Please format, read the link and post all like
sudo mkdir -p /mnt/broken
sudo mount /dev/nvme0n1p2 /mnt/broken
sudo garuda-chroot /mnt/broken/@
[root@garuda-lxqt /]# sudo mount /dev/sda6 /mnt/broken
[root@garuda-lxqt /]# sudo garuda-chroot /mnt/broken/@
sudo: garuda-chroot: command not found
@malik it looks like you clicked the chroot icon.
If that is accurate, you can skip those steps and proceed directly to restoring grub.
So doing so
sudo grub-install /dev/sda6 ?????
Try /dev/sda, not any specific partition and post the output.
[root@garuda-lxqt /]# sudo grub-install /dev/sda
Installing for x86_64-efi platform.
grub-install: error: cannot find EFI directory.
Yikes, poor grub doesn't even know what to do on that disk anymore. What happens if you try
grub-install /dev/sda --boot-directory=/boot
in fact he doesn't know what to do anymore
sorry the sequence is wrong.
the last and the first
wait now I'll show you some images having started it in lagacy
Just edit your post.
sorry I do not understand
@discobot start tutorial
Gosh I hate to say so, but that disk is just a terrible mess.
/dev/sda1 and why does it have those flags? Did it used to be a boot partition? If so, what happened to it? Normally if you see a grub2 core.img filesystem it is very small, less than 1 MB so I am wondering if this partition was set up with a different purpose./dev/sda3 looks like an EFI partition, but it seems a little...odd. Did the system set up this partition, or did you create it in GParted, independent of an installation? Why does it have only 2.74 MiB on it? Have you looked at the contents of /boot/efi to see what is actually on there?/dev/sda6? It has a legacy_boot flag and it is mounted at /boot, but the partition is 185.55 GiB? The purpose of this partition is unclear. Is boot/grub in here?If this were my disk, I would do whatever it takes to get my backups in order and just start over. Format the disk completely, set up new sensible partitions, and begin from scratch. Whatever missteps led to this present state are going to be difficult or impossible to straighten out.
So in sda6 I have garuda kde and I would like to get it back since I have many files saved
sda5 instead there is garuda LXQT.
But the problem that with garuda lxqt does not see the partition of garuda kde, that of win10 yes.
that at most I saved the win10 files but those of garuda kde I don't know how.
the sda1 partition made me build it boot repair but I guess it just made trouble.
and sda1, if desired, I could also delete it.
I hope I was able to make myself explain
cat /etc/fstab
sudo fdisk -l
lsblk -f
ls -la /boot
sudo mkdir -p /mnt/garuda
sudo mkdir -p /mnt/boot
sudo mkdir -p /mnt/esp
sudo mount /dev/sda5 /mnt/garuda
sudo mount /dev/sda6 /mnt/boot
sudo mount /dev/sda3 /mnt/esp
ls -la /mnt/boot
ls -la /mnt/esp
lsblk -f
sudo fdisk -l
We also need /etc/fstab file of your installed system. If you can find it, post it here, as well.
[root@DELL malik]# cat /etc/fstab
# <file system> <mount point> <type> <options> <dump> <pass>
#UUID=5E63-73A4 /boot/efi vfat umask=0077 0 2
UUID=85767c9d-1549-476d-ad89-f880cf55488b / btrfs subvol=/@,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /home btrfs subvol=/@home,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /root btrfs subvol=/@root,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /srv btrfs subvol=/@srv,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /var/tmp btrfs subvol=/@tmp,defaults,noatime,compress=zstd,discard=async,ssd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
#UUID=59b2d140-9617-4869-bc03-09f061ee6bce /boot btrfs defaults 0 2
#UUID=5E63-73A4 /boot/efi vfat defaults 0 1
[root@DELL malik]# sudo fdisk -l
Disk /dev/sda: 447,13 GiB, 480103981056 bytes, 937703088 sectors
Disk model: KINGSTON SA400S3
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: B6291FBA-5200-459B-AE1E-87041A292765
Dispositivo Start Fine Settori Size Tipo
/dev/sda2 264192 1286143 1021952 499M Microsoft basic data
/dev/sda3 1286144 1490943 204800 100M EFI System
/dev/sda4 1490944 197303029 195812086 93,4G Microsoft basic data
/dev/sda5 586424320 936576663 350152344 167G Linux filesystem
/dev/sda6 197304320 586424319 389120000 185,5G Linux filesystem
/dev/sda7 936577024 937701375 1124352 549M Linux swap
Partition table entries are not in disk order.
Disk /dev/zram0: 15,53 GiB, 16677601280 bytes, 4071680 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
Disk /dev/loop3: 164,76 MiB, 172761088 bytes, 337424 sectors
Disk /dev/loop2: 71,1 MiB, 74551296 bytes, 145608 sectors
Disk /dev/loop1: 44,68 MiB, 46845952 bytes, 91496 sectors
Disk /dev/loop4: 65,21 MiB, 68378624 bytes, 133552 sectors
Disk /dev/loop5: 55,54 MiB, 58232832 bytes, 113736 sectors
[root@DELL malik]# lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0
squash 4.0 0 100% /var/lib/snapd/snap/bare/5
loop1
squash 4.0 0 100% /var/lib/snapd/snap/snapd/15534
loop2
squash 4.0 0 100% /var/lib/snapd/snap/translatium/141
loop3
squash 4.0 0 100% /var/lib/snapd/snap/gnome-3-28-1804/161
loop4
squash 4.0 0 100% /var/lib/snapd/snap/gtk-common-themes/1519
loop5
squash 4.0 0 100% /var/lib/snapd/snap/core18/2409
sda
ββsda2
β ntfs Recovery
β B0243BA0243B690C
ββsda3
β vfat FAT32 5E63-73A4
ββsda4
β ntfs 06F665DCF665CC8D
ββsda5
β btrfs 85767c9d-1549-476d-ad89-f880cf55488b 151,2G 9% /var/log
β /var/cache
β /home
β /root
β /var/tmp
β /srv
β /
ββsda6
β btrfs 59b2d140-9617-4869-bc03-09f061ee6bce 157,4G 14% /boot
ββsda7
swap 1 2f465ffe-f823-4f14-bcb9-cec74faa773a [SWAP]
sr0
zram0
[SWAP]
root@DELL malik]# ls -la /boot
totale 122976
drwxr-xr-x 1 root root 172 23 mag 20.02 .
drwxr-xr-x 1 root root 192 20 mag 21.57 ..
drwxr-xr-x 1 root root 20 11 mag 18.18 @
drwxr-xr-x 1 root root 0 23 mag 20.02 broken
drwxr-xr-x 1 root root 0 14 mag 16.21 efi
drwxr-xr-x 1 root root 112 23 mag 23.11 grub
-rw------- 1 root root 70136397 20 mag 18.49 initramfs-linux-zen-fallback.img
-rw------- 1 root root 44401209 20 mag 18.49 initramfs-linux-zen.img
-rw-r--r-- 1 root root 11362912 20 mag 18.49 vmlinuz-linux-zen
[root@DELL malik]# sudo mkdir -p /mnt/garuda
[root@DELL malik]# sudo mkdir -p /mnt/boot
[root@DELL malik]# sudo mkdir -p /mnt/esp
[root@DELL malik]# sudo mount /dev/sda5 /mnt/garuda
[root@DELL malik]# sudo mount /dev/sda6 /mnt/boot
[root@DELL malik]# sudo mount /dev/sda3 /mnt/esp
[root@DELL malik]# ls -la /mnt/boot
totale 122976
drwxr-xr-x 1 root root 38 24 mag 08.41 ..
[root@DELL malik]# ls -la /mnt/esp
totale 4
drwxr-xr-x 5 root root 1024 1 gen 1970 .
drwxr-xr-x 2 root root 1024 14 mag 17.54 broken
drwxr-xr-x 6 root root 1024 23 mag 23.27 EFI
drwxr-xr-x 2 root root 1024 22 mag 15.51 sda6
[root@DELL malik]#
loop0
loop1
loop2
loop3
loop4
loop5
sda
ββsda2
β ntfs Recovery
β B0243BA0243B690C
ββsda3
β vfat FAT32 5E63-73A4 97M 2% /mnt/esp
ββsda4
ββsda5
β btrfs 85767c9d-1549-476d-ad89-f880cf55488b 151,2G 9% /mnt/garuda
β /var/log
β /var/cache
β /home
β /root
β /var/tmp
β /srv
β /
ββsda6
β btrfs 59b2d140-9617-4869-bc03-09f061ee6bce 157,4G 14% /mnt/boot
β /boot
ββsda7
sr0
zram0
[SWAP]
[root@DELL malik]#
