pipewire, pipewire-pulse, and pipewire-media-session (sudo pacman -S pipewire pipewire-pulse pipewire-media-session)
Enable and start the relevant services (systemctl --user enable pipewire pipewire-pulse pipewire-media-session) and (systemctl --user restart pipewire pipewire-pulse pipewire-media-session). After that, my d…
pulseaudio-qt is required by: kdeconnect and libfakekey. First one is useful to have; 2nd one sounds suspicious.
Then libpulse is used by many more applications. It doesn't seem like a component that can be removed.
NaN
28 April 2023 17:18
14
I checked kdeconnect and both libfakekey and pulseaudio-qt seem to be it's dependencies.
however, pulseaudio-qt doesn't seem to be listed as pulseaudio's dependency as you can see here
Depends On : alsa-lib fftw libcap libltdl libpulse=16.1-6 libsm libsoxr libxtst orc rtkit
speexdsp tdb webrtc-audio-processing
Optional Deps : pulseaudio-alsa: ALSA configuration (recommended)
pulseaudio-bluetooth: Bluetooth support
pulseaudio-equalizer: Graphical equalizer
pulseaudio-jack: Jack support
pulseaudio-lirc: IR (lirc) support
pulseaudio-rtp: RTP and RAOP support
pulseaudio-zeroconf: Zeroconf support
are you sure you are running
pacman -Rns pulseaudio
and this is what's asking you to remove pulseaudio-qt?? because that shouldn't happen logically.
also I never had pulseaudio in my system and kdeconnect seemed to work fine however I removed it a while ago (roughly a month).
Pulseaudio package itself is not installed.
NaN
29 April 2023 12:19
16
Well I picked that information from your inxi. Could you possibly provide screenshot of the command you are running to remove pulseaudio. It could be possible you are running it with wrong spelling or something.
Can you repost your garuda-inxi again??
SGS
29 April 2023 13:03
17
Just copy the entered command including the output and post it as text.
Pictures from the terminal are unnecessary and also not desired.
I look from octopi. pulseaudio package is not installed. The only installed package that contains "pulseaudio" is pulseaudio-qt.
Here's my Inxi again
Kernel: 6.2.12-x64v1-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
ID-1: BAT1 charge: 42.5 Wh (100.0%) condition: 42.5/58.8 Wh (72.3%)
volts: 16.5 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Speed (MHz): avg: 3391 high: 3500 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 3500 2: 3302 3: 3354
4: 3500 5: 3483 6: 3500 7: 3500 8: 2600 9: 3500 10: 3462 11: 3500 12: 3500
bogomips: 62399
vendor: Acer Incorporated ALI driver: nvidia v: 530.41.03
alternate: nvidiafb,nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-2
empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
driver: snd_hda_intel v: kernel bus-ID: 1-1.3:6 chip-ID: 08bb:29b0
alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3 class-ID: 0300
API: ALSA v: k6.2.12-x64v1-xanmod1-1 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.69 status: active with: 1: pipewire-pulse
address: <filter>
Local Storage: total: 3.19 TiB used: 1.21 TiB (38.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
rev: 234200WD temp: 58.9 C scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 469.78 GiB (25.4%)
fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
used: 469.78 GiB (25.4%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
ID-1: swap-1 type: zram size: 15.45 GiB used: 2 GiB (12.9%) priority: 100
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 53.0 C pch: 72.0 C mobo: N/A gpu: nvidia
temp: 55 C
Processes: 379 Uptime: 5d 17h 0m wakeups: 1 Memory: 15.45 GiB
used: 4.39 GiB (28.4%) Init: systemd v: 253 default: graphical
pm: pacman pkgs: 2108 libs: 557 tools: octopi,pamac,paru pm: appimage
pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.26
Last full system update: 2023-04-23 ↻
NaN
29 April 2023 20:39
19
How did you even install sndiod. Anyway, you were correct it seems your new inxi doesn’t have pulseaudio anymore but does have sndiod. Please remove it.
sudo pacman -Rns sndio
You don’t need multiple sound servers. Once you are done reinstall pipewire following the post I gave before
sndio is needed by many components, including smplayer and mpv
