[root@DELL malik]# sudo fdisk -l
Disk /dev/sda: 447,13 GiB, 480103981056 bytes, 937703088 sectors
Disk model: KINGSTON SA400S3
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: B6291FBA-5200-459B-AE1E-87041A292765
Dispositivo Start Fine Settori Size Tipo
/dev/sda2 264192 1286143 1021952 499M Microsoft basic data
/dev/sda3 1286144 1490943 204800 100M EFI System
/dev/sda4 1490944 197303029 195812086 93,4G Microsoft basic data
/dev/sda5 586424320 936576663 350152344 167G Linux filesystem
/dev/sda6 197304320 586424319 389120000 185,5G Linux filesystem
/dev/sda7 936577024 937701375 1124352 549M Linux swap
Partition table entries are not in disk order.
Disk /dev/zram0: 15,53 GiB, 16677601280 bytes, 4071680 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disk /dev/loop0: 4 KiB, 4096 bytes, 8 sectors
Disk /dev/loop3: 164,76 MiB, 172761088 bytes, 337424 sectors
Disk /dev/loop2: 71,1 MiB, 74551296 bytes, 145608 sectors
Disk /dev/loop1: 44,68 MiB, 46845952 bytes, 91496 sectors
Disk /dev/loop4: 65,21 MiB, 68378624 bytes, 133552 sectors
Disk /dev/loop5: 55,54 MiB, 58232832 bytes, 113736 sectors
[root@DELL malik]#
Just a "readability" tip on my side.
To make terminal text more readable in the posts, please add ~~~ before and after. Like this
text
I did it for a couple of posts above.
# <file system> <mount point> <type> <options> <dump> <pass>
#UUID=5E63-73A4 /boot/efi vfat umask=0077 0 2
UUID=85767c9d-1549-476d-ad89-f880cf55488b / btrfs subvol=/@,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /home btrfs subvol=/@home,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /root btrfs subvol=/@root,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /srv btrfs subvol=/@srv,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=85767c9d-1549-476d-ad89-f880cf55488b /var/tmp btrfs subvol=/@tmp,defaults,noatime,compress=zstd,discard=async,ssd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
#UUID=59b2d140-9617-4869-bc03-09f061ee6bce /boot btrfs defaults 0 2
#UUID=5E63-73A4 /boot/efi vfat defaults 0 1
this is the / etc / fstab content of the OS I am using now.
Premise: to start this system I must first enter the bios and indicate what to start, and so I can start garuda lxqt
We have communication language issues.IMHO, this was what caused this problem.
I cannot always understand you, and neither can you, it seems.
I don't want to be responsible for destroying your system and data.
Please ask your parents or teacher to help you with technical English terminology.
The issue is easy to fix, if we speak and understand common language.
yes yes ok quiet, I just want to understand if we can unlock everything.
At most I reinstall everything even if I would like to lose things.
