Hi All,
New to Garuda and Linux, been reading alot the past week or so for all my issues and managed to resolve alot on my own but Im stumped on this VMware portion. I realize from some internet posts that vmware support on Arch based distros is either not supported or 'youre on your own'
Im trying to update VMWare Workstation 16.2.4 but keep encountering an error. I believe all the dependencies are present, I installed this from AUR initially. Despite this Im still not 100% sure everything is kosher as far as dependencies or other services running or enabled.
I have updated the OS as far as I know how. Im posting the last few lines of the error from the logs rather than the whole for everyone's sanity but I can if its requested.
Edit1: I did run:
sudo pacman -Sy
This updated the kernal but still no to avail.
Also tried enabling some vmware services and was successful with all but one
sudo systemctl enable --now vmware-hostd.service
The error I got from this was
Failed to enable unit: Unit file vmware-hostd.service does not exist.
However I dont know if this is relevant.
Thanks in advance for your help.
2022-07-22 19:51:34,327] Installer running.
[2022-07-22 19:51:34,327] Command Line Arguments:
[2022-07-22 19:51:34,328] ['/tmp/vmis.FhUx25/install/vmware-installer/vmware-installer.py', '--set-setting', 'vmware-installer', 'libconf', '', '--install-component', '/tmp/vmis.FhUx25/install/vmware-installer', '--install-bundle', '/home/ghaz/.cache/vmware/cds/cdstmp_ws-linux_16.2.4_20089737/VMware-Workstation-16.2.4-20089737.x86_64.bundle', '', '--delete-install-components', '--install-component=/home/ghaz/.cache/vmware/cds/cdstmp_tools-winPreVista_11.3.5_20089737/vmware-tools-winPreVista-11.3.5-18557794.x86_64.component', '--install-component=/home/ghaz/.cache/vmware/cds/cdstmp_tools-linux_11.3.5_20089737/vmware-tools-linux-11.3.5-18557794.x86_64.component', '--install-component=/home/ghaz/.cache/vmware/cds/cdstmp_tools-windows_11.3.5_20089737/vmware-tools-windows-11.3.5-18557794.x86_64.component', '--install-component=/home/ghaz/.cache/vmware/cds/cdstmp_tools-solaris_11.3.5_20089737/vmware-tools-solaris-11.3.5-18557794.x86_64.component', '--install-component=/home/ghaz/.cache/vmware/cds/cdstmp_tools-netware_11.3.5_20089737/vmware-tools-netware-11.3.5-18557794.x86_64.component', '--install-component=/home/ghaz/.cache/vmware/cds/cdstmp_tools-linuxPreGlibc25_11.3.5_20089737/vmware-tools-linuxPreGlibc25-11.3.5-18557794.x86_64.component', '--install-component=/home/ghaz/.cache/vmware/cds/cdstmp_tools-winPre2k_11.3.5_20089737/vmware-tools-winPre2k-11.3.5-18557794.x86_64.component']
[2022-07-22 19:51:34,444] System installer version is: 3.0.0.19376536
[2022-07-22 19:51:34,444] Running installer version is: 3.0.0.20089737
[2022-07-22 19:51:34,445] Opening database file /etc/vmware-installer/database
[2022-07-22 19:51:34,535] Uncaught exception in installer:
File "/tmp/vmis.FhUx25/install/vmware-installer/vmware-installer.py", line 694, in <module>
main(options)
File "/tmp/vmis.FhUx25/install/vmware-installer/vmware-installer.py", line 536, in main
txn.Install(options.installComponent,
File "/tmp/vmis.FhUx25/install/vmware-installer/vmis/core/transaction.py", line 610, in Install
resolveResults = Resolve(common.repository.available, common.repository.installed, [], db.database)
File "/tmp/vmis.FhUx25/install/vmware-installer/vmis/core/dependency.py", line 1421, in Resolve
positiveGraph.constructLinks(installed)
File "/tmp/vmis.FhUx25/install/vmware-installer/vmis/core/dependency.py", line 367, in constructLinks
for dependency in node.component.dependencies:
File "/tmp/vmis.FhUx25/install/vmware-installer/vmis/core/component.py", line 489, in _getDependencies
deps = db.database.components.GetDependencies(self._uid)
File "/tmp/vmis.FhUx25/install/vmware-installer/vmis/db.py", line 706, in GetDependencies
cur = self._db.execute('SELECT dependency FROM component_dependencies WHERE component_id=?',
File "/tmp/vmis.FhUx25/install/vmware-installer/vmis/db.py", line 233, in execute
return self._db.execute(query, args)
sqlite3.OperationalError: no such table: component_dependencies
