Problems with Garuda installation
Not really. If you depend on it as the main system, it might be worth it. When this item is available, the installation is basically undo a screw slide DVD out and install a 2.5SSD inside new DVD"SSD" container and slide in and your done.
https://duckduckgo.com/?q=+dell+latitude+e6430+second+hard+drive&t=brave&atb=v368-1&iax=images&ia=images
