Good afternoon.
I had an SSD go down earlier today which caused a bunch of issues. The SSD was a secondary drive (NTFS) but I was able to retrieve my files on another machine, install an HDD (btrfs) to avoid any issues like that in the future and restored via Snapper so that the games that stopped working would work again.
However, I’m still having issues similar to this thread: On login, Background on one screen is missing and right-click menu doesn't display but I did not see a solution to the issue there.
On login, the background wallpaper for the primary monitor is missing and right clicking on the primary monitor doesn’t bring up a context menu. By switching the primary monitor to and from brings back the background and any windows/menus.
Is there a way for the display to boot in the way it was when I restart/shutdown?
This is my first post so I apologise if I’ve missed any info I should have included.
garuda-inxi:
Kernel: 6.6.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=30b24f59-736e-4a29-80a7-dd70e004d9ea rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Desktop Mobo: Micro-Star model: Z790 GAMING PRO WIFI (MS-7D93) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.20
date: 09/06/2023
Info: model: 12th Gen Intel Core i9-12900KF bits: 64 type: MST AMCP
microcode: 0x32
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 14 MiB desc: 8x1.2 MiB, 2x2 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 800 min/max: 800/5100:5200:3900 scaling:
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 800 19: 800 20: 800 21: 800 22: 800 23: 800
24: 800 bogomips: 152985
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
Device-2: Elgato Systems GmbH Cam Link 4K
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-5:2 chip-ID: 0fd9:0066
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
s-diag: 1055mm (41.54")
Monitor-1: DP-3 mapped: DisplayPort-2 pos: right model: AOC 24B1W
serial: <filter> built: 2023 res: 1920x1080 hz: 60 dpi: 94 gamma: 1.2
size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9 modes:
Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: primary,left model: Samsung
serial: <filter> built: 2013 res: 1920x1080 hz: 60 dpi: 55 gamma: 1.2
size: 887x500mm (34.92x19.69") diag: 1213mm (47.8") ratio: 16:9 modes:
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.3.1-arch1.1
navi22 LLVM 16.0.6 DRM 3.54 6.6.7-zen1-1-zen) device-ID: 1002:73df
memory: 11.72 GiB unified: no
Device-1: Intel vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:7a50
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Kingston HyperX QuadCast
lanes: 1 mode: 1.1 bus-ID: 1-7.2:4 chip-ID: 0951:16df class-ID: 0300
Device-4: Elgato Systems GmbH Cam Link 4K
API: ALSA v: k6.6.7-zen1-1-zen status: kernel-api with: aoss
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
lanes: 1 port: 4000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-3: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:8 chip-ID: 8087:0033
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 3.64 TiB used: 609.92 GiB (16.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40A temp: 35.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST2000DM008-2UB102
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 598.5 GiB (32.1%)
used: 598.5 GiB (32.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.19 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 36.0 C
mem: 30.0 C
Fan Speeds (rpm): cpu: 1083 fan-2: 3166 fan-3: 751 fan-4: 954 fan-5: 1009
fan-6: 990 fan-7: 0 fan-8: 0 fan-9: 0 fan-10: 0 gpu: amdgpu fan: 0
Processes: 427 Uptime: 31m wakeups: 0 Memory: total: 32 GiB
available: 31.19 GiB used: 3.83 GiB (12.3%) Init: systemd v: 255
default: graphical tool: systemctl Compilers: gcc: 13.2.1 Packages: 1898
pm: pacman pkgs: 1887 libs: 546 tools: octopi,paru pm: flatpak pkgs: 11
Shell: fish v: 3.6.4 default: Bash v: 5.2.21 running-in: konsole
inxi: 3.3.31
Garuda (2.6.21-1):
System install date: 2023-10-19
Last full system update: 2023-12-19
