Kernel: 6.7.0-AMD-znver3 arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: hpet,acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-amd-znver3
root=UUID=814b5a44-cc3e-4a96-af5e-86e325473144 rw rootflags=subvol=@ quiet quiet
Console: tty 3 DM: SDDM Distro: Garuda Linux base: Arch Linux
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
UEFI: American Megatrends v: P4.30 date: 04/14/2021
Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 4 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
microcode: 0xA201009
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3788 high: 3800 min/max: 2200/4850 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 5: 3618
6: 3800 7: 3800 8: 3800 9: 3800 10: 3800 11: 3800 12: 3800 13: 3800 14: 3800 15: 3800 16: 3800
bogomips: 121647
Device-1: NVIDIA GP104 [GeForce GTX 1060 6GB] vendor: Micro-Star MSI driver: nvidia v: 545.29.06
alternate: nvidia_drm non-free: 545.xx+ status: current (as of 2023-10; EOL~2026-12-xx)
arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: DP-2,DP-3
empty: DP-1,DVI-D-1,HDMI-A-1 bus-ID: 0d:00.0 chip-ID: 10de:1b83 class-ID: 0300
Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 046d:08e5 class-ID: 0102
Display: server: X.org v: 1.21.1.10 with: Xwayland v: 23.2.3 driver: X: loaded: nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch tty: 192x54
Monitor-1: DP-2 model: VG278 serial: <filter> built: 2019 res: 1920x1080 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: DP-3 model: Philips 227ELH serial: <filter> built: 2011 res: 1920x1080 dpi: 102
gamma: 1.2 size: 480x268mm (18.9x10.55") diag: 550mm (21.6") ratio: 16:9 modes: max: 1920x1080
min: 640x480
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2 drv: swrast gbm:
drv: nvidia surfaceless: drv: nvidia inactive: wayland,x11,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.3.2-arch1.2 note: console (EGL sourced)
renderer: NVIDIA GeForce GTX 1060 6GB/PCIe/SSE2, llvmpipe (LLVM 16.0.6 256 bits)
API: Vulkan v: 1.3.274 layers: 14 device: 0 type: discrete-gpu name: NVIDIA GeForce GTX 1060
6GB driver: nvidia v: 545.29.06 device-ID: 10de:1b83 surfaces: N/A device: 1 type: cpu
name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.2-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0d:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: JMTek LLC. USB Condenser Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0c76:1716
Device-4: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo type: USB rev: 2.1
API: ALSA v: k6.7.0-AMD-znver3 status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.0.0 status: off with: 1: pipewire-pulse status: off 2: wireplumber
status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0 chip-ID: 8086:1539 class-ID: 0200
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 3-2:5 chip-ID: 8087:0029 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: yes address: <filter> bt-v: 5.2 lmp-v: 11 status: discoverable: no
pairing: no
Local Storage: total: 4.15 TiB used: 1.82 TiB (43.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus 1TB size: 931.51 GiB
fw-rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB
fw-rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT500MX500SSD1 size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 023 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
fw-rev: 4B6Q scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD10JPLX-00MBPT0 size: 931.51 GiB
fw-rev: 1H01 scheme: MBR
ID-6: /dev/sde maj-min: 8:64 vendor: Intenso model: Speed Line size: 58.59 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: N/A serial: <filter> scheme: MBR
ID-1: / raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 401.08 GiB (86.2%) fs: btrfs
dev: /dev/sdb2 maj-min: 8:18
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 584 KiB (0.2%) fs: vfat
dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 401.08 GiB (86.2%) fs: btrfs
ID-4: /var/log raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 401.08 GiB (86.2%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-5: /var/tmp raw-size: 465.46 GiB size: 465.46 GiB (100.00%) used: 401.08 GiB (86.2%)
ID-1: swap-1 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 16 dev: /dev/zram0
System Temperatures: cpu: 46.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (rpm): fan-6: 1131
Processes: 327 Uptime: 1m wakeups: 0 Memory: total: 32 GiB available: 31.28 GiB
used: 1.88 GiB (6.0%) Init: systemd v: 255 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: pm: pacman pkgs: 2042 libs: 580 tools: octopi,paru
Shell: Bash v: 5.2.21 running-in: tty 3 inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-08-16
Last full system update: 2024-01-12
Addition: It is a Windows dual boot (Edit: It’s on the NVMe the Garuda is on the Crucial SSD)
The system showed this behaviour after the penultimate update, the last update was made after reading this topic.
Since I’m still able to use my system over something like tty3, if I didn’t try to login via sddm, I tried to update my system from the tty, but that doesn’t fix it, on that base I also switched over to dbus-daemon (Option 2) without any improvement.
I tried pretty much every Snapshot available from grub but only the last three even start, but show the same freeze after sddm login.
Starting with zen kernel takes longer than with my default choice(zen3 kernel), but leads to the same problem even on fallback versions.
Last thing I did on the running system was playing around with the garuda default panel for my two Monitors(slightly different versions of each other), while waiting for the running garuda-update to finish its process.
System was running fine after that and with the next restart, the system would freeze like 3 - 6 Seconds after logging into it from the sddm login.
Each start varies a little bit, with how much of the auto start programs are loaded, and to what degree, sometimes I even come to see the last thunderbird stand on my emails.
But what stays somewhat consistent is the freeze around 45% CPU load and 34,3% RAM usage, read from the panel widgets, and the firewalld popup notification.
Problems with older Snapshots aren’t always the same, it ranges from:
NVRM: loading NVIDIA UNIX x86_64 Kernel Module 545.29.06 Thu Nov 16 01:59:08 UTC 2023
[FAILED] Failed to start Remount Root and Kernel File Systems.
uvcvideo 3-5:1.1: Failed to set UVC probe control : -32 (exp. 26).
Bluetooth: hci0: FW download error recovery failed (-19)
Bluetooth: hci0: sending frame failed (-19)
Bluetooth: hci0: Reading supported feature failed (-19)
Cycling the HDMI and DP Monitors on/off like every 15 - 25 seconds
Over to some Snapshots failing over not being able to mount directories like /tmp and some other system relevant ones, but on these errors the system will sometimes still boot up to the sddm to let me login and freeze afterwards too, even so the system was fine at that point in time.
My knowledge base:
On Windows I’m fine with fixing problems if they come up.
I never really run into problems with my Debian Webserver that weren’t solvable with a fast web search.
But since Garuda Linux is my first distribution that I’m using as a daily driver, I’m not really sure where to even start with the troubleshooting.
Edit:
If any more information are needed I will do my best to deliver them, since I want to fix the system and not just reinstall it.
Thanks in advance for reading and any tips that could help diagnose the problem.
