I have problems installing Garuda XFCE on my Dell Latitude E6340. I have 3 partitions on my hard drive, one empty, one with Windows and one with Antix. After the first installation on the empty partition I got a black screen and the message "Invalid partition table".
I reinstalled it again, now it asked me to make an EFI Fat32 partition again, I did it. I could not access it either, I did a reinstall of Grub from Antix and now I can only access Antix. From Garuda I cannot reinstall Grub.
Any advice? Thanks.
Maybe there is no solution?
Are you trying to manually partition your drives? If yes, why not let calamares automatically handle it? If you are not doing such a thing then please use your garuda live usb to provide the following details
lsblk -f
also the contents of /etc/fstab would be nice you can obtain this from either chroot or through TTY.
To chroot into your system from live usb you can either search forum for the topic chroot or just use the chroot option available in garuda's welcome application.
2 posts were split to a new topic: Problem with the latest ISO
Thank you. Here is the information. Sorry, I tried to restore grub doing chroot but I can’t do it, maybe I don’t understand the process.
Kernel: 6.1.26-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
misobasedir=garuda root=miso:LABEL=GARUDA_XFCE_RAPTOR quiet
systemd.show_status=1 ibt=off systemd.unified_cgroup_hierarchy=1
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Type: Laptop System: Dell product: Latitude E6430 v: 01
Mobo: Dell model: 0CPWYR v: A00 serial: <superuser required> BIOS: Dell
v: A22 date: 02/21/2018
ID-1: BAT0 charge: 26.3 Wh (100.0%) condition: 26.3/62.2 Wh (42.2%)
volts: 12.4 min: 11.1 model: Sanyo DELL NH6K933 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i7-3540M bits: 64 type: MT MCP arch: Ivy Bridge
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1200 min/max: 1200/3700 scaling: driver: intel_cpufreq
governor: schedutil cores: 1: 1200 2: 1200 3: 1200 4: 1200 bogomips: 23930
Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3,
VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: crocus gpu: i915
display-ID: :0.0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 model: LG Display 0x033e built: 2012 res: 1366x768
hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1366x768
missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
API: ALSA v: k6.1.26-1-lts status: kernel-api tools: N/A
Device-1: Intel 82579LM Gigabit Network vendor: Dell driver: e1000e
v: kernel port: f060 bus-ID: 00:19.0 chip-ID: 8086:1502 class-ID: 0200
Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell
driver: bcma-pci-bridge v: N/A modules: bcma pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:4727 class-ID: 0280
IF-ID-1: wlp2s0b1 state: up mac: <filter>
Local Storage: total: 247.34 GiB used: 4.16 GiB (1.7%)
ID-1: /dev/sda maj-min: 8:0 type: USB vendor: Toshiba model: TransMemory
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
model: WDS250G2B0A-00SM50 size: 232.89 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: MBR
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: 38.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 2698
Processes: 226 Uptime: 19m wakeups: 1 Memory: 7.67 GiB used: 2.4 GiB (31.3%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1286 libs: 359 tools: paru
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.26
System install date: 2023-08-19
Last full system update: 2023-08-19 ↻
/miso/bootmnt
└─sda2
vfat FAT12 MISO_EFI
3126-4D58
sdb
├─sdb1
│ vfat FAT32 552D-739B
├─sdb2
│ ntfs SYSTEM
│ 4858A27A58A26682
├─sdb3
│ ext4 1.0 rootantiX21
│ c2dcb6c9-9994-48ea-a960-54686d4b19f2
├─sdb4
└─sdb5
btrfs 05c90dcc-bb1d-45a2-846d-572e9fb6eb56 78.3G 5% /mnt
sr0
zram0
[SWAP]
╭─garuda@garuda in ~ as 🧙 took 12ms
╰─λ
# /etc/fstab: static file system information
# <file system> <dir> <type> <options> <dump> <pass>
/dev/mapper/root-image / auto defaults 0 0
Well, it seems I got it right, I installed Grub by doing grub-install /dev/sdb, I can now access Garuda, however it recognizes Antix but not Windows.
Is this really the fstab entry from the chroot terminal? because if it is then it’s empty there is no mount point for any subvolumes created at all which would explain why you can’t boot into your system.
- enter chroot, don’t bother with repairing grub.
- using your favorite text editor in terminal open the
/etc/fstabfile. garuda comes withmicroandnanoby default so you can use them or download something of your choice likevimusing pacman. - make sure your
fstabentry is similar to this
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=xxxx-xxxx /boot/efi vfat umask=0077 0 2
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx / btrfs subvol=/@,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx /home btrfs subvol=/@home,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx /root btrfs subvol=/@root,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx /srv btrfs subvol=/@srv,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx /var/tmp btrfs subvol=/@tmp,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx swap swap defaults,noatime 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
I have places xxx in place of actual UUID values because the one’s you provided via lsblk -f were kind of hard to map to their respective drives. So I have left that job to you.
please look at the output of lsblk -f to properly fill this
- Replace UUID of /boot/efi entry with the UUID of
/dev/sdb1 - The UUID for entry
/upto/var/tmpwould be replaced with the UUID disk that’s labelled asbtrfsby the output oflsblk -f - The UUID for entry
swapwill be the UUID of the disk labelledswap. If it’s not or you haven’t chosen swap at all while installing garuda then you can remove this entry. Please be careful and don’t accidentally considerzramin the output oflsblkto be your swap partition, you don’t have to care about zram.
and that’s it save the file and exit chroot then try to reboot.
Yes, the output of etc/fstab was the one from the USB, sorry, I got confused.
Everything seems to be fine now, but still no Windows appears in Grub, I don’t know what the problem is.
UUID=552D-739B /boot/efi vfat defaults,noatime 0 2
UUID=05c90dcc-bb1d-45a2-846d-572e9fb6eb56 / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=05c90dcc-bb1d-45a2-846d-572e9fb6eb56 /home btrfs subvol=/@home,defaults,noatime,compress=zstd 0 0
UUID=05c90dcc-bb1d-45a2-846d-572e9fb6eb56 /root btrfs subvol=/@root,defaults,noatime,compress=zstd 0 0
UUID=05c90dcc-bb1d-45a2-846d-572e9fb6eb56 /srv btrfs subvol=/@srv,defaults,noatime,compress=zstd 0 0
UUID=05c90dcc-bb1d-45a2-846d-572e9fb6eb56 /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=05c90dcc-bb1d-45a2-846d-572e9fb6eb56 /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd 0 0
UUID=05c90dcc-bb1d-45a2-846d-572e9fb6eb56 /var/tmp btrfs subvol=/@tmp,defaults,noatime,compress=zstd 0 0
├─sda1
│ vfat FAT32 552D-739B 498,4M 0% /boot/efi
├─sda2
│ ntfs SYSTEM 4858A27A58A26682
├─sda3
│ ext4 1.0 rootantiX21 c2dcb6c9-9994-48ea-a960-54686d4b19f2
├─sda4
└─sda5
btrfs 05c90dcc-bb1d-45a2-846d-572e9fb6eb56 /var/log
sr0
zram0
[SWAP]
╭─luis@luis in ~ took 16ms
╰─λ
so I can assume you are able to boot into your garuda machine? If yes then from inside your garuda machine
can you check if this
sudo os-prober
detects windows? If it does then can you check
grep GRUB_DISABLE_OS_PROBER /etc/default/grub
returns
# documentation on GRUB_DISABLE_OS_PROBER, if still want to enable this
GRUB_DISABLE_OS_PROBER=false
Please note there should be no # in front of GRUB_DISABLE_OS_PROBER=false line otherwise it means this line is commented out.
You can also just post the outputs of the commands if you feel confused.
If everything matches then can you please perform
sudo update-grub
and post it's output
Windows is not detected.
sudo os-prober
[sudo] contraseña para luis:
/dev/sda3:antiX 21 (21):antiX:linux
Hmm that's strange. Can you check if
efibootmgr
detects your windows boot loader? If you can then maybe we should go for manually adding windows to grub.
No
efibootmgr
EFI variables are not supported on this system.
Ah my bad I didn't notice that you were using BIOS and not UEFI. Can you check if you can boot into your windows installation at all from your BIOS? I am asking because it's quite possible the windows boot loader has somehow been deleted which is perhaps why os-prober is unable to detect it.
I can't, the only one that appears is Garuda.
Which means I was right and your windows boot loader has been somehow removed.
. The garuda entry refers to grub which is needed to boot linux like operating systems that's why you can still boot into your two linux installations and not the windows one.
The suggestions I am about to give out are going to be lengthy but that's the only way out I can think of at the moment if you can find a faster recovery process online or someone else can offer a more efficient method please do so.
boot into your linux system and mount the ntfs partition of the drive somewhere you want on your filesystem using
mountcommand and then backup important personal data that you need. Also backup your data from linux installations just in case. -
Reinstall windows, no other way around it sadly windows doesn't have any boot repair options.
Once done you will notice that now only windows is available on your system and grub is gone, don't panic windows does this $h*t its known for causing issues when multibooting. Use your garuda live USB to chroot into your system and reinstall grub.
Yes, you don't need to reinstall your two linux OSes just reinstalling grub would do. Finally boot into your system using grub and see if you can detect windows.
I was fearing that had been the problem.
Well, I hardly used that partition with Windows, but yes, I will save the information there and reinstall it, if there is no other choice.
By the way, should I use UEFI instead of Bios or does it make no difference?
I honestly don’t think you should touch your BIOS or UEFI unless you are facing unexplainable errors while using your system. Don’t fix what ain’t broke. Plus the switch you are mentioning is quite dangerous and could brick your system forever not something I would recommend.
Additional hint. When possible use 2 different physical drives for Linux / Win dual boot. In my case Grub picks up all system OSes and adds them to the boot menu. It works well for me.
When I need to delete or reinstall any of the OS'es I can do it indepenent of the other drive.
Ok, I will leave everything as it is and when I have time I will fix the Windows issue.
Thanks for all your help!
Thanks for the advice, I will take it into consideration, although it is complicated to do it on a laptop. Regards.
