I disabled Latte from autostarting and ran it manually in the terminal. Here is the output:
latte-dock
Icon theme "gnome" not found.
[51843:51843:1031/113539.630537:ERROR:sharing_service.cc(222)] Device registration failed with fatal error
[51884:51884:1031/113539.643027:ERROR:sandbox_linux.cc(374)] InitializeSandbox() called with multiple threads in process gpu-process.
Fontconfig error: Cannot load default config file: No such file: (null)
[51843:51863:1031/113539.694464:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51949:1031/113540.132010:ERROR:get_updates_processor.cc(260)] PostClientToServerMessage() failed during GetUpdates with error 2
[51843:51862:1031/113540.740002:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51862:1031/113540.747376:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51862:1031/113540.747417:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51949:1031/113540.748428:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51948:1031/113540.777965:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51948:1031/113540.778017:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51919:1031/113540.778943:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51949:1031/113540.818144:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51947:1031/113540.978960:ERROR:chrome_browser_main_extra_parts_metrics.cc(228)] crbug.com/1216328: Checking Bluetooth availability started. Please report if there is no report that this ends.
[51843:51947:1031/113540.978984:ERROR:chrome_browser_main_extra_parts_metrics.cc(231)] crbug.com/1216328: Checking Bluetooth availability ended.
[51843:51947:1031/113540.978989:ERROR:chrome_browser_main_extra_parts_metrics.cc(234)] crbug.com/1216328: Checking default browser status started. Please report if there is no report that this ends.
[51843:51947:1031/113541.030033:ERROR:chrome_browser_main_extra_parts_metrics.cc(238)] crbug.com/1216328: Checking default browser status ended.
[51843:51949:1031/113541.035097:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51949:1031/113541.035149:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51877:1031/113541.035956:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51919:1031/113541.113474:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51948:1031/113541.540751:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51952:1031/113551.254858:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51952:1031/113551.254909:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51952:1031/113551.257433:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51952:1031/113551.290877:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51865:1031/113551.704544:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51947:1031/113609.297389:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE visit_time >= ? AND visit_time < ?ORDER BY visit_time LIMIT ?
[51843:51947:1031/113613.107892:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51865:1031/113615.217246:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51865:1031/113615.217291:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51865:1031/113615.220686:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51862:1031/113621.221483:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51862:1031/113621.221522:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51862:1031/113621.225254:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51865:1031/113624.053140:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51861:1031/113628.139480:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51861:1031/113629.282708:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51865:1031/113639.299768:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE visit_time >= ? AND visit_time < ? AND (transition & ?) == ?ORDER BY visit_time LIMIT ?
[51843:51862:1031/113640.941214:ERROR:get_updates_processor.cc(260)] PostClientToServerMessage() failed during GetUpdates with error 2
[51843:51861:1031/113647.297876:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51862:1031/113648.046927:ERROR:get_updates_processor.cc(260)] PostClientToServerMessage() failed during GetUpdates with error 2
[51843:51862:1031/113655.102726:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:51862:1031/113655.102774:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51865:1031/113655.104381:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51865:1031/113655.299801:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:58201:1031/113703.143039:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:58201:1031/113703.143083:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:58201:1031/113703.144772:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:58199:1031/113703.240359:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:51952:1031/113703.675928:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:58200:1031/113711.489564:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE id=?
[51843:58200:1031/113711.489621:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
[51843:58200:1031/113711.490252:ERROR:database.cc(1761)] History SQLite error: code 1 errno 0: no such column: publicly_routable sql: SELECT id,url,visit_time,from_visit,transition,segment_id,visit_duration,incremented_omnibox_typed_score,publicly_routable FROM visits WHERE url=? ORDER BY visit_time DESC, id DESC LIMIT ?
I also restarted the Kwin compositor and the functionality comes back. This is the command I used:
kwin_x11 --replace
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 180, resource id: 8388621, major code: 20 (GetProperty), minor code: 0
qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 181, resource id: 8388621, major code: 20 (GetProperty), minor code: 0
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5089:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5091:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5093:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5097:47: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5099:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5107:48: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5111:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5113:46: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5117:45: this compose sequence is a duplicate of another; skipping line
kwin_xkbcommon: XKB: /usr/share/X11/locale/en_US.UTF-8/Compose:5120:46: this compose sequence is a duplicate of another; skipping line
Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
OpenGL vendor string: AMD
OpenGL renderer string: Radeon RX 580 Series (POLARIS10, DRM 3.42.0, 5.14.12-zen1-1-zen, LLVM 12.0.1)
OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.2.3
OpenGL shading language version string: 4.60
Driver: RadeonSI
GPU class: Arctic Islands
OpenGL version: 4.6
GLSL version: 4.60
Mesa version: 21.2.3
X server version: 1.20.13
Linux kernel version: 5.14.12
Requires strict binding: yes
GLSL shaders: yes
Texture NPOT support: yes
Virtual Machine: no
qml: FORCE-BLUR: starting the script
qml: ["peek"]
kwin_core: XCB error: 10 (BadAccess), sequence: 2807, resource id: 1737, major code: 142 (Composite), minor code: 2 (RedirectSubwindows)
