Problem with the Canon MF3010
Hello Garuda users.
  Kernel: 5.19.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=3be6bfab-7793-443d-8925-14f402362e3c rw rootflags=subvol=@
    resume=UUID=1358094e-bd25-4baf-9290-02892a3efe12 loglevel=3 ibt=off
  Type: Desktop System: Gigabyte product: H110M-S2H v: N/A
  Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: <superuser required>
    UEFI: American Megatrends v: F22 date: 06/12/2017
  Info: model: Intel Pentium G4600 bits: 64 type: MT MCP arch: Kaby Lake
    built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
    microcode: 0xF0
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2900 high: 3600 min/max: 800/3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3600 2: 3600 3: 3600
    4: 800 bogomips: 28800
    vulnerable
    PBRSB-eIBRS: Not affected
  Device-1: NVIDIA TU117 [GeForce GTX 1650] driver: nvidia v: 515.65.01
    alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
    2022-07) arch: Turing code: TUxxx process: TSMC 12nm built: 2018-22 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
    bus-ID: 01:00.0 chip-ID: 10de:1f82 class-ID: 0300
  Device-2: Realtek FULL HD 1080P Webcam type: USB
    driver: snd-usb-audio,uvcvideo bus-ID: 1-7:4 chip-ID: 0bda:58b0
  Screen-1: 0 s-res: 1280x1024 s-dpi: 85 s-size: 382x302mm (15.04x11.89")
    s-diag: 487mm (19.17")
  Monitor-1: DVI-D-0 res: 1280x1024 hz: 60 dpi: 86
    size: 376x301mm (14.8x11.85") diag: 482mm (18.96") modes: N/A
  OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA
    515.65.01 direct render: Yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
    driver: snd_hda_intel bus-ID: 1-7:4 v: kernel chip-ID: 0bda:58b0
    bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0102 class-ID: 0403
  Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
  Device-3: Realtek FULL HD 1080P Webcam type: USB
  Sound Server-1: ALSA v: k5.19.2-zen1-1-zen running: yes
  Local Storage: total: 674.16 GiB used: 229.04 GiB (34.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37120G
    type: SSD serial: <filter> rev: 60A9 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37480G
    type: SSD serial: <filter> rev: 1103 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
    model: DataTraveler 3.0 size: 115.23 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> scheme: MBR
  ID-1: / raw-size: 438.03 GiB size: 438.03 GiB (100.00%) used: 213.18 GiB
    (48.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 588 KiB
    (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
  ID-3: /home raw-size: 438.03 GiB size: 438.03 GiB (100.00%) used: 213.18
    GiB (48.7%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
  ID-4: /var/log raw-size: 438.03 GiB size: 438.03 GiB (100.00%) used: 213.18
  ID-5: /var/tmp raw-size: 438.03 GiB size: 438.03 GiB (100.00%) used: 213.18
  ID-1: swap-1 type: zram size: 7.72 GiB used: 73.8 MiB (0.9%)
  System Temperatures: cpu: 35.0 C mobo: N/A gpu: nvidia temp: 35 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 30%
  Processes: 267 Uptime: 1h 33m wakeups: 0 Memory: 7.72 GiB used: 4.73 GiB
  (61.3%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: note: see --pkg pacman: 2092
  lib: 556 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
Garuda (2.6.6-1):
  System install date:     2022-05-15
  Last full system update: 2022-08-23
  Failed units:            bluetooth-autoconnect.service
I've been trying to connect the printer for a couple of weeks now. I need it for my studies and until it works I won't be able to work properly. Therefore, it is advisable to resolve the issue quickly, if possible. I installed the drivers from this sitehttps://driverscollection.com/
But the system gives such an error:
"/usr/lib/cups/filter/rastertoufr2" : No such file or directory.
Please help to solve this problem.Preformatted text
What is the printer model? Your post title just says "Canon printer" and the post itself provides no further detail.
A forum search by simply mf3010 seems to lead to a good result
Edit: I see only now you already tried there probably
Yes, it is. It's just that I'm doing everything right, it's just that this error knocks everything down. No one wrote about it.
PS Yes, before opening the topic, I did everything as it was written there, I even took the website with drivers from there.
Try to install the driver from the AUR, maybe you will have better luck with that.
paru cndrvcups-lb
You are right.
If you search the Internet for that missing file you will find that it is a problem discovered and fixed in other distributions, e.g., gentoo and nixos.
The following is very unorthodox, but if you like you can try it.
https://bugs.gentoo.org/695896
The gentoo bug report suggests as a workaround to use the binary from the Debian package, but reading the comments they suggest an AUR package that should include that file.
The more correct option would perhaps be to open a bug for the cups package.
Edit: exactly the package suggested above :blush:
I did as you said, and then I got this conclusion. I also tried to run the installation via Octopi, but there the terminal stopped at this output and that's it. The terminal did not say that the installation was completed.
:: Π Π°Π·Ρ€Π΅ΡˆΠ΅Π½ΠΈΠ΅ зависимостСй...
:: Π•ΡΡ‚ΡŒ 2 доступных источников-поставщиков ΠΏΠ°ΠΊΠ΅Ρ‚Π° cnrdrvcups-lb:
:: Π Π΅ΠΏΠΎΠ·ΠΈΡ‚ΠΎΡ€ΠΈΠΉ AUR:
    1) cnrdrvcups-lb  2) cnrdrvcups-lb-bin
Π’Π²Π΅Π΄ΠΈΡ‚Π΅ Π½ΠΎΠΌΠ΅Ρ€ (ΠΏΠΎ ΡƒΠΌΠΎΠ»Ρ‡Π°Π½ΠΈΡŽ = 1): 1
:: Поиск ΠΊΠΎΠ½Ρ„Π»ΠΈΠΊΡ‚ΠΎΠ²...
:: Поиск Π²Π½ΡƒΡ‚Ρ€Π΅Π½Π½ΠΈΡ… ΠΊΠΎΠ½Ρ„Π»ΠΈΠΊΡ‚ΠΎΠ²...
Π Π΅ΠΏΠΎΠ·ΠΈΡ‚ΠΎΡ€ΠΈΠΉ Make (1) jbigkit-2.1-6
Aur (1) cnrdrvcups-lb-5.50-2
:: ΠŸΡ€ΠΎΠ΄ΠΎΠ»ΠΆΠΈΡ‚ΡŒ ΠΎΠ±Π·ΠΎΡ€? [Y/n]: Y
:: Π‘ΠΊΠ°Ρ‡ΠΈΠ²Π°ΡŽΡ‚ΡΡ PKGBUILD’ы...
 (1/1) скачиваСтся: cnrdrvcups-lb-5.50-2
/home/nikita/.cache/paru/clone/cnrdrvcups-lb/PKGBUILD
# Maintainer:  Chris Severance aur.severach aATt spamgourmet dott c>
# Maintainer:  Lone_Wolf <lone_wolf@klaas-de-kat.nl>
# Contributor: Steven She <mintcoffee@gmail.com>
# Contributor: vbPadre <vbPadre@gmail.com>
pkgname='cnrdrvcups-lb'
# The download link changes with every version, try to keep changes>
# https://gdlp01.c-wss.com/gds/8/0100007658/27/linux-UFRII-drv-v550>
_pkgver='5.50';  _dl='8/0100007658/27';_suffix='00'
pkgver="${_pkgver}"
pkgrel='2'
pkgdesc='CUPS Canon UFR II LIPSLX CARPS2 printer driver for LBP iR >
arch=('x86_64')
# Direct links to the download reference go bad on the next version>
url='https://www.canon-europe.com/support/products/imagerunner/imag>
license=('GPL2' 'MIT' 'custom')
# parts of the code are GPL or MIT licensed, some parts have a cust>
makedepends=('jbigkit' 'gzip' 'gtk3')
depends=('gcc-libs' 'libxml2')
optdepends=('libjpeg6-turbo: solves cpu hang on some color imageRUN>
                       'libjbig-shared: port of debian/fedora speci>
                        'gtk3: for cnsetuputil2')
conflicts=('cndrvcups-lb' 'cndrvcups-common-lb')
options=('!emptydirs' '!strip' '!libtool')
source=(  "http://gdlp01.c-wss.com/gds/${_dl}/linux-UFRII-drv-v${_p>
md5sums=('c5226e974498218bf969ae145f168d81')
sha512sums=('b38ddfc465a3de18ed31b89e5fd28a807ff82586028ce7f5ededbe>
# Canon provides the sourcecode in a tarball within the dowload and>
# In order to keep the $srcdir structure tidy we put the extracted >
# the code itself is spread over many folders.
# "cnrdrvcups-common-${_pkgver}" aka _common_dir & "cnrdrvcups-lb-$>
# are used to keep this manageable
_srcdir="extracted-${pkgname}-${_pkgver}"
_common_dir="cnrdrvcups-common-${_pkgver}"
_driver_dir="cnrdrvcups-lb-${_pkgver}"
prepare() {
    # extract sources
    mkdir "${_srcdir}"
    cd "${_srcdir}"
    bsdtar -xf "${srcdir}/linux-UFRII-drv-v${_pkgver//\./}-m17n/Sou>
    local _specs=(cnrdrvcups-lb.spec)
    # cngplp/autogen.sh fails to find several libraries.
    # adding these in the right place of the soon to be generated m>
    # so we patch it directly into that autogen.sh
    #    sed -e '2a export LIBS="-lgtk-x11-2.0 -lgobject-2.0 -lglib>
    # the switch to gtk3 appears to have solved this
    # the autogen.sh files from canon target an old automake/autoco>
    # autoreconf converts them to a form compatible with archlinux >
    pushd "${_common_dir}"
    for i in "backend" "buftool" "cngplp" "cnjbig" "rasterfilter"
    do
        pushd "$i"
        autoreconf --install --warnings=none
        popd
    done
    popd
    pushd "${_driver_dir}"
    for i in "cngplp/files" "cngplp" "cpca" "pdftocpca"
    do
        pushd "$i"
        popd
    done
    popd
    # allgen.sh where available is not useful for packaging on arch>
    # Canon provides methods to build deb & rpm packages.
    # The debian rules are not suited for archlinux. When the .spec>
    # Chris Severach figured out a way to automate  this conversion.
    # Generate make from spec %setup, %build
    sed -n -e '/^%setup/,/^%install/ p' "${_specs[@]}" | \
    grep -v '^%' | \
    sed -e '# Convert spec %{VAR} to shell ${VAR}' \
        -e 's:%{:${:g' \
        -e '# Quote to allow _cflags to have spaces' \
        -e 's:${_cflags}:"${_cflags}":g' \
        -e '# Some autogen.sh commands in the spec file do not set >
        -e 's:^./autogen.sh:& --prefix=${_prefix}:g ' \
        > 'make.Arch'
    # Generate make install from spec %install
    sed -n -e '/^%install/,/^%clean/ p' "${_specs[@]}" | \
    grep -v '^%' | \
        -e 's:%{:${:g' \
        -e '# Quote to handle path with spaces' \
        -e 's:${RPM_BUILD_ROOT}:"&":g' \
        -e '# ln -f hides problems so should be avoided' \
        -e 's:ln -sf :ln -s :g' \
        > 'make.install.Arch'
_setvars() {
    # variables used by the (generated) make.Arch &  make.install.A>
    # relative paths start at ${srcdir}/${_srcdir}
    # _libsarch is architecture dependent
    _vars=(
        _builddir="${srcdir}/${_srcdir}"
        common_dir="${_common_dir}"
        driver_dir="${_driver_dir}"
        utility_dir="cnrdrvcups-utility-${_pkgver}"
        RPM_BUILD_DIR="${srcdir}/${_srcdir}"
        _prefix='/usr'
        _machine_type="MACHINETYPE="$CARCH
        _cflags="CFLAGS=""$CFLAGS"
        _libdir='/usr/lib'
        _bindir='/usr/bin'
        locallibs='/usr/lib/'
        _includedir='/usr/include'
        b_lib_dir="${srcdir}/${_srcdir}/lib"
        b_include_dir="${srcdir}/${_srcdir}/include"
        _libsarch='libs64/intel'
        nobuild=0
build() {
  cd "${_srcdir}"
  local _vars; _setvars
  # Bash does not recognize var assigments hidden by array expansio>
  env "${_vars[@]}" \
  sh 'make.Arch'
package() {
    cd "${_srcdir}"
    env "${_vars[@]}" \
    RPM_BUILD_ROOT="${pkgdir}" \
    sh 'make.install.Arch'
    # licensing information is spread over multiple files and folde>
    # while they could be done in a loop iterating through dirs/fil>
    # I feel that would obscure what happens and make troubleshooti>
    # so each file gets its own install command
    install -Dpm644 "README" "${pkgdir}/usr/share/licenses/${pkgnam>
    install -Dpm644 "backend/LICENSE.txt" "${pkgdir}/usr/share/lice>
    install -Dpm644 "backend/LICENSE.canon.txt" "${pkgdir}/usr/shar>
    install -Dpm644 "backend/README" "${pkgdir}/usr/share/licenses/>
    install -Dpm644 "buftool/LICENSE.txt" "${pkgdir}/usr/share/lice>
    install -Dpm644 "buftool/README" "${pkgdir}/usr/share/licenses/>
    install -Dpm644 "cngplp/LICENSE.canon.txt" "${pkgdir}/usr/share>
    install -Dpm644 "cngplp/README" "${pkgdir}/usr/share/licenses/$>
    install -Dpm644 "cnjbig/README" "${pkgdir}/usr/share/licenses/$>
    install -Dpm644 "rasterfilter/README" "${pkgdir}/usr/share/lice>
    popd
    install -Dpm644 "cngplp/files/README" "${pkgdir}/usr/share/lice>
    install -Dpm644 "cpca/README" "${pkgdir}/usr/share/licenses/${p>
    install -Dpm644 "cpca/cnpklib/LICENSE.canon.txt" "${pkgdir}/usr>
    install -Dpm644 "pdftocpca/README" "${pkgdir}/usr/share/license>
    popd
    # documentation
    pushd "$srcdir/linux-UFRII-drv-v${_pkgver//\./}-m17n/Documents"
    install -Dpm644 deutsch/"README-ufr2-5.5xDE.html" "${pkgdir}/us>
    install -Dpm644 espanol/"README-ufr2-5.5xSP.html" "${pkgdir}/us>
    install -Dpm644 francais/"README-ufr2-5.5xFR.html" "${pkgdir}/u>
    install -Dpm644 italiano/"README-ufr2-5.5xIT.html" "${pkgdir}/u>
    install -Dpm644 korean/"README-ufr2-5.5xKR.html" "${pkgdir}/usr>
    install -Dpm644 simplified_chinese/"README-ufr2-5.5xSC.html" "$>
    install -Dpm644 traditional_chinese/"README-ufr2-5.5xTC.html" ">
    install -Dpm644 uk_eng/"README-ufr2-5.5xUK.html" "${pkgdir}/usr>
    install -Dpm644 deutsch/"UsersGuide-ufr2-DE.html" "${pkgdir}/us>
    install -Dpm644 espanol/"UsersGuide-ufr2-SP.html" "${pkgdir}/us>
    install -Dpm644 francais/"UsersGuide-ufr2-FR.html" "${pkgdir}/u>
    install -Dpm644 italiano/"UsersGuide-ufr2-IT.html" "${pkgdir}/u>
    install -Dpm644 korean/"UsersGuide-ufr2-KR.html" "${pkgdir}/usr>
    install -Dpm644 simplified_chinese/"UsersGuide-ufr2-SC.html" "$>
    install -Dpm644 traditional_chinese/"UsersGuide-ufr2-TC.html" ">
    install -Dpm644 uk_eng/"UsersGuide-ufr2-UK.html" "${pkgdir}/usr>
    install -Dpm644 deutsch/"LICENSE-DE.txt" "${pkgdir}/usr/share/l>
    install -Dpm644 espanol/"LICENSE-ES.txt" "${pkgdir}/usr/share/l>
    install -Dpm644 francais/"LICENSE-FR.txt" "${pkgdir}/usr/share/>
    install -Dpm644 italiano/"LICENSE-IT.txt" "${pkgdir}/usr/share/>
    install -Dpm644 korean/"LICENSE-KO.txt" "${pkgdir}/usr/share/li>
    install -Dpm644 simplified_chinese/"LICENSE-CN.txt" "${pkgdir}/>
    install -Dpm644 traditional_chinese/"LICENSE-TW.txt" "${pkgdir}>
    install -Dpm644 uk_eng/"LICENSE-EN.txt" "${pkgdir}/usr/share/li>
    popd
(END)
Paru gives you an opportunity to review the code before you proceed with installation. Once you are finished reviewing it, press
q
and it will ask you if you want to continue.
Hello, your solution helped, but I got another error (it looks like the printer itself is actively resisting normal operation))). This is the "Filter failed" error, and I see it only in the localhost 631 interface. And in the computer, the program endlessly sends data to the printer. I've been trying to fix it for 40 minutes. I tried reinstalling ghostscript via Octopi, but it didn't help.
Your compy's BIOS is dated 2017. Is there a more current one available? The BIOS (Basic Input/Output System) can have a direct bearing on hardware recognition. That may or may not be a part of the problem(s).
regards
Source: BIOS - Wikipedia
No, unfortunately, this is my only BIOS.
Are you setting up the printer in the Print Settings app before you try to use it? It looks like this:
Yes exactly.
Okay, and it is detecting the printer just fine and allowing you to add it?
Are you able to print a test page to the printer?
Does the printer show up as an option if you attempt to print a document or something?
Can you provide more detail about where exactly you are encountering the error you mentioned?
1)Yes, you can add a printer
2) No, you can't, because of the endless "processing and sending data to the printer"
3) Yes
4)Screenshots are attached
Hmm, the screenshots you chose don't appear to show anything helpful. Certainly the problem you are experiencing is not illustrated.
Try power cycling the printer and rebooting your computer as well. Test again, then make note of any error messages. A screenshot of the error you are seeing might be helpful. Even better, copy and paste to the thread as text if possible.
I restarted the computer and the printer. Then I tried to print a test page (4 times). There is an error on one of the screenshots (where the status message is):Filter file. On another screen, there is just an inscription "Processing - Sending data to the printer." (Written in Russian).
Is the printer connected by USB? If so, it looks like there is another additional package that may need to be installed:
USB over IP (BJNP)
Some Canon printers use Canon’s proprietary USB over IP BJNP protocol to communicate over the network. There is a CUPS backend for this, which is available as cups-bjnpAUR.
Source: CUPS/Printer-specific problems - ArchWiki
To install:
paru cups-bjnp
I did everything as you wrote. The result is the same.
The printer seems to be processing the task, judging by the display.
