Hello Garuda users.
the problem_
No idea how this happened. No taskbar, no icons and can’t right click desktop in KDE after login. only the Late Dock was working properly.
kquitapp5 plasmashell && kstart5 plasmashell
plasmaslell - replace
both are not able to fix this. Restarting it or rebooting the whole machine didn’t help.
I’d tried removing ~/.cache. Shortly after all plasmashell would do is start my desktop background with a wallpaper, but wouldn’t give me any taskbar and I couldn’t bring up a menu by right clicking the desktop.
i hadn’t faced this before…
i think it happened after upgrade to kernel 6.0… but restoring previous snapshot solve nothing.
the solution_ ( somehow it worked for me __ and the problem solved )
i have to uninstall qemu desktop … and it surprisingly solved the problem without rebooting the computer.
i dont know how qemu is connected to this
if anyone know this logic … please tell me…
btw it was solved. I post this so that it may be helpful to someone who faced this same problem… and the solution might be this
because this solution doesn’t works for me.
Thank You.
